brocja01
Hexxeh Raspbian R3 GPG Error
Mon Jun 11, 2012 9:12 pm
Hey all, just downloaded Hexxeh's new Raspbian image and I'm having issues running apt-get update.
I get GPG errors on http://archive.raspbian.org wheezy InRelease stating that the file doesn't start with a clearsigned message.
I can't install anything without being able to do an update. Any help would be greatly appreciated. I'm over in the US, if that makes any difference.
Thanks,
JBro
plugwash
Re: Hexxeh Raspbian R3 GPG Error
Mon Jun 11, 2012 9:32 pm
The file looks fine to me.
Can you try running apt-get update again and if that fails can you post the exact error you are getting?
Also can you confim if you are using the main repo or one of the mirrors?
brocja01
Tue Jun 12, 2012 1:49 pm
root@raspbian:~# apt-get update
Get:1 http://archive.raspbian.org wheezy InRelease
Ign http://archive.raspbian.org wheezy InRelease
Get:2 http://archive.raspbian.org wheezy/main Sources
99% [2 Sources xz 0 B] [Connecting to archive.raspbian.org (208.113.240.22)]/usr/bin/xz: (stdin): File format not recognized
Get:3 http://archive.raspbian.org wheezy/main armhf Packages
99% [3 Packages xz 0 B]/usr/bin/xz: (stdin): File format not recognized
Get:4 http://archive.raspbian.org wheezy/main TranslationIndex
Fetched 1,088 B in 1s (681 B/s)
W: GPG error: http://archive.raspbian.org wheezy InRelease: File /var/lib/apt/lists/partial/archive.raspbian.org_raspbian_dists_wheezy_InRelease doesn't start with a clearsigned message
W: Failed to fetch gzip:/var/lib/apt/lists/partial/archive.raspbian.org_raspbian_dists_wheezy_main_source_Sources Encountered a section with no Package: header
W: Failed to fetch gzip:/var/lib/apt/lists/partial/archive.raspbian.org_raspbian_dists_wheezy_main_binary-armhf_Packages Encountered a section with no Package: header
W: Failed to fetch http://archive.raspbian.org/raspbian/di ... i18n/Index No Hash entry in Release file /var/lib/apt/lists/partial/archive.raspbian.org_raspbian_dists_wheezy_main_i18n_Index
E: Some index files failed to download. They have been ignored, or old ones used instead.
This is the output I receive.
plugwash
Tue Jun 12, 2012 1:59 pm
can you manually download http://archive.raspbian.org/raspbian/di ... /InRelease using wget and inspect the contents of the file you receive?
brocja01
Tue Jun 12, 2012 2:40 pm
It was my work connection. Seems to be fixed now.
felpato
Tue Aug 28, 2012 1:28 pm
I have a similar problem but I don't think it was the connection:
pi@raspberrypi ~ $ sudo apt-get update
Get:1 http://archive.raspbian.org wheezy InRelease [2,256 B]
Get:2 http://archive.raspbian.org wheezy/main Sources [2,256 B]
Get:3 http://archive.raspberrypi.org wheezy InRelease [2,255 B]
Get:4 http://archive.raspbian.org wheezy/main armhf Packages [2,256 B]
Err http://archive.raspberrypi.org wheezy InRelease
Get:5 http://archive.raspbian.org wheezy/main Translation-en_GB [2,256 B]
Get:6 http://archive.raspbian.org wheezy/main Translation-en [2,255 B]
Fetched 13.5 kB in 7s (1,786 B/s)
Reading package lists... Done
W: A error occurred during the signature verification. The repository is not updated and the previous index files will be used. GPG error: http://archive.raspberrypi.org wheezy InRelease: File /var/lib/apt/lists/partial/archive.raspberrypi.org_debian_dists_wheezy_InRelease doesn't start with a clearsigned message
W: Failed to fetch http://archive.raspberrypi.org/debian/dists/wheezy/InRelease
W: Some index files failed to download. They have been ignored, or old ones used instead.
Infact if I do
ping www.google.it
I receive an answer...
plugwash
Tue Aug 28, 2012 3:30 pm
Firstly place try again, sometimes this sort of thing is caused simply by hitting a repo that is in the middle of being updated.
If it's stil broken can you try downloading http://archive.raspbian.org/raspbian/di ... /InRelease using wget and looking at the resulting file?
What kind of internet connection are you using?
felpato
Tue Aug 28, 2012 4:34 pm
I have tried again but it doesn't work again.
