I'm using debian 6, the standard recommended image with maximum RAM dedicated to system, not GFX card. And an HDMI cable.
I am unable to rotate my display (180 degrees). Arandr (GUI frontend to xrandr) shows my display, but all options for resolution and rotation grey'ed out.
Xrandr gives:
pi@raspberrypi:~$ DISPLAY=:0.0 xrandr -q
xrandr: Failed to get size of gamma for output default
Screen 0: minimum 1824 x 1104, current 1824 x 1104, maximum 1824 x 1104
default connected 1824x1104+0+0 0mm x 0mm
1824x1104 0.0* Code: Select all
pi@raspberrypi:~$ DISPLAY=:0.0 xrandr --output default --rotate inverted
xrandr: output default cannot use rotation "inverted" reflection "none"
