miauriel
RPi keeps replacing spaces in file names with "%20"
Mon Aug 04, 2014 8:37 pm
good day
I am using my B+ as a linux home file server, and every file I copy to the server is being renamed automatically. For example, if the file is named "my favorite movie.avi", when I copy it over it turns to "my%20favorite%20movie.avi".
Is there any way I can stop this renaming from occurring
Thanks!
Re: RPi keeps replacing spaces in file names with "%20"
Mon Aug 04, 2014 8:48 pm
Simple answer: don't put spaces in file names use something benign like an underscore.
More complex answer: URLs/URIs with special characters get encoded so that the special characters aren't sent over the network. Spaces count as special characters so get encoded to %20. http://en.wikipedia.org/wiki/Percent-encoding there's no easy way to avoid it.
gkreidl
Mon Aug 04, 2014 8:56 pm
miauriel wrote:good day
Thanks!
How do you copy the files to your "home server". There are lots of ways to keep the spaces (Dougie prefers to live in the stone age of computing, when spaces were not allowed).
Minimal Kiosk Browser (kweb)
DirkS
DougieLawson wrote:More complex answer
I'm fairly sure there's an even more complex answer as (or maybe a simpler answer). I for one don't have any problems with spaces being converted when I move files to my Pi server...
Gr.
Dirk.
AndrewS
Mon Aug 04, 2014 8:57 pm
What (server? client?) software are you using to copy files to/from the server?
Mon Aug 04, 2014 9:11 pm
Gr.
Dirk.
When you've lived with these rules for 34 years: dataset names should be 44 characters (or fewer). The segments of a dataset name can be no more than 8 characters, must start with an alpha or national and are separated by full stops. The valid chars are upper case alpha, numbers and three national characters it becomes a habit to dislike names that don't match that pattern.
I don't need spaces in my Unix file names, so I don't use spaces in my Unix file names.
AndrewS
Mon Aug 04, 2014 9:14 pm
DougieLawson wrote:The segments of a dataset name can be no more than 8 characters, must start with an alpha or national and are separated by full stops.
AUTOEXEC.BAT style? ;)
Mon Aug 04, 2014 9:35 pm
NO, 8.3 sucks and is an artefact of the Fisher Price range of toy computers with less than 640K of memory that appeared in the 1980s.
My habit is from IBM's S/360 MFT / MVT & S/370 MVS (also know a proper mainframe computers[1]). The problem was that the dataset name and some flag bits and bytes had to fit in an 80 byte record. It's even worse with tape datasets, only the last seventeen characters get written to the machine readable tape labels on the first few feet of tape.
[1] The distinction being never trust a computer you can lift.
miauriel
Mon Aug 04, 2014 10:41 pm
I normally use an underscore to indicate a space in a file name. However, trying to convince others on my home network to go the extra mile when collating information is like talking to a wall. Moreover, I am also using my B+ as a torrent box running Transmission and the files I download already have spaces in the name which are turned into %20's.
At this time I am backing up data onto the 1TB HDD connected to my pi from other devices, and will eventually be connecting another 1TB HDD to be a redundant timed backup. So with a very large amount of files that have already been named, I want to try and avoid renaming everything prior to putting it on my PiServer.
I am running raspian on the B+, LXLE on my laptop, Win8 (puke) on my wife's laptop, and a WDTVLIVE hub (linux I believe). Although I try and SSH into my pi to transfer files from the command line, I also use my laptop to transfer files.
is there anything I can do??
DirkS
Mon Aug 04, 2014 11:03 pm
What networking software do you use (server / client side)? Samba, NFS, any other?
Not sure if it's relevant, but maybe also useful to know the file system of the PiServer drive (ext4, NTFS, ... ).
W. H. Heydt
Tue Aug 05, 2014 12:08 am
As exercises for the readers...
1. Try manipulating files with embedded spaces in the file names in a command line environment.
2. Now do it in a scripting language.
The results of doing this in an "obvious" way may not produce the results you think they will.
miauriel
Tue Aug 05, 2014 12:46 am
I'm using samba, and the TB HDD is ntfs. @ W. H. Heydt: please elaborate on what you mean by manipulating in the command line and scripting.
Thanks!
AndrewS
Tue Aug 05, 2014 1:59 am
Are you just copying the files to/from the Pi using regular old Windows Explorer then? As Dougie already mentioned, "%20" is the URI-encoding for a space character, so it's what I'd expect to (perhaps) see if you were using some kind of web or http access to your Pi. But AFAIK Samba should be totally fine with filenames containing spaces :?
