I want to add a powered USB hub for my Pi, and power it with the hub. I was thinking of this hub.
Do I have to add a USB > Micro USB cable to power it?
Re: Powering with USB hub
Yes & Yes
D-Link D-Link 7 Port USB Hub DUB-H7/B USB 2.0 7-Port 2.4 A Verified [Power USB slots can be used to power Raspberry Pi.
http://elinux.org/RPi_Powered_USB_Hubs
The information is out there....you just have to let it in.
My other Linux machines are a ChromeBox & Intel CoreDuo Desktop
- mahjongg
- Forum Moderator
I suppose it isn't "back powering" then?
It is not possible to power it only by connecting it to the USB port right?
- FLYFISH TECHNOLOGIES
- Contact: Website
HI,
Best wishes, Ivan Zilic,
Use its micro USB connector for supplying it. Otherwise, you bypass internal protection circuit.Preator wrote:It is not possible to power it only by connecting it to the USB port right?
Running out of GPIO pins and/or need to read analog values?
Solution: http://www.flyfish-tech.com/FF32
