The module is from http://github.com/doceme/py-spidev.
I can read bytes from the SPI slave just fine, but the Raspberry Pi seems to send only 0xFF (or, more likely, the MOSI is held high by some config somewhere.)
I have disconnected the slave, to make sure that it's not holding the line high -- this is the RPi not pulling it low.
And here is the output (as in, nothing,) supposed to be on the green channel in the Saleae Logic display. You can see the clock (purple line):
I'm pretty sure the wiring is correct, because I can program the target device (which is an ATTiny85) using avrdude/gpio over the same connection, and when I measure directly on the RPi, I hook the green probe to the fourth-from-the-end pin (ground, clock, miso, mosi, counting backwards.)
Here is the simple test program:
# module spivolt.py
import spidev
import os
class SpiVolt(object):
def __init__(self):
""" Open and configure the SPI device.
self.dev = spidev.SpiDev()
self.dev.open(0, 1)
self.dev.max_speed_hz = 500000
self.dev.bits_per_word = 8
self.dev.cshigh = False
self.dev.lsbfirst = False
self.dev.mode = 0
def close(self):
self.dev.close()
def read(self):
""" Read a voltage value from the power controller.
Returns a voltage value as a float, or None if not able to
properly communicate (re-trying may improve things).
l = self.dev.xfer([0])
l.extend(self.dev.xfer([1]))
l.extend(self.dev.xfer([2]))
l.extend(self.dev.xfer([3]))
if l[0] == 240 and l[2] == 240:
return (l[1] + l[3]) * 0.5 * 14.19 / 256;
if l[1] == 240 and l[3] == 240:
return (l[0] + l[2]) * 0.5 * 14.19 / 256;
return None
def off(self):
""" Send a signal to cut power (if on battery.)
Will sync the file system first, for safety.
print "syncing to turn off..."
os.system("sync")
print "turning off"
self.dev.xfer([0xAA])
self.dev.xfer([0x55])
# program
import spivolt
volt = spivolt.SpiVolt()
volt.off()
Why does the RPi not output anything over the MOSI line?
