Just a quick question about the voltage of the 1820 temperature probes. I read that you should only use 3.3v with the GPIO pins on the PI, but most of the wiring diagrams for the 1820 are connected to the 5 volt pin.
As I am going to be using between 7 and 10 probes ( about a 10 meter run, evenly spaced ) should I be use 3.3 or 5 volts.
Any comments or advice?
Leo
