marat569
How do I run this program?
Mon Jul 28, 2014 12:08 am
http://popcorntime.io/
I download the 32bit archive, extract, try to run popcorn-time.so and nothing happens; my cpu ussage does not even go up.
Help, please and thank you ^_^
kusti8
Re: How do I run this program?
Mon Jul 28, 2014 12:12 am
The raspberry pi is not 32 bit or 64 bit. It uses the armv6 and unless you have the source code, from git or somewhere, there is no way to run it on the pi (unless it can run under mono).
You do realize this is illegal right?
marat569
Mon Jul 28, 2014 12:21 am
kusti8 wrote:The raspberry pi is not 32 bit or 64 bit. It uses the armv6 and unless you have the source code, from git or somewhere, there is no way to run it on the pi (unless it can run under mono).
Edit: just looked and seems like the git page has been taken down. You do realize this is illegal right?
I can compile it as I have the source, what command line for grunt would I need to compile it for ARM?
It's not illegal ;)
marat569
Mon Jul 28, 2014 12:24 am
The program is compiled via grunt build, but what commands should i add so i can build it for Rasbian?
kusti8
Mon Jul 28, 2014 12:29 am
Look at this page for info: https://github.com/popcorn-time/popcorn ... /README.md and you will need npm also.
At least in the us, it is illegal.
marat569
Mon Jul 28, 2014 12:31 am
kusti8 wrote:
Look at this page for info: and you will need npm also.
I use it to stream personal torrents (That are not illegal) and I know how to build it for windows and I have all the requirements on my windows machine to build and cross compile, I just cant find the argument for grunt to build it for arm.
I can make a torrent file of a movie on my pc and copy the magnet into popcorn time and it will stream, so as long as I stream personal media files, it is not illegal.
kusti8
Mon Jul 28, 2014 12:35 am
It is much easier to do the work on the raspberry pi. I personally have never cross compiled and find it easier to do it all on the pi. As for the illegal part, sorry, I misunderstood. :oops:
marat569
Mon Jul 28, 2014 12:37 am
kusti8 wrote:It is much easier to do the work on the raspberry pi. I personally have never cross compiled and find it easier to do it all on the pi. As for the illegal part, sorry, I misunderstood. :oops:
I've been googling and it's an issue with nodewebkit and stuff
I realized why not get xmbc, but when I do apt-get install xmbc I get an error saying that a dependency was removed :(
Mon Jul 28, 2014 6:16 am
If you want XBMC then use OpenElec or Raspbmc distro's
RPi 4B 4GB (SSD Boot)..
poseidonsg
Fri Mar 27, 2015 7:27 pm
I was wondering if it is possible for you try some other similar fork of popcorntime.io. There are many similar site like popcorntime which are based on same code base and are available for free download. Try those
djole94hns
Sat Mar 28, 2015 1:07 am
If I remember correctly, Kodi has popcorntime in it's programs section for download and install. I could be wrong, though.
