Adethefridge
Reloading start menu
Fri Aug 22, 2014 12:41 pm
Hi just received my first raspberry pi
I have loaded the standard os from the start menu,which worked fine,
I now want to return to the start menu to load the xbmc os ( thats assuming it's from there that I load the xbmc from ? )
Please help.....
propagandhi
Contact: Yahoo Messenger
Re: Reloading start menu
Fri Aug 22, 2014 7:44 pm
If you are using NOOBS, press the shift key while booting up and the interface will come up to select the OS of your choice.
Because it keeps on working, don't make it right.
Fri Aug 22, 2014 8:14 pm
If you are using the Noobs operating system chooser software, then you must install your choices of operating system at first install
You can not add or remove operating systems sometime in the future.
