nancy
Raspberry pi and PN532 NFC breakout board
Mon Jul 07, 2014 11:15 am
I am a newbie to raspberry pi and i want to read the nfc tag with the nfc reader connected to raspberry pi.
I bought the below PN532 NFC breakout board from adafruit:
http://www.adafruit.com/products/364
I have a tag which contains some information. How i can read this tag info stored in it with the help of reader and pi?
Kind Regards
Nancy
joan
Re: Raspberry pi and PN532 NFC breakout board
Mon Jul 07, 2014 11:27 am
Not easily at the moment.
It looks like you'll need to follow this tutorial.
https://learn.adafruit.com/adafruit-nfc ... spberry-pi
nancy
Mon Jul 07, 2014 11:44 am
Hi Joan,
Thanks for the reply.
I already went through with this tutorial and getting the tag ID as a result. But now i want if i stored name in the tag then how that name is read and shown on the console??
Secondly I want two nfc reader connecected to the same pi, then how the pi will know which reader is reading the data?
Regards
Nancy
rpdom
Tue Nov 18, 2014 10:37 am
mikeeugine wrote:raspberry pi nfc board: http://www.elecfreaks.com/store/nfcrfid ... p-519.html
That module appears to require a 5v interface. It will require a level converter to connect it to the Pi unless you can bypass/disable the on-board level converter and access it at the IC's native 3.3v signal level.
