here are details of my system:
uname -a
Linux raspberrypi 3.10.32+ #6 PREEMPT Tue Apr 22 11:19:48 SGT 2014 armv6l GNU/Linux
lsmod
Module Size Used by
rndis_host 7032 0
cdc_ether 4721 1 rndis_host
stmpe_ts 3070 0
fb_ili9340 3139 0
fbtft_device 28788 0
fbtft 31153 2 fb_ili9340,fbtft_device
syscopyarea 3135 1 fbtft
sysfillrect 3301 1 fbtft
sysimgblt 2194 1 fbtft
fb_sys_fops 1403 1 fbtft
i2c_dev 5609 0
snd_bcm2835 15962 0
snd_pcm 82132 1 snd_bcm2835
snd_seq 53679 0
snd_seq_device 6473 1 snd_seq
snd_timer 20030 2 snd_pcm,snd_seq
snd 58921 5 snd_bcm2835,snd_timer,snd_pcm,snd_seq,snd_seq_device
snd_page_alloc 5132 1 snd_pcm
joydev 9072 0
leds_gpio 2118 0
led_class 3710 1 leds_gpio
evdev 9439 6
spi_bcm2708 7444 0
i2c_bcm2708 3939 0
ls /usr/share/X11/xorg.conf.d/
10-evdev.conf 50-synaptics.conf
sudo modprobe spi-bcm2708
sudo modprobe fbtft_device name=adafruitts
rotate=90
export FRAMEBUFFER=/dev/fb1
startx
Herewith Xorg.1.log
[ 2357.632]
X.Org X Server 1.12.4
Release Date: 2012-08-27
[ 2357.634] X Protocol Version 11, Revision 0
[ 2357.635] Build Operating System: Linux 3.2.0-2-mx5 armv7l Debian
[ 2357.636] Current Operating System: Linux raspberrypi 3.10.32+ #6 PREEMPT Tue Apr 22 11:19:48 SGT 2014 armv6l
[ 2357.637] Kernel command line: dma.dmachans=0x7f35 bcm2708_fb.fbwidth=1024 bcm2708_fb.fbheight=768 bcm2708.boardrev=0xe bcm2708.serial=0x953463a1 smsc95xx.macaddr=B8:27:EB:34:63:A1 sdhci-bcm2708.emmc_clock_freq=100000000 vc_mem.mem_base=0x1ec00000 vc_mem.mem_size=0x20000000 dwc_otg.lpm_enable=0 console=tty1 root=/dev/mmcblk0p2 rootfstype=ext4 elevator=deadline rootwait
[ 2357.649] Build Date: 18 December 2013 05:20:52PM
[ 2357.649] xorg-server 2:1.12.4-6+deb7u2 (Julien Cristau <jcristau@debian.org>)
[ 2357.650] Current version of pixman: 0.29.3
[ 2357.650] Before reporting problems, check http://wiki.x.org
to make sure that you have the latest version.
[ 2357.650] Markers: (--) probed, (**) from config file, (==) default setting,
(++) from command line, (!!) notice, (II) informational,
(WW) warning, (EE) error, (NI) not implemented, (??) unknown.
[ 2357.660] (==) Log file: "/var/log/Xorg.1.log", Time: Wed Jul 2 19:49:59 2014
[ 2357.662] (==) Using config directory: "/etc/X11/xorg.conf.d"
[ 2357.662] (==) Using system config directory "/usr/share/X11/xorg.conf.d"
[ 2357.664] (==) No Layout section. Using the first Screen section.
[ 2357.664] (==) No screen section available. Using defaults.
[ 2357.664] (**) |-->Screen "Default Screen Section" (0)
[ 2357.664] (**) | |-->Monitor "<default monitor>"
[ 2357.666] (==) No monitor specified for screen "Default Screen Section".
Using a default monitor configuration.
[ 2357.667] (==) Automatically adding devices
[ 2357.667] (==) Automatically enabling devices
[ 2357.667] (WW) The directory "/usr/share/fonts/X11/misc" does not exist.
[ 2357.667] Entry deleted from font path.
[ 2357.668] (WW) The directory "/usr/share/fonts/X11/cyrillic" does not exist.
[ 2357.668] Entry deleted from font path.
[ 2357.668] (WW) The directory "/usr/share/fonts/X11/100dpi/" does not exist.
