Alt255 wrote:Hello all,
I was gifted with a c64 1802 monitor, I connected to the RaspPi but I can't seem to get the monitor to display. I tried all the rca ports in the back. There are three rows. First row is Yellow and White.
Second is Yellow, Red and White
Last Row is Black.
The Pi has booted to the login as I check via HDMI after a reboot. So is possible? As I said it was gifted, and I use to use a C64 in the day, and would love to get this monitor going.
The C64 has a (sort of) S-Video output, hence the many RCA connectors. The 1802 has composite input also.
At
http://gona.mactar.hu/Commodore/monitor ... rsion).pdf you ca find a manual.
Connect the Pi to the video inout (the left bottom one) and set the switch on the right to video.
Since you tried all RCA inputs, at least a monochrome picture should have appeared. So it looks you have the usual RCA RPi output problems, which many threads in this forum are about. RCA works fine, but it takes careful reading and following steps ot the letter. SFrom software HDMI is very well supported, composite support is eh, less, sophisticated (IMHO it needs a good overhaul).
Noobs, rasbpian? B, B+?
