Everything was wokring fine until now, cause i've been rendering directly on the screen, into a window surface. But now I need to draw a text into an OpenGL texture instead.
Since I can't use fbo's with OpenVG i thought that I could use the EGL pbuffers instead, since I'd be using only openVG and EGL. However I'm getting an EGL_BAD_MATCH error when I try to make the pbuffer the current surface.
The code uses two EGLContexts, one for the OpenGL part and one that is part of the VGFONT implementation. The same pbuffer needs to access both contexts. When i use window surfaces, this works perfectly, but I just can't get it working for the pbuffers.
I've modified the create_context method on VGFONT to use pbuffers like this:
attribs[n++] = EGL_RENDERABLE_TYPE; attribs[n++] = EGL_OPENVG_BIT;
//attribs[n++] = EGL_SURFACE_TYPE; attribs[n++] = EGL_WINDOW_BIT;
attribs[n++] = EGL_SURFACE_TYPE; attribs[n++] = EGL_PBUFFER_BIT;
attribs[n] = EGL_NONE;*/The pbuffers are created successfully by
EGLBoolean esCreatePbuffer(ESContext *esContext, EGLSurface *surface, int width, int height)
/*static const EGLint attribListPbuffer[] =
EGL_SURFACE_TYPE, EGL_PBUFFER_BIT,
EGL_RED_SIZE, 5,
EGL_GREEN_SIZE, 6,
EGL_BLUE_SIZE, 5,
EGL_ALPHA_SIZE, 0,
EGL_DEPTH_SIZE, 16,
EGL_STENCIL_SIZE, 0,
EGL_NONE
EGLint srfPbufferAttr[] =
EGL_WIDTH, width,
EGL_HEIGHT, height,
// EGL_COLORSPACE, GL_RGB,
// EGL_TEXTURE_FORMAT, EGL_TEXTURE_RGB,
// EGL_TEXTURE_TARGET, EGL_TEXTURE_2D,
EGL_LARGEST_PBUFFER, EGL_TRUE,
EGL_NONE
*surface = eglCreatePbufferSurface(esContext->eglDisplay,
esContext->eglConfig,srfPbufferAttr);
if ( *surface == EGL_NO_SURFACE )
_findEGLError2(574);
esMakeCurrent(esContext, *surface);
}Does anyone know what I'm doing wrong, or have a better solution for drawing into an OpenGL texture using OpenVG?
