theoscy
Owncloud
Mon Aug 11, 2014 11:49 am
I apologize for the off topicness yet again.
I have an Ubuntu server running owncloud and I have set up remote access by forwarding port 8080 to it. I dont have a external static Ip its dynamic and changes about every week or every time the router is reset. However I can find my ip by visiting http://www.whatsmyip.org/ and then log into my server remotely doing myip/owncloud. My question is this, will my ISP plusnet notice im doing this and if they do am I not supposed to do it?
Many thanks
Oscar
You could say my love for Linux is terminal ;)
elatllat
Re: Owncloud
Mon Aug 11, 2014 2:48 pm
Yes that is permitted.
you can even give your dynamic IP a domain name.
http://compare.wikia.com/wiki/Free_dns
http://www.raspberrypi.org/forums/viewt ... 28&t=75037
SBC with 32GB RAM: https://hardkernel.com
FAQ : https://raspberrypi.stackexchange.com
Unanswered: https://www.raspberrypi.org/forums/search.php?search_id=unanswered
dan3008
Re: Owncloud
Mon Aug 11, 2014 3:55 pm
personally, I use afraid.org, adn they even provide a cron job, that your computer can do to keep your ip up to date :)
dan3008 wrote:Pays your money, takes your choice
gkreidl
Re: Owncloud
Mon Aug 11, 2014 5:14 pm
Any computer connected to the internet can be client and server. It's so designed, I consider blocking it - as some providers do - a criminal act.
Minimal Kiosk Browser (kweb)
theoscy
Re: Owncloud
Mon Aug 11, 2014 10:04 pm
Thanks for that guys, really helpful!
I now have used afraid.org to get a domain name, I have attempted to install a sync client on the server by following this to the letter apart from using nano not gedit. - http://ubuntuforums.org/showthread.php?t=1758930
However when I run - ps -A | grep inadyn - I get "Dayamon failed to start."
Any suggestions or alternatives?
elatllat
Re: Owncloud
Sat Aug 16, 2014 10:46 am
Re-read the 2nd post.
Return to “Off topic discussion”