[ 2357.668] (WW) The directory "/usr/share/fonts/X11/75dpi/" does not exist.
[ 2357.669] (WW) The directory "/usr/share/fonts/X11/100dpi" does not exist.
[ 2357.669] Entry deleted from font path.
[ 2357.669] (WW) The directory "/usr/share/fonts/X11/75dpi" does not exist.
[ 2357.669] (WW) The directory "/var/lib/defoma/x-ttcidfont-conf.d/dirs/TrueType" does not exist.
[ 2357.669] (==) FontPath set to:
/usr/share/fonts/X11/Type1,
built-ins
[ 2357.690] (==) ModulePath set to "/usr/lib/xorg/modules"
[ 2357.690] (II) The server relies on udev to provide the list of input devices.
If no devices become available, reconfigure udev or disable AutoAddDevices.
[ 2357.690] (II) Loader magic: 0x1aa7a8
[ 2357.690] (II) Module ABI versions:
[ 2357.690] X.Org ANSI C Emulation: 0.4
[ 2357.691] X.Org Video Driver: 12.1
[ 2357.691] X.Org XInput driver : 16.0
[ 2357.691] X.Org Server Extension : 6.0
[ 2357.691] (II) LoadModule: "extmod"
[ 2357.694] (II) Loading /usr/lib/xorg/modules/extensions/libextmod.so
[ 2357.697] (II) Module extmod: vendor="X.Org Foundation"
[ 2357.697] compiled for 1.12.4, module version = 1.0.0
[ 2357.698] Module class: X.Org Server Extension
[ 2357.698] ABI class: X.Org Server Extension, version 6.0
[ 2357.698] (II) Loading extension SELinux
[ 2357.698] (II) Loading extension MIT-SCREEN-SAVER
[ 2357.698] (II) Loading extension XFree86-VidModeExtension
[ 2357.698] (II) Loading extension XFree86-DGA
[ 2357.699] (II) Loading extension DPMS
[ 2357.699] (II) Loading extension XVideo
[ 2357.699] (II) Loading extension XVideo-MotionCompensation
[ 2357.699] (II) Loading extension X-Resource
[ 2357.699] (II) LoadModule: "dbe"
[ 2357.710] (II) Loading /usr/lib/xorg/modules/extensions/libdbe.so
[ 2357.712] (II) Module dbe: vendor="X.Org Foundation"
[ 2357.712] compiled for 1.12.4, module version = 1.0.0
[ 2357.712] Module class: X.Org Server Extension
[ 2357.712] ABI class: X.Org Server Extension, version 6.0
[ 2357.712] (II) Loading extension DOUBLE-BUFFER
[ 2357.713] (II) LoadModule: "glx"
[ 2357.714] (II) Loading /usr/lib/xorg/modules/extensions/libglx.so
[ 2357.715] (II) Module glx: vendor="X.Org Foundation"
[ 2357.715] compiled for 1.12.4, module version = 1.0.0
[ 2357.715] ABI class: X.Org Server Extension, version 6.0
[ 2357.716] (==) AIGLX enabled
[ 2357.716] (II) Loading extension GLX
[ 2357.716] (II) LoadModule: "record"
[ 2357.717] (II) Loading /usr/lib/xorg/modules/extensions/librecord.so
[ 2357.719] (II) Module record: vendor="X.Org Foundation"
[ 2357.719] compiled for 1.12.4, module version = 1.13.0
[ 2357.719] Module class: X.Org Server Extension
[ 2357.719] ABI class: X.Org Server Extension, version 6.0
[ 2357.719] (II) Loading extension RECORD
[ 2357.719] (II) LoadModule: "dri"
[ 2357.741] (II) Loading /usr/lib/xorg/modules/extensions/libdri.so
[ 2357.743] (II) Module dri: vendor="X.Org Foundation"
[ 2357.744] compiled for 1.12.4, module version = 1.0.0
[ 2357.744] ABI class: X.Org Server Extension, version 6.0
[ 2357.744] (II) Loading extension XFree86-DRI
[ 2357.744] (II) LoadModule: "dri2"
[ 2357.745] (II) Loading /usr/lib/xorg/modules/extensions/libdri2.so
