How do I convert a linux driver to run on the Raspberry Pi
I have a ZTE modem which came with a linux driver for installation on Linux how can I convert it and make it run on my raspberry pi?
Re: How do I convert a linux driver to run on the Raspberry
ZTE Modem is it USB ? is it for 3G ? then the driver disk is useless for the Pi.
Assuming it is a USB 3G Modem and you have Raspbian Wheezy installed, then plug in the Modem and power on the Pi.
Open up LXTerminal type in lsusb press enter and post the output.
The information is out there....you just have to let it in.
It displays
Bus 001 Device 008: ID 19d2:ffeb ZTE WCDMA Technologies MSM
http://myhowtosandprojects.blogspot.co. ... linux.htmlkene.dozie wrote:It displays
If it is a 3G driver:
sudo apt-get update; sudo apt-get -y install ppp
wget "https://raspberry-at-home.com/files/sakis3g.tar.gz"
sudo mkdir /usr/bin/modem3g
sudo chmod 777 /usr/bin/modem3g
I have tried that previously, when I use the sakis3g method it returns an error after detecting the modem.
When I use the wvdial method it does not see the network on the modem.
Is the ZTE Modem recognised by Linux as a Modem or a Storage Device, that was mentioned in the link I posted ??kene.dozie wrote:I have tried that previously, when I use the sakis3g method it returns an error after detecting the modem.
Start the Pi, then plug in the modem, type "dmesg" and look at the last messages, that should give you an Idea if the modem is recognized properly.
When I typed in 'dmesg' it displayed
Usb 1-1.3: Product: Qualcomm CDMA Technologies
And thats all ??
I am sorry everyone I was away from my pi for these few days.
But I'm back
When I used dmesg it displays:
[ 3.945748] usb 1-1.3: Product: Qualcomm CDMA Technologies MSM
[ 3.966265] usb 1-1.3: Manufacturer: Qualcomm, Incorporated
[ 4.098454] usb 1-1.2.1: new full-speed USB device number 7 using dwc_otg
[ 4.246573] usb 1-1.2.1: New USB device found, idVendor=046d, idProduct=c52b
[ 4.268253] usb 1-1.2.1: New USB device strings: Mfr=1, Product=2, SerialNumber=0
it displays towards the end:
[ 9.012661] usbserial: USB Serial support registered for generic
[ 9.122279] usbcore: registered new interface driver zte_ev
[ 9.191954] usbserial: USB Serial support registered for zte_ev
[ 9.277885] zte_ev 1-1.3:1.0: zte_ev converter detected
[ 9.343641] usb 1-1.3: zte_ev converter now attached to ttyUSB0
[ 9.448368] zte_ev 1-1.3:1.1: zte_ev converter detected
[ 9.507542] usb 1-1.3: zte_ev converter now attached to ttyUSB1
[ 9.528379] zte_ev 1-1.3:1.2: zte_ev converter detected
[ 9.574636] usb 1-1.3: zte_ev converter now attached to ttyUSB2
[ 9.608363] zte_ev 1-1.3:1.3: zte_ev converter detected
[ 9.659271] usb 1-1.3: zte_ev converter now attached to ttyUSB3
So I think the Rpi is not detecting the ZTE device as modem yet.
But I'm back
- DougieLawson
- Location: A small cave in deepest darkest Basingstoke, UK
- Contact: Website Twitter
I think you need to look at the power supply for your USB modem.
It connects, initialises then fails, reconnects, re-initialises and loops doing that.
Ok thanks I will try that.
