tdenson
Remote access
Thu Jul 17, 2014 11:24 am
I manage a network in Kenya from the UK. I have a couple of Pis on the network sending me back information. Because of ISP restrictions I cannot use port forwarding and therefore cannot use remote control products like VNC. However, on my PCs and Macs I can happily use the likes of TeamViewer, Logmein and the Google Chrome remote desktop. Currently I have to do a double terminal connect to access the Pi (one remote, one local via a Windows 7 server). Is there any equivalent app for the Pi ?
tdenson
Re: Remote access
Thu Jul 17, 2014 11:30 am
After I posted that, I came across this posting in the forum -
"I recommend a solution based on OpenVPN. Run OpenVPN as client on your PRI and connect it to a OpenVPN server running in your home or office.
Once established VPN you will be able to connect with your RPI using ssh or vnc."
Do people generally agree this is the best solution, or is there a stand alone app that does it ?
Re: Remote access
Thu Jul 17, 2014 11:36 am
The only restriction on that is that you need port 1194 both TCP & UDP open and port forwarded on your home router. You also need the remote machine to be able to connect to the server's port 1194 without getting blocked by any firewall.
If that's not possible you can configure OpenVPN to use port 80 (so that it appears as http traffic as far as a network admin who controls a firewall is concerned). That is a bit of an ugly hack.
cpc464
Re: Remote access
Thu Jul 17, 2014 12:45 pm
Hi
Awesome stuff about managing a Kenyan network. It is difficult to know what your restrictions are exactly, as I am not quite clear on where the port forwarding is being limited. VNC can be run over an ssh tunnel very effectively. I have desktops on Linux systems behind a firewall in which only port 22 (ssh) is open. I use Putty to make a tunnel from my windows desktop to the target machine, and all traffic goes through port 22 (not the default port for VNC, 5900). Sorry if that's irrelevant.
Jim
Unix engineer since 1989
tdenson
Re: Remote access
Thu Jul 24, 2014 8:45 pm
cpc464 wrote:Hi
Jim
Thanks for this, sorry about the delay in response.
As I understand it Orange Kenya, the ISP I am using, reuse external IP addresses for multiple customers simultaneously. As a result there is not a unique destination to communicate with over ip.
I already use Putty to ssh to my Pi from my Windows 7 server machine. However I'm not sure I understand how to use it to create an ssh tunnel.
FTrevorGowen
Re: Remote access
Thu Jul 24, 2014 8:59 pm
tdenson wrote: ...
Is what I do here:
http://www.cpmspectrepi.webspace.virgin ... aspPi.html
of any help? (I'm not sure if it "quite fits" into your setup, since I'm running PuTTY on a Linux box in those examples. However, in the past**, IIRC, I used similar settings to remotely log into a "secure" Linux cluster from a Windows XP box)
Trev.
** before I retired.
mgutt
Re: Remote access
Fri Jul 25, 2014 9:09 pm
1.) LogMeIn has a working client for Raspberry Pi:
http://raspberrypi.stackexchange.com/q/10110/17815
This solves your problem if you're having enough budget.
2.) I'm having the same problem (and low budget) and I think about the following:
- install VNC on the RPI with autostart, so it connects to my pc without interaction
- let RPI check every 30 seconds the URL http://example.org/PleaseCallMe.txt
- if the URL is available RPI starts VNC (and connects to my PC)
What I need to know:
a) is it possible to setup VNC with an autostart connection?
b) is it possible to let VNC run only on port 80 and/or 443?
c) how to get/install such a script to check URL and start VNC?
EDIT: Hmm.. maybe it would be better to start an OpenVPN tunnel, instead of starting VNC. And kill the tunnel after the URL is not available anymore. I think this would be much more flexible and works with Port 443 only. What do you think?
Return to “Advanced users”
