jmb2341
Bluetooth Speakers
Sun Aug 24, 2014 8:39 pm
There is already a good amount of information on using a Raspberry Pi to make your speakers into Bluetooth speakers. I followed this tutorial,
http://www.instructables.com/id/Turn-yo ... /?ALLSTEPS
and ended up with almost what I wanted.
Ive been able to play music over my speakers through my Pi with an iPhone 4 and iPhone 5 but not a computer. All devices are able to pair but music does not transfer through my Macbook Pro running Mavericks.
Is there a different connection protocol with computers compared to phones? I would think that a new computer would be A2DP and AVRCP enabled.
I am using a CSR8510 Bluetooth USB dongle on my Pi.
Douglas6
Re: Bluetooth Speakers
Mon Aug 25, 2014 12:31 am
jmb2341 wrote:Is there a different connection protocol with computers compared to phones?
No, but.... I'm a Windows guy, so I can't try this, but it might be that the MacBook is looking for a slightly different Class of Device (CoD). I would try changing the 'class' line in /var/lib/bluetooth/<adapter address>/config, to:
class 0x64041C
reboot the Pi and just to be sure, re-pair with the MacBook. (This is a handy calculator for translating CoDs to hex and back: http://www.ampedrftech.com/cod.htm)
Failing that, check /var/log/syslog and (following the instructables guide), /var/log/bluetooth_dev for any informative errors.
jmb2341
Sat Aug 30, 2014 4:52 pm
Thank you for the reply. I finally got a chance to test this again. Unfortunately every time I reboot the class seems to reset. I use,
 sudo nano /var/lib/bluetooth/00:1A:7D:DA:71:13/config
to edit the file and changes are saved. Then I reboot and check the file but the class reverts to
 class 0x4e041c
This doesn't seem to have Audio as a service class which could be the problem.
http://www.ampedrftech.com/cod.htm?result=4e041c
Do you know how I can write the class so it wont reset?
Douglas6
Sat Aug 30, 2014 5:05 pm
Sorry, I didn't think it was necessary but it sounds like you'll need to make the same change also in /etc/bluetooth/main.conf
jmb2341
Sat Aug 30, 2014 6:42 pm
Unfortunately I already made the change in both. It remains the same in
but when I reboot the
reverts back.
Here is my config file,
pi@raspberrypi ~ $ cat /var/lib/bluetooth/00:1A:7D:DA:71:13/config
name Bose1
pairable yes
class 0x64041c
and here is my conf file
pi@raspberrypi ~ $ cat /etc/bluetooth/main.conf
[General]
# List of plugins that should not be loaded on bluetoothd startup
#DisablePlugins = network,input
# Default adaper name
# %h - substituted for hostname
# %d - substituted for adapter id
Name = Bose1
# Default device class. Only the major and minor device class bits are
# considered.
# Class = 0x4e041c
Class = 0x64041c
# How long to stay in discoverable mode before going back to non-discoverable
# The value is in seconds. Default is 180, i.e. 3 minutes.
# 0 = disable timer, i.e. stay discoverable forever
DiscoverableTimeout = 0
# How long to stay in pairable mode before going back to non-discoverable
# The value is in seconds. Default is 0.
# 0 = disable timer, i.e. stay pairable forever
PairableTimeout = 0
# Use some other page timeout than the controller default one
# which is 16384 (10 seconds).
PageTimeout = 8192
# Discover scheduler interval used in Adapter.DiscoverDevices
# The value is in seconds. Defaults is 30.
DiscoverSchedulerInterval = 30
# Automatic connection for bonded devices driven by platform/user events.
# If a platform plugin uses this mechanism, automatic connections will be
# enabled during the interval defined below. Initially, this feature
# intends to be used to establish connections to ATT channels.
AutoConnectTimeout = 60
# What value should be assumed for the adapter Powered property when
# SetProperty(Powered, ...) hasn't been called yet. Defaults to true
InitiallyPowered = true
# Remember the previously stored Powered state when initializing adapters
RememberPowered = true
# Use vendor, product and version information for DID profile support.
# The values are separated by ":" and VID, PID and version.
#DeviceID = 1234:5678:abcd
# Do reverse service discovery for previously unknown devices that connect to
# us. This option is really only needed for qualification since the BITE tester
# doesn't like us doing reverse SDP for some test cases (though there could in
# theory be other useful purposes for this too). Defaults to true.
ReverseServiceDiscovery = true
# Enable name resolving after inquiry. Set it to 'false' if you don't need
# remote devices name and want shorter discovery cycle. Defaults to 'true'.
NameResolving = true
# Enable runtime persistency of debug link keys. Default is false which
# makes debug link keys valid only for the duration of the connection
# that they were created for.
DebugKeys = false
# Enable the GATT Attribute Server. Default is false, because it is only
# useful for testing.
AttributeServer = false
Return to “Media centres”
