oliv93
Installing OpenCV on the RPi
Mon Jun 30, 2014 6:58 pm
I need to install OpenCV for a python project, so I've found this link :
http://robertcastle.com/2014/02/install ... pberry-pi/
Following the instructions, when I install dependencies I've got for the first line code of the page :
pi@raspberrypi ~ $ sudo apt-get -y install build-essential cmake cmake-curses-gui pkg-config libpng12-0 libpng12-dev libpng++-dev libpng3 libpnglite-dev zlib1g-dbg zlib1g zlib1g-dev pngtools libtiff4-dev libtiff4 libtiffxx0c2 libtiff-tools libeigen3-dev
Reading package lists... Done
Building dependency tree
build-essential is already the newest version.
cmake is already the newest version.
cmake-curses-gui is already the newest version.
libeigen3-dev is already the newest version.
libpng++-dev is already the newest version.
libpng12-0 is already the newest version.
libpng12-dev is already the newest version.
libpng3 is already the newest version.
libpnglite-dev is already the newest version.
libtiff-tools is already the newest version.
libtiff4 is already the newest version.
libtiff4-dev is already the newest version.
libtiffxx0c2 is already the newest version.
pkg-config is already the newest version.
pngtools is already the newest version.
zlib1g is already the newest version.
zlib1g-dbg is already the newest version.
zlib1g-dev is already the newest version.
You might want to run 'apt-get -f install' to correct these:
The following packages have unmet dependencies:
 libgtk-3-0 : Depends: libgtk-3-common (= 3.4.2-7) but 3.4.2-6 is to be installed
 libgtk-3-bin : Depends: libgtk-3-common (= 3.4.2-7) but 3.4.2-6 is to be installed
E: Unmet dependencies. Try 'apt-get -f install' with no packages (or specify a solution).
I go on the second line code of the page :
pi@raspberrypi ~ $ sudo apt-get -y install libjpeg8 libjpeg8-dev libjpeg8-dbg libjpeg-progs ffmpeg libavcodec-dev libavcodec53 libavformat53 libavformat-dev libgstreamer0.10-0-dbg libgstreamer0.10-0 libgstreamer0.10-dev libxine1-ffmpeg libxine-dev libxine1-bin libunicap2 libunicap2-dev swig libv4l-0 libv4l-dev python-numpy libpython2.6 python-dev python2.6-dev libgtk2.0-dev
libgstreamer0.10-0 is already the newest version.
libgstreamer0.10-0 set to manually installed.
libjpeg8 is already the newest version.
libjpeg8 set to manually installed.
libjpeg8-dev is already the newest version.
libjpeg8-dev set to manually installed.
python-numpy is already the newest version.
python-numpy set to manually installed.
 ffmpeg : Depends: libav-tools but it is not going to be installed
          Depends: libavdevice53 (>= 6:0.8.3-1~) but it is not going to be installed
          Depends: libavfilter2 (>= 6:0.8.3-1~) but it is not going to be installed
          Depends: libavutil51 (>= 6:0.8.3-1~) but it is not going to be installed
          Depends: libpostproc52 (>= 6:0.8.3-1~) but it is not going to be installed
          Depends: libswscale2 (>= 6:0.8.3-1~) but it is not going to be installed
 libavcodec-dev : Depends: libavutil-dev (= 6:0.8.10-1+rpi1) but it is not going to be installed
 libavcodec53 : Depends: libavutil51 (>= 6:0.8.3-1~) but it is not going to be installed
                Depends: libdirac-encoder0 but it is not going to be installed
                Depends: libgsm1 (>= 1.0.13) but it is not going to be installed
                Depends: libmp3lame0 but it is not going to be installed
                Depends: libschroedinger-1.0-0 (>= 1.0.0) but it is not going to be installed
                Depends: libspeex1 (>= 1.2~beta3-1) but it is not going to be installed
                Depends: libtheora0 (>= 1.0) but it is not going to be installed
                Depends: libva1 (> 1.0.15~) but it is not going to be installed
                Depends: libvpx1 (>= 1.0.0) but it is not going to be installed
                Depends: libx264-123 but it is not going to be installed
                Depends: libxvidcore4 (>= 1.2.2) but it is not going to be installed
 libavformat-dev : Depends: libavutil-dev (= 6:0.8.10-1+rpi1) but it is not going to be installed
 libavformat53 : Depends: libavutil51 (>= 6:0.8.3-1~) but it is not going to be installed
 libgstreamer0.10-dev : Depends: libglib2.0-dev but it is not going to be installed
                        Depends: libxml2-dev but it is not going to be installed
