homercole
Configure wifi
Sun Jul 20, 2014 2:28 pm
Hi.
I'm a newbie in Raspberry, so I need your help. I have read many tutorial about wifi configuration, but all that stuff has confused me. So, I'd like to know only 2 things. 1, I want configure wifi. 2, I want connect automatically raspberry to my wifi connection. Maybe you have read this question many times, but my researches on google confused me.
Re: Configure wifi
Sun Jul 20, 2014 3:06 pm
If you are using Raspbian Wheezy
On the Desktop is the Wireless Icon, that is used to configure your WiFi, once configured it will be remembered
http://thepihut.com/pages/how-to-setup- ... i-raspbian
Obviously that is assuming that your Wiresless USB Adaptor has been correctly identified
RPi 4B 4GB (SSD Boot)..
homercole
Re: Configure wifi
Sun Jul 20, 2014 3:15 pm
Thanks for your answer, but I have discovered that my usb keyboard doesen't work, so I need to configure wifi from command line, but I don't know how to do.
kusti8
Re: Configure wifi
Sun Jul 20, 2014 4:23 pm
What type of encryption is your network (WEP, WPA/WPA2 PSK or Enterprise)? First, check that the following lines are in /etc/network/interfaces by doing:
sudo nano /etc/network/interfaces
And then checking the following exists and add it if it does not:
allow-hotplug wlan0
iface wlan0 inet dhcp
wpa-conf /etc/wpa_supplicant/wpa_supplicant.conf
iface default inet dhcp
Then open /etc/wpa_supplicant/wpa_supplicant.conf and add the following lines:
update_config=1
network={
ssid="YOURSSID"
psk="YOURPASSWORD"
# Protocol type can be: RSN (for WP2) and WPA (for WPA1)
proto=WPA
# Key management type can be: WPA-PSK or WPA-EAP (Pre-Shared or Enterprise)
key_mgmt=WPA-PSK
# Pairwise can be CCMP or TKIP (for WPA2 or WPA1)
pairwise=TKIP
#Authorization option should be OPEN for both WPA1/WPA2 (in less commonly used are SHARED and LEAP)
auth_alg=OPEN
Reboot your pi
Hope this helps!
MrEngman
Re: Configure wifi
Sun Jul 20, 2014 6:29 pm
homercole wrote:Hi.
Some information about your wifi adaptor and the operating system you are using would be useful. Makes life a little easier for people willing to help rather than just guessing what your problem may be.
Can you post the output of command uname -a, which shows some details about the OS, command lsusb which shows info about your USB devices, which should include your wifi adaptor provided it is connected to the Pi of course, and command cat /etc/network/interfaces which shows your basic wifi set up.
MrEngman
homercole
Re: Configure wifi
Sun Jul 20, 2014 7:39 pm
So, the output:
uname -a
Linux raspberrypi 3.12.22+ #691 PREEMPT Wed Jun 18 18:29:58 BST 2014 armv6l GNU/Linux
lsusb
Bus 001 Device 002: ID 0424:9512 Standard Microsystems Corp.
Bus 001 Device 003: ID 0424:ec00 Standard Microsystems Corp.
auto lo
iface lo inet loopback
#auto eth0
iface eth0 inet dhcp
auto wlan0
allow-hotplug wlan0
kusti8 wrote:What type of encryption is your network (WEP, WPA/WPA2 PSK or Enterprise)?
WPA/WPA2 PSK.
I've tried your code, but it doesen't work
Thanks for your patience
drgeoff
Re: Configure wifi
Sun Jul 20, 2014 7:45 pm
lsusb says you have no Wi-Fi adaptor plugged in. :(
You said earlier that your USB keyboard is not working. How are you typing commands into the RPi?
asandford
Re: Configure wifi
Sun Jul 20, 2014 8:43 pm
As an alternative to using /etc/wpa_supplicant/wpa_supplicant.conf:
[once your wifi adapter is recognised]
Edit (as root) /etc/network/interfaces to resemble this:
auto lo
allow-hotplug wlan0
wpa-ssid <YourWlanSSID> <--change to an appropriate value, no quotes required (might do if you use spaces)
wpa-psk <YourPassword> <--change to an appropriate value, no quotes required (might do if you use spaces)
#wpa-roam /etc/wpa_supplicant/wpa_supplicant.conf
Then type (they might throw errors):
ifdown wlan0
ifup wlan0
Then type:
ifconfig wlan0
wlan0     Link encap:Ethernet  HWaddr 80:1f:02:xx:xx:xx
          inet addr:192.168.0.121  Bcast:192.168.0.255  Mask:255.255.255.0
          UP BROADCAST RUNNING MULTICAST  MTU:1500  Metric:1
          RX packets:783 errors:0 dropped:3 overruns:0 frame:0
          TX packets:355 errors:0 dropped:1 overruns:0 carrier:0
          collisions:0 txqueuelen:1000
          RX bytes:128097 (125.0 KiB)  TX bytes:52903 (51.6 KiB)
kusti8
Re: Configure wifi
Sun Jul 20, 2014 9:27 pm
Try using a powered hub if you are not already. That sometimes solves it.