I've downloaded the file you said:
<!DOCTYPE html PUBLIC "-//W3C//DTD XHTML 1.0 Strict//EN" "http://www.w3.org/TR/xhtml1/DTD/xhtml1-strict.dtd">
<html xmlns="http://www.w3.org/1999/xhtml">
        <head>
                <meta http-equiv="content-type" content="text/html;charset=UTF-8" />
                <link rel='stylesheet' href='css/style.css' type='text/css' />
                <!--[if lt IE 7.]>
                   <script defer type='text/javascript' language='JavaScript'  src='js/pngfix.js'></script>
                <![endif]-->
                <!--[if IE]>
                <link rel='stylesheet' href='css/style_exp.css' type='text/css' />
                <![endif]-->
                <link rel='stylesheet' href='css/wizard.css' type='text/css' />
                <script language='JavaScript' src='jquery/jquery.js?ver=1.6' type='text/javascript'></script>
                <script language='JavaScript' src='jquery/jquery.ba-bbq.js' type='text/javascript'></script>
                <script language='JavaScript' src='jquery/jqSOAPClient.js' type='text/javascript'></script>
                <script src='main.cgi?js=rg_config.js' type='text/javascript'></script>
                <script language='Javascript' src='js/lang.js' type='text/javascript'></script>
                <script language='Javascript' src='main.cgi?page=dm_path.js' type='text/javascript'></script>
                <script language='JavaScript' src='js/utils.js' type='text/javascript'></script>
                <script language='JavaScript' src='js/wizard_levels.js' type='text/javascript'></script>
                <script language='JavaScript' src='js/sm.js' type='text/javascript'></script>
                <script language='JavaScript' src='js/wizard_painter.js' type='text/javascript'></script>
                <script language='JavaScript' src='js/wizard_states.js' type='text/javascript'></script>
                <script language='JavaScript' src='main.cgi?page=back_end.js' type='text/javascript'></script>
                <script language='JavaScript'>
                        $(document).ready(function(){
                            dashboard_init();
                </script>
        <script language='JavaScript'>var dm_cookie='502341566';</script></head>
        <body>
                <div id="logo"><div id="menu"></div></div>
                <div id="main">
                        <div id="title"></div>
                        <div id="content"><div id="center"></div><hr/>
                                <noscript>
                                    <h1>Per visualizzare correttamente la pagina richiesta clicca su abilita. Abilita - Blocca</h1>
                                </noscript>
                        </div>
                        <div id="bottom"></div>
                        <div id="footer"></div>
                </div>
        </body>
</html>
plugwash
Tue Aug 28, 2012 4:43 pm
I can pretty categorically state that the content you pasted did not come from our server.
It seems to me that something on your network is blocking your Pi's attempts to download stuff from our server.
felpato
Tue Aug 28, 2012 4:49 pm
My internet connection is DSL. (ISP Vodafone - Italy)
felpato
Tue Aug 28, 2012 4:52 pm
Ok.. Is there a specified port for this kind of request? Vodafone station firewalls some ports, but I can set firewall off..
felpato
Tue Aug 28, 2012 4:58 pm
I have tried wget http://archive.raspberrypi.org/debian/d ... /InRelease from my mac and the file downloaded is completely different...
RaspberryPI is connected through ethernet cable to Vodafone station (Router/AccessPoint/Gateway/ etc). My mac is connected through wifi to vodafone station again..I'm controlling raspberry through ssh from my mac..
plugwash
Tue Aug 28, 2012 4:59 pm
It should be standard http on port 80.
felpato
Tue Aug 28, 2012 5:05 pm
I was wrong: internet doesn't work on rasberrypi..
felpato
Tue Aug 28, 2012 5:34 pm
if I do
ping www.google.com
it works, but with wget doesn't..
Seems that only port 80 is blocked but I think no firewall blocking port 80 exists..It won't make sense.
plugwash
Tue Aug 28, 2012 8:26 pm
Can you actually try running a web browser on the Pi? it seems to me that the router is trying to hijack the session to ask you something....
Unfortunately i'm not sure if hexxeh R3 includes a browser by default or not which may leave you with a bit of a chicken and egg problem :(
felpato
Wed Aug 29, 2012 1:37 pm
SOLVED!
As you said, vodafone station wanted to tell me to download its own app for configuration. I have downloaded the app but not installed. Then it worked :)
avolag
Sat Mar 02, 2013 2:33 pm
Dear Felpato,
I have tha same your staff=
1) RaspberryPI connected through ethernet cable to Vodafone station through TP Link power line adapter
2) mac connected through wifi to vodafone station
3) I'm also controlling raspberry through ssh from my mac
but I really did not understand how you solved the problem. If you can better explain me I really appreciate (anche in italiano ...).
Thanks in advance
avolag
Tue Mar 05, 2013 5:27 pm
SOLVED the problem of the GPG error on the first internet access with Vodafone station 2 router
Open the graphical interface with startx
Open Midora browser
You will find the vodafone app download page
Just download the linux version of the app
sacdallago
Sun Feb 15, 2015 1:27 pm
Hi to everyone!
I also had this problem and since I'm running KODI/XBMC I didn't really want to lose time trying to install another desktop environment.
Solved it connecting to my rasp via SSH using the -D option (
ssh user@rasp -D 1234
), then fired up Firefox from my mac and set the socks proxy to localhost and port 1234, "donwloaded" the vodafone software and now everything is up & running!
Hate Vodafone everyday a little more...
Cheers guys
Return to “Raspberry Pi OS”