                        Depends: gir1.2-gstreamer-0.10 (= 0.10.36-1.2) but it is not going to be installed
                        Recommends: debhelper but it is not going to be installed
 libgtk2.0-dev : Depends: libglib2.0-dev (>= 2.27.3) but it is not going to be installed
                 Depends: libgdk-pixbuf2.0-dev (>= 2.21.0) but it is not going to be installed
                 Depends: libpango1.0-dev (>= 1.20) but it is not going to be installed
                 Depends: libatk1.0-dev (>= 1.29.2) but it is not going to be installed
                 Depends: libcairo2-dev (>= 1.6.4-6.1) but it is not going to be installed
                 Depends: libx11-dev (>= 2:1.0.0-6) but it is not going to be installed
                 Depends: libxext-dev (>= 1:1.0.1-2) but it is not going to be installed
                 Depends: libxinerama-dev (>= 1:1.0.1-4.1) but it is not going to be installed
                 Depends: libxi-dev (>= 1:1.0.1-4) but it is not going to be installed
                 Depends: libxrandr-dev (>= 2:1.2.99) but it is not going to be installed
                 Depends: libxcursor-dev but it is not going to be installed
                 Depends: libxfixes-dev (>= 1:3.0.0-3) but it is not going to be installed
                 Depends: libxcomposite-dev (>= 1:0.2.0-3) but it is not going to be installed
                 Depends: libxdamage-dev (>= 1:1.0.1-3) but it is not going to be installed
                 Depends: libxml2-utils but it is not going to be installed
 libpython2.6 : Depends: python2.6 (= 2.6.8-1.1) but it is not going to be installed
 libunicap2 : Depends: libraw1394-11 but it is not going to be installed
 libv4l-0 : Depends: libv4lconvert0 (= 1.0.0-1) but it is not going to be installed
 libv4l-dev : Depends: libv4lconvert0 (= 1.0.0-1) but it is not going to be installed
              Depends: libv4l2rds0 (= 1.0.0-1) but it is not going to be installed
 libxine1-ffmpeg : Depends: libavutil51 (>= 6:0.8.3-1~) but it is not going to be installed
                   Depends: libfaad2 (>= 2.7) but it is not going to be installed
 python-dev : Depends: python (= 2.7.3-4+deb7u1) but 2.7.3-4 is to be installed
              Depends: python2.7-dev (>= 2.7.3-1~) but it is not going to be installed
 python2.6-dev : Depends: python2.6 (= 2.6.8-1.1) but it is not going to be installed
                 Depends: libssl-dev but it is not going to be installed
 swig : Depends: swig2.0 (>= 2.0.7-3) but it is not going to be installed
So I follow by :
pi@raspberrypi ~ $ sudo apt-get -f install
Correcting dependencies... Done
The following extra packages will be installed:
  libgtk-3-common
The following packages will be upgraded:
  libgtk-3-common
1 upgraded, 0 newly installed, 0 to remove and 42 not upgraded.
44 not fully installed or removed.
Need to get 0 B/2,656 kB of archives.
After this operation, 0 B of additional disk space will be used.
Do you want to continue [Y/n]? Y
(Reading database ... 63994 files and directories currently installed.)
Preparing to replace libgtk-3-common 3.4.2-6 (using .../libgtk-3-common_3.4.2-7_all.deb) ...
Unpacking replacement libgtk-3-common ...
dpkg: error processing /var/cache/apt/archives/libgtk-3-common_3.4.2-7_all.deb (--unpack):
 cannot copy extracted data for './usr/share/locale/ca/LC_MESSAGES/gtk30-properties.mo' to '/usr/share/locale/ca/LC_MESSAGES/gtk30-properties.mo.dpkg-new': failed to write (No space left on device)
dpkg-deb: error: subprocess paste was killed by signal (Broken pipe)
Processing triggers for libglib2.0-0:armhf ...
E: Sub-process /usr/bin/dpkg returned an error code (1)
pi@raspberrypi ~ $
Do you have any idea about where ii can come from?
Thank you
oliv93
Re: Installing OpenCV on the RPi
Mon Jun 30, 2014 7:37 pm
sorry for this post, I found the answer in the manual of Raspberry :
sudo raspi-config
and then first option to expand SD
oliv93
Tue Jul 01, 2014 7:45 am
I've installed opencv following the instructions of the link posted earlier. when I install, after 66% it says that I don't have enough space and it stops installing. I'm using a 4 GB SD Card NOOBS.
So I'm wondering :
Do I need a 8 GB Sd Card or did I forgot to do something?
I don't know where opencv is installing, on the SD Card or on the RPi directly. I guess that if it's on the SD Card I need a 8 GB and if it's on the RPi ... I don't know.
Any help please?
