I saw the Mausberry car switch and it looked perfect, however it's out of stock
Does anyone have any other inexpensive solutions to gracefully shutdown the pi when power is cut?
Thanks!
IIRC the Mausberry switch is actually a different. See https://mausberry-circuits.myshopify.co ... ply-switch.
Wow I love the work your doing! I will defiantly look into setting it up on mineBostonDev wrote:I use the Pi UPS out of Germany. When it detects a power loss, it acts like a UPS and sends a safe shutdown signal to your Pi.
Given you're building a GPS for the car, check out Black Box Pi. I've built an open source black box for the car using a Pi that logs GPS, OBD2, and more.
http://www.blackboxpi.com/
http://www.raspberrypi.org/forums/viewt ... 41&t=70517Tommyb10 wrote:Now it's time to look for some good looking gps software to run
I have looked at this setup, but I can't seem to find a good osd layout for my 800x480 displayfruitoftheloom wrote:http://www.raspberrypi.org/forums/viewt ... 41&t=70517Tommyb10 wrote:Now it's time to look for some good looking gps software to run
http://www.engineering-diy.blogspot.ro/ ... pdate.html
Is there any update on your setup? I saw you were starting a motorcycle version, did that get completed?BostonDev wrote:I use the Pi UPS out of Germany. When it detects a power loss, it acts like a UPS and sends a safe shutdown signal to your Pi.
