SteveMilner
USB Hub Recommendations Please
Tue Jul 15, 2014 10:16 am
I need a powered hub to connect devices to the Pi.
I also need a hub that does not attempt to be bus powered if the power to the hub is lost, since that will cause the Pi to switch of due to lack of power.
Can anyone suggest a suitable hub please?
Regards,
Stephen
Re: USB Hub Recommendations Please
Tue Jul 15, 2014 10:53 am
SteveMilner
Tue Jul 15, 2014 11:11 am
Will run from bus-power in the absence of a power brick
Not what I want.
May do the trick, does anyone have one of these they can do a test with to see what happens when the power to the hub is removed?
This is a good list, but it doesn't answer the question I have directly.
I'm trying to avoid a trial and error loop purchasing and then testing USB hubs.
This one looks like it will do the trick though:
http://thepihut.com/products/7-port-usb ... spberry-pi
Steve
RaTTuS
Contact: Twitter YouTube
Tue Jul 15, 2014 11:15 am
Not what I want.
yes it is
you run that and power the RPI from it - it will not back power your RPi and will provide all the umph you need - get a decent PSU with it
Covfefe
SteveMilner
Tue Jul 15, 2014 11:20 am
RaTTuS wrote:
Not what I want.
yes it is
Sadly it isn't.
Firstly I do not want to supply power to the Pi from the hub. I have an adequate power supply solution for the Pi.
If the hub looses power it will switch to bus powered mode. At that point the Pi can't supply enough current to the hub and peripherals, so it will freeze/shut down.
I have an in car application and the Pi is using a battery backup board (UPiS). When the ignition is switched off the UPiS board signals the Pi so that it can shutdown cleanly.
I can't battery back up the Hub so when the ignition switches off the hub you suggest will switch to Bus Powered mode and the current drawn will shut down the Pi instantly risking file system corruption.
I need a hub that will only work with external power.
Steve
Tue Jul 15, 2014 11:30 am
Cut the red wire in the cable between your RPi and the hub.
SteveMilner
Tue Jul 15, 2014 11:32 am
DougieLawson wrote:Cut the red wire in the cable between your RPi and the hub.
I tried that with my existing hub. It seemed like the obvious answer.
I could have buggered the cable up of course, but once I did that the Hub & the Pi weren't talking at all.
Regards,
Stephen
RaTTuS
Tue Jul 15, 2014 11:33 am
Cut the red lead from the Hub to the RPi then it cannot back / bus power - this works for all hubs
but it may be cleaner to have the hub in the circuit behind the ignition switch, as you will not be wanting a PSU for th hub,
what have you got plugged into the hub to need more power anyway ?
Covfefe
SteveMilner
Tue Jul 15, 2014 11:38 am
It's a media server solution.
A hard drive is the main current source.
It also needs to be transportable since I need it move into other cars or my caravan.
I don't really want the hub constantly fed with power from the car thought. It will probably flatten the car battery within a few days.
Just had confirmation from the PiHut that this:
Is exactly what I need.
Happy days.
Steve
SteveMilner
Mon Jul 21, 2014 2:34 pm
SteveMilner wrote: Just had confirmation from the PiHut that this:
Happy Days
Sadly the days were not so happy when I tested this on Saturday.
I pulled the power out of the hub and the Pi then attempted to provide power to the hub & peripherals. This was too much for the Pi and it switched off :cry:
However, this time cutting the red wire between the Pi & the hub solved the problem (It didn't work with my old hub though) :D
Steve
SteveMilner
Mon Jul 21, 2014 3:01 pm
RaTTuS wrote:Cut the red lead from the Hub to the RPi then it cannot back / bus power - this works for all hubs
Actually my first hub I tested this resulted in the PI not recognising any USB devices at all were attached. The hub seemed to need the +ve supply from the Pi to work - even though it was externally powered.