Ahh, perhaps this is the bug you're seeing? https://bugs.launchpad.net/ubuntu/+sour ... ug/1325270 (which indicates it's a bug in the pcmanfm file-manager rather than in samba itself)
W. H. Heydt
Tue Aug 05, 2014 4:37 am
miauriel wrote:I'm using samba, and the TB HDD is ntfs. @ W. H. Heydt: please elaborate on what you mean by manipulating in the command line and scripting.
Thanks!
Move, copy, rename, concatenate, delete, sort, compare, and so on files with spaces in the file names using a CLI and the doing the same sorts of things using a .bat file or shell script (sh, csh, bash, etc.).
Cancelor
Tue Aug 05, 2014 6:52 am
Yeh, if it doesn't fill a room it's not worth having ;-)
I guess it all dates back to when cards were used to enter data and programmes. http://en.wikipedia.org/wiki/Punched_ca ... cter_codes I used to submit my Fortran code using them :)
Can't find the thread you want? Try googling : YourSearchHere site:raspberrypi.org
RaTTuS
Contact: Twitter YouTube
Tue Aug 05, 2014 7:50 am
miauriel wrote:I normally use an underscore to indicate a space in a file name. However, trying to convince others on my home network to go the extra mile when collating information is like talking to a wall. Moreover, I am also using my B+ as a torrent box running Transmission and the files I download already have spaces in the name which are turned into %20's.
yes lots ...
organise your data in sensible locations
always use the same name conventions
be consistent
what is it that is displaying the %20% instead of spaces ?
the CLI , windows , explorer , etc
then use the same method to copy and only one way i.e.
automagically use
rsync to put them where you want and need
never copy by hand or windows if you can help it
Covfefe
AndrewS
Tue Aug 05, 2014 11:59 am
Cancelor wrote:Yeh, if it doesn't fill a room it's not worth having ;-)
You must use your Pi in a very small room then? :lol:
BMS Doug
Tue Aug 05, 2014 12:34 pm
That's why I have a doll's house. well actually it's because I have daughters.
Doug.
Ravenous
Tue Aug 05, 2014 12:45 pm
BMS Doug wrote: That's why I have a doll's house.
"Barbie's server farm" accessories...
Barbie forecasts her own weather...
Barbie breaks the record for cryptographic number crunching...
hansotten
Tue Aug 05, 2014 1:15 pm
Nothing in Linux should prevent spaces in filenames, except crappy programs.
http://duinorasp.hansotten.com for Raspberry Pi and Arduino and ESP8266
http://retro.hansotten.nl for retrocomputing with the 6502 cpu
Joe Schmoe
Tue Aug 05, 2014 2:10 pm
Leaving Windows (ref: your mention of .bat files) aside (and what else is one to do with Windows?), when writing Unix/Linux shell scripts in an eh-derived shells (and, leaving csh and csh-derived shells aside - and, seriously, what else is one to do with csh/tcsh as a scripting language?), you are usual entirely OK as long as you quote every variable reference. That is, you just get in the habit of never writing:
echo $foo
and always writing:
echo "$foo"
As long as you do that, you should be OK, as long as these two things don't happen:
1) Files with newlines in them. This is truly deranged and you can put me down on the list of people who think that spaces in filenames are OK nowadays, but newline is truly sick. Against this, for all I know, quoting does make files-with-newlines work OK; I've never had occasion to test this in my work.
2) Scripts/functions that call other scripts/functions passing parameters on. This has caught me in the past, where you essentially have to "double-quote" things in order to protect them against both the current shell and the sub-shell. This can, obviously, get ugly if you have to support infinite levels of sub-shell-ing.
RaTTuS
Tue Aug 05, 2014 2:19 pm
having leading - in files names is a crime against humanity ... see also leading / trailing spaces
never create a file called
-rf
Covfefe
mikerr
Tue Aug 05, 2014 2:23 pm
yep, here's a great page on the horrors of filenames:
http://www.dwheeler.com/essays/fixing-u ... names.html
piglet
Tue Aug 05, 2014 2:24 pm
hansotten wrote:Nothing in Linux should prevent spaces in filenames, except crappy programs.
and common sense...
btw I still like GDG's. **pines for mainframe days when programmers had a clue**
Tue Aug 05, 2014 3:07 pm
and common sense...
+1 Generation data groups are so much easier than having stupid date/time stamps in dataset names.
He's not a dead dinosaur, he's pining for the mainframe.