[ 2357.746] (II) Module dri2: vendor="X.Org Foundation"
[ 2357.746] compiled for 1.12.4, module version = 1.2.0
[ 2357.747] ABI class: X.Org Server Extension, version 6.0
[ 2357.747] (II) Loading extension DRI2
[ 2357.747] (==) Matched fbdev as autoconfigured driver 0
[ 2357.747] (==) Assigned the driver to the xf86ConfigLayout
[ 2357.747] (II) LoadModule: "fbdev"
[ 2357.749] (II) Loading /usr/lib/xorg/modules/drivers/fbdev_drv.so
[ 2357.760] (II) Module fbdev: vendor="X.Org Foundation"
[ 2357.761] compiled for 1.12.1, module version = 0.4.2
[ 2357.761] ABI class: X.Org Video Driver, version 12.0
[ 2357.761] (II) FBDEV: driver for framebuffer: fbdev
[ 2357.761] (--) using VT number 8
[ 2357.810] (WW) Falling back to old probe method for fbdev
[ 2357.810] (II) Loading sub module "fbdevhw"
[ 2357.810] (II) LoadModule: "fbdevhw"
[ 2357.811] (II) Loading /usr/lib/xorg/modules/libfbdevhw.so
[ 2357.812] (II) Module fbdevhw: vendor="X.Org Foundation"
[ 2357.813] compiled for 1.12.4, module version = 0.0.2
[ 2357.813] ABI class: X.Org Video Driver, version 12.1
[ 2357.814] (II) FBDEV(0): using default device
[ 2357.814] (WW) VGA arbiter: cannot open kernel arbiter, no multi-card support
[ 2357.814] (II) FBDEV(0): Creating default Display subsection in Screen section
"Default Screen Section" for depth/fbbpp 16/16
[ 2357.814] (==) FBDEV(0): Depth 16, (==) framebuffer bpp 16
[ 2357.815] (==) FBDEV(0): RGB weight 565
[ 2357.815] (==) FBDEV(0): Default visual is TrueColor
[ 2357.815] (==) FBDEV(0): Using gamma correction (1.0, 1.0, 1.0)
[ 2357.815] (II) FBDEV(0): hardware: fb_ili9340 (video memory: 150kB)
[ 2357.816] (II) FBDEV(0): checking modes against framebuffer device...
[ 2357.816] (II) FBDEV(0): checking modes against monitor...
[ 2357.816] (--) FBDEV(0): Virtual size is 320x240 (pitch 320)
[ 2357.816] (**) FBDEV(0): Built-in mode "current"
[ 2357.816] (==) FBDEV(0): DPI set to (96, 96)
[ 2357.816] (II) Loading sub module "fb"
[ 2357.817] (II) LoadModule: "fb"
[ 2357.818] (II) Loading /usr/lib/xorg/modules/libfb.so
[ 2357.819] (II) Module fb: vendor="X.Org Foundation"
[ 2357.840] compiled for 1.12.4, module version = 1.0.0
[ 2357.840] ABI class: X.Org ANSI C Emulation, version 0.4
[ 2357.840] (**) FBDEV(0): using shadow framebuffer
[ 2357.841] (II) Loading sub module "shadow"
[ 2357.841] (II) LoadModule: "shadow"
[ 2357.842] (II) Loading /usr/lib/xorg/modules/libshadow.so
[ 2357.843] (II) Module shadow: vendor="X.Org Foundation"
[ 2357.843] compiled for 1.12.4, module version = 1.1.0
[ 2357.843] ABI class: X.Org ANSI C Emulation, version 0.4
[ 2357.844] (EE) FBDEV(0): FBIOBLANK: Invalid argument
[ 2357.846] (==) FBDEV(0): Backing store disabled
[ 2357.847] (==) FBDEV(0): DPMS enabled
[ 2357.847] (==) RandR enabled
[ 2357.847] (II) Initializing built-in extension Generic Event Extension
[ 2357.848] (II) Initializing built-in extension SHAPE
[ 2357.848] (II) Initializing built-in extension MIT-SHM
[ 2357.848] (II) Initializing built-in extension XInputExtension
[ 2357.848] (II) Initializing built-in extension XTEST
