Can anyone tell me why this is happening?
For 500 data points plotted 1000 times "./HSDMPi 1000 500 For 505 data points plotted 1000 times "./HSDMPi 1000 505 For 2000 data points plotted 1000 times "./HSDMPi 1000 2000 My source code is below.
// HSDMPi
// Jonathan Olson (olso4539@umn.edu)
#include <stdio.h>
#include <stdlib.h>
#include <assert.h>
#include <time.h>
//#include <string.h>
//#include <unistd.h>
//#include <bcm_host.h>
//#include <vgfont.h>
#include "VG/openvg.h"
#include "VG/vgu.h"
#include "EGL/egl.h"
#include "GLES/gl.h"
typedef struct {
uint32_t screen_width;
uint32_t screen_height;
// OpenGL|ES objects
EGLDisplay display;
EGLSurface surface;
EGLContext context;
} STATE_T;
static void exit_func(void);
static STATE_T _state, *state=&_state;
// init_ogl sets the display, OpenGL|ES context and screen information
// state holds the OGLES model information
static void init_ogl(STATE_T *state) {
int32_t success = 0;
EGLBoolean result;
EGLint num_config;
static EGL_DISPMANX_WINDOW_T nativewindow;
DISPMANX_ELEMENT_HANDLE_T dispman_element;
DISPMANX_DISPLAY_HANDLE_T dispman_display;
DISPMANX_UPDATE_HANDLE_T dispman_update;
VC_RECT_T dst_rect;
VC_RECT_T src_rect;
static const EGLint attribute_list[] = {
EGL_RED_SIZE, 8,
EGL_GREEN_SIZE, 8,
EGL_BLUE_SIZE, 8,
EGL_ALPHA_SIZE, 8,
EGL_SURFACE_TYPE, EGL_WINDOW_BIT,
EGL_NONE
EGLConfig config;
// get an EGL display connection
state->display = eglGetDisplay(EGL_DEFAULT_DISPLAY);
assert(state->display!=EGL_NO_DISPLAY);
// initialize the EGL display connection
result = eglInitialize(state->display, NULL, NULL);
assert(EGL_FALSE != result);
// bind OpenVG API
eglBindAPI(EGL_OPENVG_API);
// get an appropriate EGL frame buffer configuration
result = eglChooseConfig(state->display, attribute_list, &config, 1, &num_config);
// create an EGL rendering context
state->context = eglCreateContext(state->display, config, EGL_NO_CONTEXT, NULL);
assert(state->context!=EGL_NO_CONTEXT);
// create an EGL window surface
success = graphics_get_display_size(0 /* LCD */, &state->screen_width, &state->screen_height);
assert( success >= 0 );
dst_rect.x = 0;
dst_rect.y = 0;
dst_rect.width = state->screen_width;
dst_rect.height = state->screen_height;
src_rect.x = 0;
src_rect.y = 0;
src_rect.width = state->screen_width << 16;
src_rect.height = state->screen_height << 16;
dispman_display = vc_dispmanx_display_open( 0 /* LCD */);
dispman_update = vc_dispmanx_update_start( 0 );
dispman_element = vc_dispmanx_element_add ( dispman_update, dispman_display, 0/*layer*/, &dst_rect, 0/*src*/, &src_rect, DISPMANX_PROTECTION_NONE, 0 /*alpha*/, 0/*clamp*/, 0/*transform*/);
nativewindow.element = dispman_element;
nativewindow.width = state->screen_width;
nativewindow.height = state->screen_height;
vc_dispmanx_update_submit_sync( dispman_update );
state->surface = eglCreateWindowSurface( state->display, config, &nativewindow, NULL );
assert(state->surface != EGL_NO_SURFACE);
