kusti8
Composite and Audio on B+
Mon Jul 28, 2014 9:40 pm
Hello! Haven't got the B+ yet but I wanted to know of you can use the composite jack and the audio jack at the same time. What I want to do is make a portable version of my media center and want to use the B+ I need the composite since some hotel TV do not have HDMI. I also need audio. Is there a way where I can put the video to the tv and then have the sound play throughout either the tv or speakers. Another question: should I use a sound card to improve quality or not. Any help is appreciated!
Re: Composite and Audio on B+
Mon Jul 28, 2014 9:48 pm
RPi 4B 4GB (SSD Boot)..
AndrewS
Mon Jul 28, 2014 9:49 pm
http://www.raspberrypi.org/forums/viewt ... 77#p577977
That obviously depends on whether the analogue audio from the B+ is "high quality enough" for you or not...
drgeoff
Mon Jul 28, 2014 9:50 pm
Yes, if you have a suitable cable you can have simultaneous composite video and stereo audio from the 4 pole 3.5 mm socket.
kusti8
Mon Jul 28, 2014 9:55 pm
Can anyone suggest a cable which I can buy for this purpose?
Mon Jul 28, 2014 10:00 pm
Last edited by fruitoftheloom on Mon Jul 28, 2014 10:04 pm, edited 1 time in total.
kusti8
Thank you!
SFX Group
Thu Jan 08, 2015 3:53 am
Can we use a standard 3.5mm audio jack to get sound from this? It appears that would short the composite to ground in the connector, i assume this is ok (which is why the connector was designed this way?)
Post 3 on a standard 3.5mm jack is ground, then post 4 is added in this are for the composite so using a standard audio jack will short these 2, again i assume by design?
Many Thanks
Ashley
© Copyright 2015 - www.ashleygriffin.ca
klricks
Thu Jan 08, 2015 5:17 am
SFX Group wrote:Can we use a standard 3.5mm audio jack to get sound from this? It appears that would short the composite to ground in the connector, i assume this is ok (which is why the connector was designed this way?)
Your 2 questions to me appear to be the same......
You can use a 3 ring plug in the RPi audio jack for audio only. It will short out the video signal but that is OK. I don't think there is video signal there anyway when using HDMI.
Be sure to fully seat the plug in the jack.
Thu Jan 08, 2015 8:23 am
Yes, the fourth connection (S in the TRRS of the plug) is for video and the circuit is designed so that it will not be damaged if shorted out - even if trying to output video at the time.
SFX Group
Thu Jan 08, 2015 1:14 pm
thanks
Many Thanks
Ashley