[ 2357.848] (II) Initializing built-in extension BIG-REQUESTS
[ 2357.848] (II) Initializing built-in extension SYNC
[ 2357.848] (II) Initializing built-in extension XKEYBOARD
[ 2357.848] (II) Initializing built-in extension XC-MISC
[ 2357.849] (II) Initializing built-in extension SECURITY
[ 2357.849] (II) Initializing built-in extension XINERAMA
[ 2357.849] (II) Initializing built-in extension XFIXES
[ 2357.849] (II) Initializing built-in extension RENDER
[ 2357.849] (II) Initializing built-in extension RANDR
[ 2357.849] (II) Initializing built-in extension COMPOSITE
[ 2357.849] (II) Initializing built-in extension DAMAGE
[ 2357.870] (II) SELinux: Disabled on system
[ 2358.033] (II) AIGLX: Screen 0 is not DRI2 capable
[ 2358.034] (II) AIGLX: Screen 0 is not DRI capable
[ 2358.034] (EE) AIGLX error: dlopen of /usr/lib/arm-linux-gnueabihf/dri/swrast_dri.so failed (/usr/lib/arm-linux-gnueabihf/dri/swrast_dri.so: cannot open shared object file: No such file or directory)
[ 2358.034] (EE) GLX: could not load software renderer
[ 2358.035] (II) GLX: no usable GL providers found for screen 0
[ 2358.347] (II) config/udev: Adding input device stmpe-ts (/dev/input/event2)
[ 2358.348] (**) stmpe-ts: Applying InputClass "evdev touchscreen catchall"
[ 2358.348] (**) stmpe-ts: Applying InputClass "calibration"
[ 2358.348] (II) LoadModule: "evdev"
[ 2358.350] (II) Loading /usr/lib/xorg/modules/input/evdev_drv.so
[ 2358.351] (II) Module evdev: vendor="X.Org Foundation"
[ 2358.351] compiled for 1.12.1, module version = 2.7.0
[ 2358.351] Module class: X.Org XInput Driver
[ 2358.351] ABI class: X.Org XInput driver, version 16.0
[ 2358.352] (II) Using input driver 'evdev' for 'stmpe-ts'
[ 2358.352] (**) stmpe-ts: always reports core events
[ 2358.352] (**) evdev: stmpe-ts: Device: "/dev/input/event2"
[ 2358.353] (--) evdev: stmpe-ts: Vendor 0 Product 0
[ 2358.353] (--) evdev: stmpe-ts: Found absolute axes
[ 2358.353] (--) evdev: stmpe-ts: Found x and y absolute axes
[ 2358.353] (--) evdev: stmpe-ts: Found absolute touchscreen
[ 2358.353] (**) Option "SwapAxes" "1"
[ 2358.353] (II) evdev: stmpe-ts: Configuring as touchscreen
[ 2358.354] (**) evdev: stmpe-ts: YAxisMapping: buttons 4 and 5
[ 2358.354] (**) evdev: stmpe-ts: EmulateWheelButton: 4, EmulateWheelInertia: 10, EmulateWheelTimeout: 200
[ 2358.354] (**) Option "config_info" "udev:/sys/devices/platform/bcm2708_spi.0/spi_master/spi0/spi0.1/stmpe-ts.0/input/input2/event2"
[ 2358.354] (II) XINPUT: Adding extended input device "stmpe-ts" (type: TOUCHSCREEN, id 6)
[ 2358.355] (II) evdev: stmpe-ts: initialized for absolute axes.
[ 2358.357] (**) stmpe-ts: (accel) keeping acceleration scheme 1
[ 2358.357] (**) stmpe-ts: (accel) acceleration profile 0
[ 2358.357] (**) stmpe-ts: (accel) acceleration factor: 2.000
[ 2358.357] (**) stmpe-ts: (accel) acceleration threshold: 4
[ 2358.360] (II) config/udev: Adding input device stmpe-ts (/dev/input/mouse1)
[ 2358.360] (**) stmpe-ts: Applying InputClass "calibration"
[ 2358.360] (II) No input driver specified, ignoring this device.
[ 2358.361] (II) This device may have been added with another device file.
