lunarkingdom
RetroPie With 1 or 2 GPIO Game Controllers Tutorial
Wed Jul 30, 2014 11:27 pm
Hello! Most of the credit to getting this working goes to DigitalLumberjack who did all the code to make the joysticks work, he has been working close with me the last 3 days and this is what we have come up with. The rest goes to PetRockBlog for all of the Retropie code as well as for the Retropie Image. As with all opes source I am sure a bazillion others helped get this to where it is today and I thank them as well. Follow THIS tutorial only, there are subtle changes to PetRockBlog's and DigitalLumberjack's pages to get the B+ running smoothly. First thing you are going to need to do is download the RetroPieImage_Ver2.3.img from here:
http://blog.petrockblock.com/download/r ... ect-image/
Burn this image to your microSD card then put it in your Raspberry Pi and fire it ip and proceed.
Credit for this first part goes to:
http://blog.petrockblock.com/2012/07/22 ... pberry-pi/
Follow THIS tutorial only, there are subtle changes to PetRockBlog's and DigitalLumberjack's pages to get the B+ running smoothly. The link is for credit and reference only.
First run the raspi-config script to extend your root file system.
sudo raspi-config
Credit for the next part goes to:
https://github.com/digitalLumberjack/mk ... ystick_rpi
This part you can either configure your GPIO for 1 or 2 GPIO controllers (or mame cabinet controls), the GPIO pinout is as follows for B+ Pi, if you are only hooking up one joystick use the green only.
Right click this image and select open link in new window to see large version
Installation Script
Download the installation script and install it:
mkdir mkjoystick
cd mkjoystick
wget https://github.com/digitalLumberjack/mk ... install.sh
sudo sh ./install.sh
Loading the driver
The driver is loaded with the modprobe command and take one parameter nammed "map" representing connected joysticks. When you will have to load the driver you must pass a list of parameters that represent the list of connected Joysticks. The first parameter will be the joystick mapped to /dev/input/js0, the second to js1 etc..
If you have connected a joystick on RPi GPIOs (joystick 1 on the pinout image) you must pass "map=1" as a parameter. If you are on B+ revision and you connected 2 joysticks you must pass map="1,2" as a parameter.
If you have one joystick connected on your RPi B or B+ version you will have to run the following command :
sudo modprobe mk_arcade_joystick_rpi map=1
If you have two joysticks connected on your RPi B+ version you will have to run the following command :
sudo modprobe mk_arcade_joystick_rpi map=1,2
The GPIO joystick 1 events will be reported to the file "/dev/input/js0" and the GPIO joystick 2 events will be reported to "/dev/input/js1"
Auto load at startup
Open /etc/modules :
sudo nano /etc/modules
And add the line you use to load the driver :
For single controller:
For dual controllers:
To exit and save hit control X then select Y and when it shows the file name "/etc/modules" hit enter.
Testing
Use the following commands to test joysticks 1 inputs :
jstest /dev/input/js0
Use the following commands to test joysticks 2 inputs :
jstest /dev/input/js1
To exit the test program use ctrl+c, do not cycle the power to get out of it.
Then reboot:
sudo reboot
Next part make sure you use correct caps on RetroArch name
cd /opt/retropie/emulators/RetroArch/installdir/bin
sudo ./retroarch-joyconfig -j 0 >> /opt/retropie/configs/all/retroarch.cfg
It will say:
found joypad driver: udev
using joypad: 2nd arcade GPIO controller B+
Joypads tend to have stale state after opened.
press some buttons and move some axis around to make sure joypad state is completely neutral before proceeding.
when done press enter…
Hit Enter and it will then say:
Configuring binds for player #1 for joypad #1
B button (down)
Then map your joystick and buttons BUT if there are more to do than your game pad has just use the last button over and over until it was done, after you are complete open the file you just wrote for editing like this:
sudo nano /opt/retropie/configs/all/retroarch.cfg
Copy and paste the entire section that begins with “input_player1_” and change it to “input_player2_”. Don’t forget to change the “input_player_joypad_index” to 0 or 1 as well. Make sure you add this to the end of your code so you can use start and select together to exit rom's:
input_enable_hotkey_btn = “4″
input_exit_emulator_btn = “5″
Once complete save by using control and x, then y for yes, then enter for filename (make sure you don't accidentally hit a key and mess it up) then do this and let it boot to emulationstation, load a rom and see if it works (it should), if there are any discrepancies please don't hesitate to let me know. I hope this helps some of you who are having trouble adding buttons via the GPIO, I do not know how to set up any other interface so please do not ask this is for digital inputs only (buttons and arcade joysticks).
pandadesh
Re: RetroPie With 1 or 2 GPIO Game Controllers Tutorial
Thu Aug 21, 2014 2:32 pm
i want to add more buttons to player 1. how will i do that? and what if i want to use a analog joystick?
the joystick is this https://www.adafruit.com/products/512
thanks in a advance
Vasilisrk
Sat Sep 27, 2014 6:14 pm
Hi, thanks for the great tutorial.