// connect the context to the surface
result = eglMakeCurrent(state->display, state->surface, state->surface, state->context);
//DAVE - Set up screen ratio
glViewport(0, 0, (GLsizei)state->screen_width, (GLsizei)state->screen_height);
glMatrixMode(GL_PROJECTION);
glLoadIdentity();
float ratio = (float)state->screen_width / (float)state->screen_height;
glFrustumf(-ratio, ratio, -1.0f, 1.0f, 1.0f, 10.0f);
// setfill sets the fill color
void setfill(float color[4]) {
VGPaint fillPaint = vgCreatePaint();
vgSetParameteri(fillPaint, VG_PAINT_TYPE, VG_PAINT_TYPE_COLOR);
vgSetParameterfv(fillPaint, VG_PAINT_COLOR, 4, color);
vgSetPaint(fillPaint, VG_FILL_PATH);
vgDestroyPaint(fillPaint);
// setstroke sets the stroke color and width
void setstroke(float color[4], float width) {
VGPaint strokePaint = vgCreatePaint();
vgSetParameteri(strokePaint, VG_PAINT_TYPE, VG_PAINT_TYPE_COLOR);
vgSetParameterfv(strokePaint, VG_PAINT_COLOR, 4, color);
vgSetPaint(strokePaint, VG_STROKE_PATH);
vgSetf(VG_STROKE_LINE_WIDTH, width);
vgSeti(VG_STROKE_CAP_STYLE, VG_CAP_BUTT);
vgSeti(VG_STROKE_JOIN_STYLE, VG_JOIN_MITER);
vgDestroyPaint(strokePaint);
// Start begins the picture, clearing a rectangluar region with a specified color
void Start(int width, int height, float fill[4]) {
vgSetfv(VG_CLEAR_COLOR, 4, fill);
vgClear(0, 0, width, height);
vgLoadIdentity();
// End checks for errors, and renders to the display
void End() {
assert(vgGetError() == VG_NO_ERROR);
eglSwapBuffers(state->display, state->surface);
assert(eglGetError() == EGL_SUCCESS);
// rshapes draws shapes (rect and ellipse) with random colors, strokes, and sizes.
void plot(int width, int height, int n, int p) {
float color1[4] = {0,0,1,1};
float color2[4] = {0,1,0,1};
float color3[4] = {0,1,1,1};
float color4[4] = {1,0,0,1};
float color5[4] = {1,0,1,1};
float color6[4] = {1,1,0,1};
float color7[4] = {1,1,1,1};
float color8[4] = {0.5,0.5,0.5,1};
float bgcolor[4] = {0,0,0,1};
int i,j;
int leftborder=width/10;
int plotwidth = width - leftborder;
int points=p;
float dp1[10000],dp2[10000],dp3[10000],dp4[10000],dp5[10000],dp6[10000],dp7[10000],dp8[10000];
if (points>5000) points=5000;
Start(width, height, bgcolor);
srand(time(NULL));
VGPath path1 = vgCreatePath(VG_PATH_FORMAT_STANDARD, VG_PATH_DATATYPE_F, 1.0f, 0.0f, 0, 0, VG_PATH_CAPABILITY_ALL);
VGPath path2 = vgCreatePath(VG_PATH_FORMAT_STANDARD, VG_PATH_DATATYPE_F, 1.0f, 0.0f, 0, 0, VG_PATH_CAPABILITY_ALL);
VGPath path3 = vgCreatePath(VG_PATH_FORMAT_STANDARD, VG_PATH_DATATYPE_F, 1.0f, 0.0f, 0, 0, VG_PATH_CAPABILITY_ALL);
VGPath path4 = vgCreatePath(VG_PATH_FORMAT_STANDARD, VG_PATH_DATATYPE_F, 1.0f, 0.0f, 0, 0, VG_PATH_CAPABILITY_ALL);
VGPath path5 = vgCreatePath(VG_PATH_FORMAT_STANDARD, VG_PATH_DATATYPE_F, 1.0f, 0.0f, 0, 0, VG_PATH_CAPABILITY_ALL);
VGPath path6 = vgCreatePath(VG_PATH_FORMAT_STANDARD, VG_PATH_DATATYPE_F, 1.0f, 0.0f, 0, 0, VG_PATH_CAPABILITY_ALL);
VGPath path7 = vgCreatePath(VG_PATH_FORMAT_STANDARD, VG_PATH_DATATYPE_F, 1.0f, 0.0f, 0, 0, VG_PATH_CAPABILITY_ALL);
