kusti8
Power Problems
Fri Aug 15, 2014 3:40 pm
This is a continuation of this thread since it got a little old while I waited for my new power supply. http://www.raspberrypi.org/forums/viewt ... 2&p=589267
When I plug in the raspberry pi with my new 2A 5V power supply, when running OpenELEC, the usb and keyboard start to work, but later fail to work. I assume that this is a problem with the raspberry pi, but when I use raspbian, the problems become less evident.
I am using a model B.
Any help is appreciated!
There are 10 types of people: those who understand binary and those who don't.
redhawk
Re: Power Problems
Fri Aug 15, 2014 4:18 pm
Is this during the user interface or does the screen go blank and you cannot wake it??
If you have a digital voltmeter then check the voltage at TP1/TP2 before and after the Pi becomes unresponsive.
If the voltage output appears lower than acceptable then you may have a poly fuse problem http://elinux.org/RPi_Hardware#Power_Supply_Problems
Richard S.
drgeoff
Re: Power Problems
Fri Aug 15, 2014 4:23 pm
If your power supply is the type with a USB socket output and needs a separate USB to micro-USB cable, try another cable.
kusti8
Re: Power Problems
Fri Aug 15, 2014 4:51 pm
The user interface shows and the wizard pops up but the mouse and keyboard are unusable and later the screen starts to dim. Already tested the TP1 and TP2 and the voltage was 4.65. Should I get a new raspberry pi or is there another cheaper remedy?
drgeoff
Re: Power Problems
Fri Aug 15, 2014 5:01 pm
What voltage between one end of the F3 polyfuse and ground?
What voltage between the other end of the F3 polyfuse and ground?
kusti8
Re: Power Problems
Fri Aug 15, 2014 5:52 pm
TP2 to SD card end of polyfuse is 5.19 V and the other side is also the same.
kusti8
Re: Power Problems
Fri Aug 15, 2014 6:34 pm
Bump
redhawk
Re: Power Problems
Fri Aug 15, 2014 7:52 pm
Could you measure TP1/TP2 again without the USB keyboard and mouse attached.
Richard S.
kusti8
Re: Power Problems
Fri Aug 15, 2014 8:07 pm
redhawk wrote:Could you measure TP1/TP2 again without the USB keyboard and mouse attached.
Richard S.
Without any USB, the voltage is 4.45 V to 4.65 V
redhawk
Re: Power Problems
Fri Aug 15, 2014 8:23 pm
Something is clearly wrong the voltage supply to the USB ports it's low and probably not sufficient to power the keyboard and mouse correctly.
In one of your posts you've measured TP2 with one end of the F3 polyfuse at 5.19v but TP1/TP2 was measured at 4.65v
So this would mean that there is a voltage drop of around 0.54v at both sides of the F3 polyfuse (measure to confirm this).
This is a considerable voltage drop for a Pi with no attached USB devices either the SoC is drawing more power than it's suppose to or the F3 polyfuse is going bad.
Back feeding power into the USB maybe one solution although not recommended without a stable regulated 5v supply.
Richard S.
kusti8
Re: Power Problems
Fri Aug 15, 2014 8:25 pm
Is there any way I can repair this for a long term solution (not back powering) or should I just get a new raspberry pi?
redhawk
Re: Power Problems
Fri Aug 15, 2014 8:33 pm
If you're good at soldering then I would try to replace the F3 polyfuse, or if you don't care then solder a wire link to bypass it.
The latter option would remove the Pi's protection from getting the wrong (high) voltage but at 5.19v I think you'll be fine.
Richard S.
kusti8
Re: Power Problems
Fri Aug 15, 2014 8:42 pm
Where would I be able to buy a replacement for the polyfuse?
drgeoff
Re: Power Problems
Fri Aug 15, 2014 9:48 pm
kusti8 wrote:Where would I be able to buy a replacement for the polyfuse?
You told me earlier today:
"TP2 to SD card end of polyfuse is 5.19 V and the other side is also the same.".
Something doesn't stack up.
kusti8
Re: Power Problems
Fri Aug 15, 2014 10:10 pm
Measured the polyfuse and sure enough, there is a 0.5 V difference. Sorry, not sure what happened the first time.
kusti8
Re: Power Problems
Sat Aug 16, 2014 12:48 am
Still, where could I buy such a fuse?
redhawk
Re: Power Problems
Sat Aug 16, 2014 8:25 am
kusti8 wrote:Still, where could I buy such a fuse?
eBay is usually a good place to find electronic components i.e. http://www.ebay.co.uk/itm//141295599449? (there are SMD versions but they may not fit the board).
Richard S.
mahjongg
Re: Power Problems
Sat Aug 16, 2014 10:34 am
you need an 1812 size 1Amp to 2Amp polyfuse (PTC Resettable Fuse).
something like this:
http://nl.farnell.com/jsp/search/produc ... DP-1345925
or this
http://nl.farnell.com/littelfuse/1812l2 ... dp/1822216
make sure that when soldering the fuse to the board, you do it quickly, because overheating the fuse may damage it.
kusti8
Re: Power Problems
Sat Aug 16, 2014 4:34 pm
Thank you! Will look into it.