I've done it all but I don't know what to do with that:
Copy and paste the entire section that begins with “input_player1_” and change it to “input_player2_”. Don’t forget to change the “input_player_joypad_index” to 0 or 1 as well....
P-Nut
Thu Feb 19, 2015 10:26 pm
I get a error when I try and use 'sudo modprobe mk_arcade_joystick_rpi map=1,2
FATAL: Module mk_arcade_joystick_rpi not found....
I think when installing the problem occurs.
The install file references to links/packages that are no longer there....
Hopefully someone will help me out... its driving me nuts.
DigitalLumberjack
Fri Feb 20, 2015 12:49 pm
There are new version since this tutorial.
https://github.com/digitalLumberjack/mk ... /releases/
You should change all 0.1.1 to 0.1.4 :)
P-Nut
Sat Feb 21, 2015 12:49 am
Thanks for the reply.
I was able to do the new tutorial of 1.0.4.
* mkdir mkjoystick
cd mkjoystick
* sudo sh ./install.sh updatesystem
sudo reboot
* sudo modprobe mk_arcade_joystick_rpi map=1,2
* sudo nano /etc/modules
* mk_arcade_joystick_rpi map=1,2 (got 2 player setup)
I then tested and all the inputs were registerd.
Most emulators work but I can't get pifba to respond to the controls... and I cant find anything that describes how to get it to work with the gpio/joystick setup. Could you please tell me how I can get pifba to work ;o
Greets Paul
KingRoyz
Thu Mar 05, 2015 8:16 am
sorry for my bad English,
I'm making an arcade retrogame using scripts digitlLumberjack:
https://github.com/digitalLumberjack/mk ... 9ab30134a5
Because I would like to add 4 players, I installed the integrated MCP23017, I realized, that, but can not be activated and usable outputs GPB6, GPB7, GPA6 and GPB7. I want to use all of the outputs of this integrated, how do I activate them? Where is the file to edit the parameters of MCP23017?
geoldr
Fri Mar 13, 2015 11:32 pm
Hey all, I am on the latest retro Pie, and using the latest 0.1.4. When I run the install script, I eventually get a 'Error! Bad return status for module build on kernel: 3.18.9-v7+ (armv71).
And when I modprobe, it just gives the FATAL: module mk_arcade_joystick_rpi not found.
Any ideas?
peter2626
Sat Mar 28, 2015 1:25 pm
Great work...Thanks so much
Has any one considered a tutorial video on this starting from a fresh install? Or does any one know if it exists. That would be excellent for noobs like me
thanks again for all the hard work
Djinny
Wed Apr 22, 2015 4:51 pm
How do i reconfigure the buttons and such?
I'm going to need 14 buttons + analog sticks using a 12bit ADC.
ABC/XYZ/Start/Select/Dpad4/Ltrigger/Rtrigger + two 12bit analog channels.
I know it's a lot but if i want compatibility with more emulators, i need a lot of buttons. n64 for example.
My RPi needs a fan, heat will leech into the battery, so people saying I don't need a fan, don't understand how Li-Po batteries are affected by high temps. Cool pi = cool battery.
I would very much so like to see a Pi2/Pi3 Zero, power and size.
Barnuk
Thu May 14, 2015 9:14 am
Hi, firstly - thanks for the work you've put in on this and the tutorial. I am however struggling to get the second controller (GPIO controller 2). To be recognised in any emulator other than MAME. The jstest works perfectly for both js0 and js1 but I just cannot get proper function in games elsewhere.
I have manually created a GPIOcontroller2.cfg to see if that helped but it didn't.
I wonder if maybe I'm just listing the code wrong in the retroarch.cfg (all configs) file. What should it look like (could you share yours please?)
Regards
Neil
ivwshane
Fri Jun 19, 2015 7:10 am
Can this be done with recalbox?