[ 2358.364] (II) config/udev: Adding input device HID 04d9:2517 (/dev/input/event0)
[ 2358.364] (**) HID 04d9:2517: Applying InputClass "evdev keyboard catchall"
[ 2358.364] (II) Using input driver 'evdev' for 'HID 04d9:2517'
[ 2358.365] (**) HID 04d9:2517: always reports core events
[ 2358.365] (**) evdev: HID 04d9:2517: Device: "/dev/input/event0"
[ 2358.365] (--) evdev: HID 04d9:2517: Vendor 0x4d9 Product 0x2517
[ 2358.365] (--) evdev: HID 04d9:2517: Found keys
[ 2358.365] (II) evdev: HID 04d9:2517: Configuring as keyboard
[ 2358.366] (**) Option "config_info" "udev:/sys/devices/platform/bcm2708_usb/usb1/1-1/1-1.3/1-1.3:1.0/input/input0/event0"
[ 2358.366] (II) XINPUT: Adding extended input device "HID 04d9:2517" (type: KEYBOARD, id 7)
[ 2358.366] (**) Option "xkb_rules" "evdev"
[ 2358.366] (**) Option "xkb_model" "pc105"
[ 2358.366] (**) Option "xkb_layout" "gb"
[ 2358.586] (II) config/udev: Adding input device HID 04d9:2517 (/dev/input/event1)
[ 2358.587] (**) HID 04d9:2517: Applying InputClass "evdev pointer catchall"
[ 2358.587] (**) HID 04d9:2517: Applying InputClass "evdev keyboard catchall"
[ 2358.587] (II) Using input driver 'evdev' for 'HID 04d9:2517'
[ 2358.587] (**) HID 04d9:2517: always reports core events
[ 2358.587] (**) evdev: HID 04d9:2517: Device: "/dev/input/event1"
[ 2358.588] (--) evdev: HID 04d9:2517: Vendor 0x4d9 Product 0x2517
[ 2358.588] (--) evdev: HID 04d9:2517: Found 9 mouse buttons
[ 2358.588] (--) evdev: HID 04d9:2517: Found scroll wheel(s)
[ 2358.588] (--) evdev: HID 04d9:2517: Found relative axes
[ 2358.588] (--) evdev: HID 04d9:2517: Found x and y relative axes
[ 2358.589] (--) evdev: HID 04d9:2517: Found absolute axes
[ 2358.589] (II) evdev: HID 04d9:2517: Forcing absolute x/y axes to exist.
[ 2358.589] (--) evdev: HID 04d9:2517: Found keys
[ 2358.589] (II) evdev: HID 04d9:2517: Configuring as mouse
[ 2358.589] (II) evdev: HID 04d9:2517: Configuring as keyboard
[ 2358.589] (II) evdev: HID 04d9:2517: Adding scrollwheel support
[ 2358.589] (**) evdev: HID 04d9:2517: YAxisMapping: buttons 4 and 5
[ 2358.590] (**) evdev: HID 04d9:2517: EmulateWheelButton: 4, EmulateWheelInertia: 10, EmulateWheelTimeout: 200
[ 2358.590] (**) Option "config_info" "udev:/sys/devices/platform/bcm2708_usb/usb1/1-1/1-1.3/1-1.3:1.1/input/input1/event1"
[ 2358.590] (II) XINPUT: Adding extended input device "HID 04d9:2517" (type: KEYBOARD, id 8)
[ 2358.590] (**) Option "xkb_rules" "evdev"
[ 2358.591] (**) Option "xkb_model" "pc105"
[ 2358.591] (**) Option "xkb_layout" "gb"
[ 2358.593] (II) evdev: HID 04d9:2517: initialized for relative axes.
[ 2358.593] (WW) evdev: HID 04d9:2517: ignoring absolute axes.
[ 2358.594] (**) HID 04d9:2517: (accel) keeping acceleration scheme 1
[ 2358.595] (**) HID 04d9:2517: (accel) acceleration profile 0
[ 2358.595] (**) HID 04d9:2517: (accel) acceleration factor: 2.000
[ 2358.595] (**) HID 04d9:2517: (accel) acceleration threshold: 4
[ 2358.598] (II) config/udev: Adding input device HID 04d9:2517 (/dev/input/mouse0)
[ 2358.598] (II) No input driver specified, ignoring this device.
[ 2358.598] (II) This device may have been added with another device file.
[ 2358.638] (EE) FBDEV(0): FBIOBLANK: Invalid argument
[ 2358.659] (II) evdev: stmpe-ts: Close
[ 2358.660] (II) UnloadModule: "evdev"
[ 2358.660] (II) evdev: HID 04d9:2517: Close
[ 2358.661] (II) UnloadModule: "evdev"
[ 2358.661] (II) evdev: HID 04d9:2517: Close
[ 2358.712] Server terminated successfully (0). Closing log file.
Anyone with any ideas?
