mrteach
what kind of data is this?
Mon Aug 25, 2014 11:03 pm
I'm using mpd and a python wrapper. When I use status() I get this it starts with the ___ bracket. I'm trying to retrieve this data to find out if it is playing or not.
>>> data
{'songid': '28', 'playlistlength': '1', 'playlist': '32', 'repeat': '0', 'consume': '0', 'mixrampdb': '0.000000', 'random': '0', 'state': 'play', 'xfade': '0', 'volume': '-1', 'single': '1', 'mixrampdelay': 'nan', 'time': '228:429', 'song': '0', 'elapsed': '228.473', 'bitrate': '128', 'audio': '44100:24:2'}
My current workaround is turning it into a string and using the split(',') to retrieve my information.
kusti8
Re: what kind of data is this?
Mon Aug 25, 2014 11:18 pm
Looks like it is a dictionary.
There are 10 types of people: those who understand binary and those who don't.
mahjongg
Mon Aug 25, 2014 11:59 pm
looks like the internal list of strings used in an music player program that has a "playlist", and organized so that internationalizing (translating the program) is made easier.
mrteach
Tue Aug 26, 2014 3:01 am
any easy way to extract the data? into a variable I want to know if it is playing or not..
Douglas6
Tue Aug 26, 2014 3:33 am
I believe kusti8 is correct, but you can verify by reading the documentation regarding how you got the data variable. Assuming it is a Python dictionary, you can access the 'state' property so:
if data['state'] == 'play':
    print('playing')
Very basic, very well documented Python code.
Tue Aug 26, 2014 6:15 am
https://docs.python.org/2/library/json.html
It's JSON so simple to decode.
mrteach
Fri Aug 29, 2014 8:55 pm
okay how to I use json.... I want to check what state it is on...
Fri Aug 29, 2014 8:58 pm
import json
decoded = json.loads(jsondata)
print decoded['songid'], decoded['state']
gkreidl
Fri Aug 29, 2014 9:17 pm
DougieLawson wrote:
import json
Sorry, Dougie, but this is simply nonsense. Why should anybody use Json inside Python to "decode" a simple Python dictionary,
Minimal Kiosk Browser (kweb)
mrteach
Fri Aug 29, 2014 9:22 pm
oh sorry I didn't read the first parts. Yes that works perfectly =)
print('playing')
mrteach
Fri Aug 29, 2014 9:43 pm
Thanks again that code worked perfectly. I want to do one more thing
i'm doing data['time']
i get this outputted
'21:429'
is it possible to some how extract compare the numbers in a %.
e.g. 21/429 = 0.05 = 5%
I want to created an LED bar that will show the progress of the audio.
EDIT: I tried just replacing the : to a / but that didn't work =/ lol
mrteach
Fri Aug 29, 2014 9:55 pm
Nevermind figured it out good old 'eval'
Douglas6
Fri Aug 29, 2014 9:59 pm
mrteach wrote:I'm using mpd and a python wrapper. When I use status() I get this it starts with the ___ bracket. I'm trying to retrieve this data to find out if it is playing or not.
>>> data
Gotta admit, that data looks a bit 'pantsed'.
data['time'] = 228:429
data['elapsed'] = 228.473
So not only is the format different (colon vs. dot), but the elapsed time is greater than the song time (assuming that's what those are.) Again assuming they represent seconds and milliseconds, you could split out the first part of each and divide elapsed by (total) time, but, I'm not feeling good about the data.
What is the 'python wrapper' you're using? Isn't there a fairly standard Python library for MPD?
[EDIT: Ok, if that works, clearly my assumptions were wrong.]
Fri Aug 29, 2014 11:00 pm
gkreidl wrote:
DougieLawson wrote:
import json
It walks like JSON, it quacks like JSON, why not decode it like JSON?
mrteach
Sat Aug 30, 2014 2:01 am
>>> data
Yeah I had to take a close look (I didn't think they had a song length) they did it by saying 228(current duration of song):429(length of the whole song).
Using python-mpd2 by the way.
Thanks again. I think the only reason I wouldn't use json is because you have to import something else(not sure if this acutally takes memory or anything) and it won't decode right away you have to convert it from ' to " using json.dumps(data) first.
so I would have to do
import json
decoded = json.loads(json.dumps(data))
and oddly it would output u'play or something like that instead of just play (unless I messed up with the code). I tried without dumping it (converting ' to ") but it gave me an error.
this did help me learn a bit about json.. not sure what it is for but will be in the back in my memory banks. Thanks.
ame
Sat Aug 30, 2014 3:04 am
DougieLawson wrote:
gkreidl wrote:
DougieLawson wrote:
import json
Because it's a dict. It's already 'decoded' and trivial to access.
KenT
Sat Aug 30, 2014 8:27 am
DougieLawson wrote:
gkreidl wrote:
DougieLawson wrote:
import json
http://json.org/
However JSON quacks twice, this quacks only once . JSON insists on " rather than '. I got caught by that one only yesterday.
Its a printout of a python dictionary
Pi Presents - A toolkit to produce multi-media interactive display applications for museums, visitor centres, and more
Download from http://pipresents.wordpress.com
paddyg
Sat Aug 30, 2014 12:30 pm
similar but different:
1. data is a dictionary object
>>> data
2. data is json.dumps(dictionary object)
>>> data
'{"songid": "28", "playlistlength": "1", "playlist": "32", "repeat": "0", "consume": "0", "mixrampdb": "0.000000", "random": "0", "state": "play", "xfade": "0", "volume": "-1", "single": "1", "mixrampdelay": "nan", "time": "228:429", "song": "0", "elapsed": "228.473", "bitrate": "128", "audio": "44100:24:2"}'
also https://groups.google.com/forum/?hl=en-GB&fromgroups=#!forum/pi3d
Return to “Python”