Also, is there a similar graphic for the pin out for the raspberry pi 2?
Fri Jun 19, 2015 8:42 am
ivwshane wrote: Also, is there a similar graphic for the pin out for the raspberry pi 2?
http://pi.gadgetoid.com/pinout
This is a doctor free zone.
ivwshane
Fri Jun 19, 2015 9:01 am
Thanks, I just realized the gpio on the b+ and rpi2 are the same:o
r1racing
Tue Dec 15, 2015 11:00 pm
Help!!!
I know this is old, but I cant make this work...
I follow all the steps, the buttons are workin ok on the test, BUT nothing happens on any emulator...
I have the raspberry pi 2, model B, 2 joysticks and 8 buttons each player.. but I have to use the keyboard..
any clue what can I do???
thrylax
Sun Jun 19, 2016 4:02 pm
Hi. Thanks for the great script by the way. Its EXACTLY what I was looking for.
I just have some issues I hope someone can help me with.
I had gotten this to work perfectly on my Raspberry Pi 3 running RetroPie v3.6, however, I recently tried to update to RetroPie v3.8.1 and when I run the script it seems to work fine, but whenever I try to start the script with sudo modprobe mk_arcade_joystick_rpi map=1,2 I get the following error.
modprobe: FATAL: Module mk_arcade_joystick_rpi not found.
I followed the tutorial exactly and even made sure to update with sudo sh ./install.sh updatesystem as well as performed a reboot before installing with sudo sh ./install.sh.
I have tried to perform this install twice and both times I still get modprobe: FATAL: Module mk_arcade_joystick_rpi not found.
Any help on solving this would be greatly appeciated. Thanks.
thrylax
Sun Jun 19, 2016 9:34 pm
Nevermind. After an extensive search though the forums I managed to find this......https://github.com/recalbox/mk_arcade_j ... /issues/32
Which explains the issue as well as resolves it, at least for me on my Raspberry Pi 3 running RetroPie v3.8.1.
Basically what it says is that you need to do a manual install for the GPIO Joystick drivers. Heres a synopsis.
sudo apt-get update
sudo apt-get upgrade
sudo rpi-update
sudo apt-get install -y --force-yes dkms cpp-4.7 gcc-4.7 git joystick
sudo apt-get install raspberrypi-kernel-headers
wget https://github.com/digitalLumberjack/mk_arcade_joystick_rpi/releases/download/v0.1.4/mk-arcade-joystick-rpi-0.1.4.deb
sudo dpkg -i mk-arcade-joystick-rpi-0.1.4.deb
Start the Driver
Opens modules with nano editor for editing.
Add the following line to the now open file “mk_arcade_joystick_rpi” without quotes.
Save the file with CTRL+O press ENTER to save and then CTRL+X to exit.
sudo nano /etc/modprobe.d/mk_arcade_joystick.conf
Add the following line to the file "options mk_arcade_joystick_rpi map=1,2".
Reboot System
Done.
candyasdf
Thu Mar 09, 2017 7:50 pm
hi all,
for my case, my modprobe.d conf file named in: "mk_arcade_joystick_rpi.conf"
after edit this, my 2p controller live again. thanks god.
take an hour to figure it out ;).
sicboy101
Sun Oct 01, 2017 1:14 pm
hi all,
can you be more specific
i'm still get stuck
Thank You
balanceistische
Mon Oct 02, 2017 9:15 pm
hi all,
Well, you solved it.
pvl_mksv
Tue Feb 20, 2018 10:13 am
Hello.
In my nearest plans is to build a console on RPi Zero. Do I need to do some changes in scripts? I think gpio map is quite the same on b+ and zero.
Thanx.
pvl_mksv
Tue Feb 20, 2018 10:44 am
Hi, dear Mr./Mrs All.
I am going to build a console on RPi Zero (i have to usea very flat device in my case). Do i need to do any changes in scripts and drivers due to the diffirence of pinout gpio on tpi zero and rpi b(+). Thank you.
lucasbrowdias
Wed Mar 13, 2019 3:25 am
I´m quite new to rpi shell, but following the commands I wasn´t able to setup the gpio.
It says the kernal 4.14.30-v7 was skipped since the headers weren´t installed even though it said installation ok
and when I tried the modprobe is said
FATAL: Module mk_arcade_joystick_rpi not found in directory /lib/modules/4.19.27-v7+
Any help there?
Return to “Gaming”