After connecting it to external power, and suing the commang "dmesg"
it gives:
[ 119.670844] usb 1-1.3: new high-speed USB device number 7 using dwc_otg
[ 119.772698] usb 1-1.3: New USB device found, idVendor=19d2, idProduct=ffeb
[ 119.772733] usb 1-1.3: New USB device strings: Mfr=3, Product=2, SerialNumber=0
[ 119.772750] usb 1-1.3: Product: Qualcomm CDMA Technologies MSM
[ 119.772766] usb 1-1.3: Manufacturer: Qualcomm, Incorporated
[ 120.076621] usbcore: registered new interface driver usbserial
[ 120.076803] usbcore: registered new interface driver usbserial_generic
[ 120.076920] usbserial: USB Serial support registered for generic
[ 120.115991] usbcore: registered new interface driver zte_ev
[ 120.116123] usbserial: USB Serial support registered for zte_ev
[ 120.116217] zte_ev 1-1.3:1.0: zte_ev converter detected
[ 120.141705] usb 1-1.3: zte_ev converter now attached to ttyUSB0
[ 120.142294] zte_ev 1-1.3:1.1: zte_ev converter detected
[ 120.153253] usb 1-1.3: zte_ev converter now attached to ttyUSB1
[ 120.155972] zte_ev 1-1.3:1.2: zte_ev converter detected
[ 120.172659] usb 1-1.3: zte_ev converter now attached to ttyUSB2
[ 120.172878] zte_ev 1-1.3:1.3: zte_ev converter detected
[ 120.176852] usb 1-1.3: zte_ev converter now attached to ttyUSB3
[ 276.259130] zte_ev ttyUSB3: zte_ev converter now disconnected from ttyUSB3
[ 276.259285] zte_ev 1-1.3:1.3: device disconnected
[ 276.707984] usbserial: USB Serial deregistering driver zte_ev
[ 276.712587] zte_ev ttyUSB2: zte_ev converter now disconnected from ttyUSB2
[ 276.713042] zte_ev ttyUSB1: zte_ev converter now disconnected from ttyUSB1
[ 276.716634] zte_ev ttyUSB0: zte_ev converter now disconnected from ttyUSB0
[ 276.716734] usbcore: deregistering interface driver zte_ev
[ 276.716901] zte_ev 1-1.3:1.2: device disconnected
[ 276.717128] zte_ev 1-1.3:1.1: device disconnected
[ 276.717283] zte_ev 1-1.3:1.0: device disconnected
[ 276.717886] usbserial: USB Serial deregistering driver generic
[ 276.718005] usbcore: deregistering interface driver usbserial_generic
[ 276.718088] usbcore: deregistering interface driver usbserial
[ 277.397740] usbcore: registered new interface driver usbserial
[ 277.397865] usbcore: registered new interface driver usbserial_generic
[ 277.397972] usbserial: USB Serial support registered for generic
[ 277.420917] usbcore: registered new interface driver option
[ 277.421127] usbserial: USB Serial support registered for GSM modem (1-port)
[ 277.858385] option 1-1.3:1.0: GSM modem (1-port) converter detected
[ 277.862035] usb 1-1.3: GSM modem (1-port) converter now attached to ttyUSB0
[ 277.876101] option 1-1.3:1.1: GSM modem (1-port) converter detected
[ 277.876680] usb 1-1.3: GSM modem (1-port) converter now attached to ttyUSB1
[ 277.877432] option 1-1.3:1.2: GSM modem (1-port) converter detected
[ 277.877962] usb 1-1.3: GSM modem (1-port) converter now attached to ttyUSB2
[ 277.878586] option 1-1.3:1.3: GSM modem (1-port) converter detected
[ 277.886776] usb 1-1.3: GSM modem (1-port) converter now attached to ttyUSB3
so what do you think?
it gives:
- DougieLawson
Ah, the extra log shows more. That one dongle appears as four /dev/ttyUSBn devices. What happens when you try to write data to those?
What do you mean by write data to it?
- DougieLawson
Everything on Unix is seen as a file. The normal operations on files are open(), write(), read() & close().kene.dozie wrote:What do you mean by write data to it?
The device is appearing as four /dev files so you now need a program to send some data and read some results.
Ok. so do you know how this can be done?
Now that the dmesg output looks more promising (thanks to the better power supply) try the sakis3g method again... and/or look at https://google.com/search?q=raspberry+pi+usb+3g+modem
- DougieLawson
It claims to be a modem. Therefore something like stty to set baud rates and parms then minicom to do the communications with the outside world.
Thanks Andrew, I have tried that method but it gives an error messageAndrewS wrote:Now that the dmesg output looks more promising (thanks to the better power supply) try the sakis3g method again... and/or look at https://google.com/search?q=raspberry+pi+usb+3g+modem
How can I use the stty and minicom?DougieLawson wrote:It claims to be a modem. Therefore something like stty to set baud rates and parms then minicom to do the communications with the outside world.
You best bet would be to read up on those application - Google is your friend. You'll need a basic understanding of what they do to be able to use them anyway, rather than just blindly following instruction people may put on here which might make something work, but won't help towards your final target.kene.dozie wrote:How can I use the stty and minicom?DougieLawson wrote:It claims to be a modem. Therefore something like stty to set baud rates and parms then minicom to do the communications with the outside world.
http://www.linux-tutorial.info/modules. ... nicom.html
Just remember that your devices is called ttyUSB0 (1,2,3).
Typically commands I would test with in minicom is:
at
ate1v1
ati
( first should return "OK" or "0", second turns on echoiing of characters and text replys, third prints some text about the modem. )
at
ate1v1
ati