VGPath path8 = vgCreatePath(VG_PATH_FORMAT_STANDARD, VG_PATH_DATATYPE_F, 1.0f, 0.0f, 0, 0, VG_PATH_CAPABILITY_ALL);
for (i=0;i<(2*points);i+=2) {
dp1[i]=dp2[i]=dp3[i]=dp4[i]=dp5[i]=dp6[i]=dp7[i]=dp8[i]=i/2.0*plotwidth/points+leftborder;
// printf("%f\n",dp1[i]);
for (j=0;j<n;++j) {
for (i=1;i<(2*points);i+=2) {
dp1[i]=(rand()%height)/9+height/9;
dp2[i]=(rand()%height)/9+2*height/9;
dp3[i]=(rand()%height)/9+3*height/9;
dp4[i]=(rand()%height)/9+4*height/9;
dp5[i]=(rand()%height)/9+5*height/9;
dp6[i]=(rand()%height)/9+6*height/9;
dp7[i]=(rand()%height)/9+7*height/9;
dp8[i]=(rand()%height)/9+8*height/9;
dp1[i]=(rand()%height)*8/9+height/9;
dp2[i]=(rand()%height)*8/9+height/9;
dp3[i]=(rand()%height)*8/9+height/9;
dp4[i]=(rand()%height)*8/9+height/9;
dp5[i]=(rand()%height)*8/9+height/9;
dp6[i]=(rand()%height)*8/9+height/9;
dp7[i]=(rand()%height)*8/9+height/9;
dp8[i]=(rand()%height)*8/9+height/9;
vguPolygon(path1,& dp1[0], points, 0);
vguPolygon(path2,& dp2[0], points, 0);
vguPolygon(path3,& dp3[0], points, 0);
vguPolygon(path4,& dp4[0], points, 0);
vguPolygon(path5,& dp5[0], points, 0);
vguPolygon(path6,& dp6[0], points, 0);
vguPolygon(path7,& dp7[0], points, 0);
vguPolygon(path8,& dp8[0], points, 0);
setstroke(color1, 1);
vgDrawPath(path1, VG_STROKE_PATH);
vgClearPath(path1,VG_PATH_CAPABILITY_ALL);
setstroke(color2, 1);
vgDrawPath(path2, VG_STROKE_PATH);
vgClearPath(path2,VG_PATH_CAPABILITY_ALL);
setstroke(color3, 1);
vgDrawPath(path3, VG_STROKE_PATH);
vgClearPath(path3,VG_PATH_CAPABILITY_ALL);
setstroke(color4, 1);
vgDrawPath(path4, VG_STROKE_PATH);
vgClearPath(path4,VG_PATH_CAPABILITY_ALL);
setstroke(color5, 1);
vgDrawPath(path5, VG_STROKE_PATH);
vgClearPath(path5,VG_PATH_CAPABILITY_ALL);
setstroke(color6, 1);
vgDrawPath(path6, VG_STROKE_PATH);
vgClearPath(path6,VG_PATH_CAPABILITY_ALL);
setstroke(color7, 1);
vgDrawPath(path7, VG_STROKE_PATH);
vgClearPath(path7,VG_PATH_CAPABILITY_ALL);
setstroke(color8, 1);
vgDrawPath(path8, VG_STROKE_PATH);
vgClearPath(path8,VG_PATH_CAPABILITY_ALL);
End();
printf("points %u ",points);
// exit_func cleans up
static void exit_func(void) {
// clear screen
glClear( GL_COLOR_BUFFER_BIT );
// Release OpenGL resources
eglMakeCurrent( state->display, EGL_NO_SURFACE, EGL_NO_SURFACE, EGL_NO_CONTEXT );
eglDestroySurface( state->display, state->surface );
eglDestroyContext( state->display, state->context );
eglTerminate( state->display );
// main initializes the system and shows the picture,
// exit and clean up when you hit [RETURN].
int main (int argc, char **argv) {
int w, h, n, p;
bcm_host_init();
memset( state, 0, sizeof( *state ) ); // clear application state
init_ogl(state); // Start OGLES
w = state->screen_width;
h = state->screen_height;
n = 1000;
p = 1000;
if (argc > 1) {
n = atoi(argv[1]);
if (argc > 2) {
p = atoi(argv[2]);
plot(w, h, n, p);
printf("n %u w %u h %u\n",n,w,h);
// while (getchar() != '\n') {
exit_func(); return 0;
