Fri Jun 27, 2014 10:38 am
You might need to also declare the screen size in the lxde startup configuration.
To find out where that is, try running the following, it might show you where lxde is started from and you could add the geometry there.
ps aux | grep lxde
IF that does not help, poke around ~/.config and files in /etc/ directory, somewhere there is a command saying to autostart lxde and you could add geometery to when it gets called.
maybe ~/.xinitrc
to add geometry to the autostart, could try something like "lxde -geometry 1680x1050" and adjust that if necessary. geometry takes offset arguments as well, to see how offset works, could try 1680x1050+nn+nn where you put +nn or -nn of 0 or higher, for offsetting.
FORUM TIP: To view someone's posting history, sign in, click on their user name, then on "Search User's Posts." || Running ArchLinuxArm on Model 2B and 512MB Model B