Re: Configure wifi
Sun Jul 20, 2014 9:40 pm
homercole wrote:Thanks for your answer, but I have discovered that my usb keyboard doesen't work, so I need to configure wifi from command line, but I don't know how to do.
If the USB Keyboard does not work are you actually accessing the Pi via SSH ?
java
Re: Configure wifi
Mon Jul 21, 2014 3:13 pm
The output of "lsusb" posted, does not show any USB devices connected to your RPi. So either, there are no devices connected to your USB ports on your RPi, or, the device is defective and not functioning, or, the output is not from your RPi ... , that is how I see it ...
homercole
Re: Configure wifi
Tue Jul 22, 2014 5:29 pm
I changed wifi adaptor and now raspberry recognize it.
asandford wrote:As an alternative to using /etc/wpa_supplicant/wpa_supplicant.conf:
auto lo
allow-hotplug wlan0
ifdown wlan0
ifup wlan0
Then type:
ifconfig wlan0
I've tried your code but it doesen't work.
This is output of command that you suggested:
pi@raspberrypi ~ $ sudo ifdown wlan0
Internet Systems Consortium DHCP Client 4.2.2
Copyright 2004-2011 Internet Systems Consortium.
All rights reserved.
For info, please visit https://www.isc.org/software/dhcp/
Listening on LPF/wlan0/1c:af:f7:11:86:ba
Sending on   LPF/wlan0/1c:af:f7:11:86:ba
Sending on   Socket/fallback
DHCPRELEASE on wlan0 to 192.168.1.254 port 67
pi@raspberrypi ~ $ sudo ifup wlan0
DHCPDISCOVER on wlan0 to 255.255.255.255 port 67 interval 4
DHCPDISCOVER on wlan0 to 255.255.255.255 port 67 interval 10
DHCPDISCOVER on wlan0 to 255.255.255.255 port 67 interval 12
DHCPDISCOVER on wlan0 to 255.255.255.255 port 67 interval 7
DHCPDISCOVER on wlan0 to 255.255.255.255 port 67 interval 13
DHCPDISCOVER on wlan0 to 255.255.255.255 port 67 interval 5
No DHCPOFFERS received.
No working leases in persistent database - sleeping.
Yes
java
Re: Configure wifi
Tue Jul 22, 2014 6:32 pm
Hmmm .... , can you say if your keyboard and USB wi-fi dongle work/function when plugged into another computer?
That is the USB ports on your RPi might not be functioning, is your RPi a B+ version?
MrEngman
Re: Configure wifi
Tue Jul 22, 2014 6:37 pm
homercole wrote:I changed wifi adaptor and now raspberry recognize it.
Yes
Well, still no idea what wifi adaptor you were trying to connect, however, from the MAC address, 1c:af:f7:11:86:ba, in the output of sudo ifup wlan0 above it appears to be a D-Link device.
An alternative to sudo ifup wlan0 is to use sudo ifup --force wlan0. And even if your wifi is not connected you can often check if it works or not using the command sudo iwlist wlan0 scan. This will get your wifi to scan for networks it could connect to, quite useful. If it doesn't work this is could indicate that the config, /etc/network/interfaces or whatever, is not quite right, although it could also mean PSU problems or other issues
MrEngman
homercole
Re: Configure wifi
Tue Jul 22, 2014 6:44 pm
java wrote:Hmmm .... , can you say if your keyboard and USB wi-fi dongle work/function when plugged into another computer?
No, my model is B.
I don't have a usb keyboard, but I've tried a wireless mouse and raspberry has recognized it. And I use the same wifi adaptor on my pc and it works fine.
homercole
Re: Configure wifi
Wed Jul 23, 2014 7:58 pm
Now the adaptor works!!!!! I don't know why, but yesterday the adaptor didn't work, today works.
Thanks for your help and pacience ;) ;) ;)
java
Re: Configure wifi
Thu Jul 24, 2014 6:23 am
Glad you got sorted ... :D
