hayloiuy
How to Send Location to Raspberry Pi
Tue Jul 22, 2014 3:08 pm
Hi guys,
I am trying to start a project where a user will wear a small transmitter and that transmitter will transmit a signal at a specific interval. Then based on the signal, Raspberry will determine the location of the person and save it in a file to be analyzed later to determine the path taken by the user.
In other words, I am trying to track someone's movement using Raspberry.
I have no electronics background. My questions are:
What transmitter is needed for the user? I have zero knowledge on this and it would be good if someone can point me in a direction.
Is there already such a project so that I can leverage the source code?
FLYFISH TECHNOLOGIES
Re: How to Send Location to Raspberry Pi
Tue Jul 22, 2014 3:14 pm
hayloiuy wrote:I am trying to start a project where a user will wear a small transmitter and that transmitter will transmit a signal at a specific interval.
What is the content of the signal ? Does it include location information or is just a "ping" signal ?
hayloiuy wrote:I have zero knowledge on this and it would be good if someone can point me in a direction.
<censored> :roll:
Best wishes, Ivan Zilic.
Running out of GPIO pins and/or need to read analog values?
Solution: http://www.flyfish-tech.com/FF32
RaTTuS
Contact: Twitter YouTube
Tue Jul 22, 2014 3:15 pm
in doors ?
out doors ?
how far from the RPI ?
wireless ?
use several RPi's and triangulate
or
use a gps module on the person
Covfefe
hayloiuy
Wed Jul 23, 2014 2:08 pm
FLYFISH TECHNOLOGIES wrote: <censored> :roll:
The exact elitist attitude that shuns lay men trying to learn programming.
I was thinking of using something simple to be wear on the user to track it's movement. So yeah, if a ping can determine a location, how can it be done?
hayloiuy
Wed Jul 23, 2014 2:11 pm
RaTTuS wrote:in doors ?
out doors ?
wireless ?
or
Outdoors, the RPI will be tracking the movement of someone running around a basketball court. It will definitely has to be wireless.
I really really appreciate your advice.
BMS Doug
Wed Jul 23, 2014 2:33 pm
Ivan's comment was based on the information content of your query, you didn't give enough detail about what you want to do before stating that you know nothing about the subject. If you (as the author of the post) don't describe what you want to do then how can anyone give you advice on how to achieve it?
Ivan is often very helpful, provided you do basic research and describe the issue you wish to resolve.
Doug.
Building Management Systems Engineer.
BMS Doug
Wed Jul 23, 2014 2:49 pm
out doors ?
wireless ?
or
for basketball court scale distances the GPS probably wouldn't be accurate enough, but you should be able to do something with an array of receivers and triangulate from that.
Doug.
Douglas6
Wed Jul 23, 2014 4:29 pm
Perhaps this project will give you some ideas: https://learn.adafruit.com/gps-logging- ... s/overview
ame
Thu Jul 24, 2014 10:59 am
It's more realistic than elitist. Please report on your learning progress every month. After a year you might have some prototype working, although I expect you'll give up before then.
Like this, for example:
http://coecsl.ece.illinois.edu/ge423/sp ... sonic.html
Or you could try it optically. Make the user wear a brightly coloured hat and use OpenCV to detect the coloured object in the view of the entire court.
Cancelor
Thu Jul 24, 2014 12:13 pm
<censored> :roll:
I took this to mean 'don't run before you can walk'
Can't find the thread you want? Try googling : YourSearchHere site:raspberrypi.org
BMS Doug
Fri Jul 25, 2014 2:38 pm
Cancelor wrote:<censored> :roll:
I took it to mean "you are asking for help with something but haven't described what you want to do. How can I provide help if you don't define what you want help with?"
Doug.
