HiassofT
Re: STICKY: The I2S sound thread.
Mon Jan 14, 2019 5:07 pm
The "DAI ... not registered - will retry" messages are harmless, they are caused by deferred probing. The important thing is that you get the "i2s mapping ok" message, this means the driver loaded successfully.
I'm not familiar with that codec but I'd recommend checking the alsamixer settings - probably some volume mixers are muted.
so long,
Hias
DanR
Tue Jan 15, 2019 3:18 pm
It wasn't the mixer volume or muting it was me misreading the datasheet and crossing the wiring for i2s DIN and DOUT. I will now sink into the background and quietly accept the doughnut award!!
Thanks for your reply though, it made me realise it must be something stupid or a broken codec. It was something stupid though ie me!!
Dan
mhelin
Wed Jan 23, 2019 9:14 pm
HiassofT wrote:
Thu Nov 08, 2018 8:29 pm
If you want to use the codec in left-justified mode you also have to use the left-justified dai format (SND_SOC_DAIFMT_LEFT_J).
But, I would not recommend doing that. bcm2835-i2 only operates correctly in left-justified mode if it is the frame master. If it's the slave left-right channel swaps can occur.
Your codec seems to require mclk synchronized with lrclk/bck when it's used in slave mode, something bcm2835 cannot provide. And using your codec as master with left-justified mode won't work well with bcm2835-i2s.
So, better use your AK5385 in I2S mode.
so long,
Hias
Why is that left-justified mode more prone to errors than I2S? LRCLK phase problem maybe, PCM DAI cannot detect the first LRCLK edge?
Anyway, it is also possible to use clock slave mode where the master clock (not needed by dai) and bit clock are generated on the hat externally, and PCM DAI generates the frame clock as frame master, anyone played with that? I think that should also make it possible to use the left-justified mode, and avoid that 2ns jitter @48k for an example.
HiassofT
Thu Jan 24, 2019 12:30 pm
It's probably a limitation in the hardware implementation of the I2S block. My guess is the sync logic needs at least one clock cycle between the leading edge of LRCLK and the start of data to reset a counter, flag, whatever - so DSP B and left justified modes don't sync properly when bcm2835 is a frame slave.
I think that could work, if the codec supports the combination of being bitclock master and frame slave and if it supports being frame slave in left-justified mode. bcm2835 should support bitclock-master/frame-slave mode (it's implemented, but I haven't tested that) but quite a lot of codecs don't allow independent master/slave selection of frame and bitclock and several codecs also don't support left justified or DSP B mode as frame slave. If you find a codec that supports this combination you could give it a try.
so long,
Hias
mhelin
Thu Jan 24, 2019 7:07 pm
https://www.akm.com/akm/en/file/datasheet/AK4558EN.pdf
In this case there is the 3.072 MHz (@48 kHz) bit clock, AK4558 runs in PLL slave mode 1 and syncs to that bit clock like RPi. RPi is frame master and generates the LRCLK.
If you want to use 44.1 kHz sample rate just use two oscillators 3.072 MHz for 48 kHz and 2.8224 MHz for 44.1 kHz sample rates, and toggle the EN pin of oscillators using some GPIO pin to select either (connect inverter between the pins so only one is enabled at a time). The osc output pin goes in high impedance state when it's not enabled.
AK4558 codec in RPi clock slave mode
You can also use any codec which requires MCLK by using for an example 12.288MHz oscillator for MCLK for codec, and the divide that by 4 using a flip-flop like 74HC74 or some counter chip like a 4-bit ripple counter 74HC93 for the bit clock. That would be actually easier as then you could use simpler codec without I2C/SPI codec control interface, AKM AK4556VT (https://www.akm.com/akm/en/file/datasheet/AK4556VT.pdf) for an example, and let RPi generate the LRCK. The AK4558 also would work fine in parallel mode (without I2C) as slave if master clock would be available. It's just so tiny chip to solder, and requires soldering the exposed pad under the chip to the PCB for cooling. It's got slightly better SNR though.
komeda
Fri Jan 25, 2019 10:25 am
Hi, maybe someone here can help me out with my setup, because I don't really understand how to do this right:
I have a samplerate converter SRC4382 with I2S output and I have a HiFiBerry DAC+ Pro both connected to the according default I2S pins on the pi. The HiFiberry alone works fine and I want to add the SRC as an input.
I control/setup the SRC via I2C, which also works.
The SRC is getting it's I2S clock signals from the HiFiBerry's PCM5122. When the HiFiBerry driver is loaded, the SRC gets a clock and starts working, giving a valid I2S output-signal (verified on oscilloscope).
I tried creating the needed alsa interface with a simple-card overlay but I don't understand how to tell it to use the PCM5122 clocks.
Can anybody here point me in the right direction?
mhelin
Tue Jan 29, 2019 7:54 pm
Using overlays you propably have to play with the examples (couldn't find one with a separate DAC and ADC, maybe there is one) and use the dummy spdif_rx codec (see older messages in this thread regarding the PCM4202 ADC).
If you can compile kernel modules you could also convert the PCM51xx DAC to a codec with the capture properties. Just add something like this to codec drivers struct snd_soc_dai_driver initialisation:
        .capture = {
		.stream_name = "Capture",
		.channels_min = 2,
		.channels_max = 2,
       .symmetric_rates = 1,
       .symmetric_formats = 1,
You should maybe also copy the .rates and .formats from the .playback initialization.
mateusfig
Fri Feb 08, 2019 10:09 pm
Anybody did try connect (I2S) ES9028 PRO board to Raspberry? I tried it out and I could get any sound.
sivakumar.skdu
Tue Feb 19, 2019 1:09 pm
Hi @stephan_o / All
Did you get a chance to check the Modules pcm4202 & rpi-4202-adc working on the Raspberry boards with PCM4202 ADC.
We have plan of designing RaPi3 board with PCM4202 ADC. And plan to use pcm4202 & rpi-4202-adc modules with support of S16_LE, 44100Hz, stereo input.
Thanking you.
Regards
S.Sivakumar
mateusfig
Tue Feb 19, 2019 1:46 pm
Please, any help about my question?
MrPolnareff
Mon Feb 25, 2019 3:23 pm
I'm currently trying to write a device tree overlay to add a TDM input to the raspberry pi (Raspberry Pi 3b+ Raspbian stretch).
The input will contain 8 channels. So in one frame, i should have 8 slots of 32 bits each.
I've tried to start with the simple_card overlay from dmesg i have this error: set_tdm_slot error.
Could someone help me writing (or have) a DT overlay implementing multiple channels input on the raspberry Pi ?
thank you,
MrPolnareff.
EDIT: By reading the Broadcom 2835 documentation(p119), it seems that the PCM interface of the raspberry can't be more than 2 channels.
