paaland
How to check filesystem for errors
Fri Jun 15, 2012 8:20 am
After my last reboot the root file-system was mounted read-only due to an error. dmesg reports:
[   39.556518] EXT4-fs error (device mmcblk0p3): add_dirent_to_buf:1270: inode #                                                   204: block 8322: comm dhclient-script: bad entry in directory: rec_len % 4 != 0                                                    - offset=3584(3584), inode=17498628, rec_len=26739, name_len=97
[   39.590756] EXT4-fs (mmcblk0p3): Remounting filesystem read-only
[   39.606110] EXT4-fs error (device mmcblk0p3) in ext4_evict_inode:170: Readonl                                                  y filesystem
How to force a check and make ths fs read-write again?
Dragon 32>BBC Model B>PC>PC>PC>PC>Raspberry PI (circle complete)
bredman
Re: How to check filesystem for errors
Fri Jun 15, 2012 8:41 am
fsck is the command to check and repair the filesystem
http://linux.die.net/man/8/fsck
Respectech
Thu Sep 12, 2013 6:03 am
Problem with fsck is this:
$ fsck
fsck from util-linux 2.20.1
e2fsck 1.42.5 (29-Jul-2012)
/dev/mmcblk0p2 is mounted.
WARNING!!! The filesystem is mounted. If you continue you ***WILL***
cause ***SEVERE*** filesystem damage.
Do you really want to continue<n>?
The proper way to check is this:
shut down and check the file system on reboot:
sudo shutdown -F -r now
after the RasPI is up and running again, check the results in /var/log/fsck/
VascoFerraz
Mon Apr 04, 2016 9:05 am
Is this command working on Jessie?
The issue is in -F or -f flags. If I don't use them, the system reboots fine.
I am getting this message:
[email protected]:/ $ sudo shutdown -F -r now
Code should not be reached 'Unhandled option' at ../src/systemctl/systemctl.c:6316, function shutdown_parse_argv(). Aborting.
Thanks.
Vasco
Vasco Ferraz
jojopi
Mon Apr 04, 2016 9:19 am
If the filesystem goes read-only due to serious errors, fsck should run on the next boot automatically. (Assuming the corruption does not prevent booting.)
I do not see much point forcing an fsck that the system does not think it needs. However, one way to do so in jessie is to add to /boot/cmdline.txt: "fsck.mode=force fsck.repair=yes".
VascoFerraz
Mon Apr 04, 2016 11:00 am
Thanks for the explanation.
Vasco Ferraz
jahboater
Mon Apr 04, 2016 5:23 pm
Or stick the SD card in a card reader and plug it into a Pi or any Linux system, then run fsck.
Return to “Raspbian”
