Tekk3y
Start a Python Script from boot
Fri Jun 20, 2014 12:47 pm
Hello everyone, I was hoping someone could help me. I'm working on a project that uses a python script but it needs to open the python script as soon as the Raspberry Pi has booted up. I was wondering if anyone knew of any really good tutorials on this or if someone could describe it themselves.
Thanks, Tekk3y
Re: Start a Python Script from boot
Fri Jun 20, 2014 12:55 pm
Add a line in /etc/rc.local (before the exit 0 line) with
/dir/subdir/pythonscriptname parms &
You need to use the whole path to the script.
This is a doctor free zone.
Tekk3y
Fri Jun 20, 2014 3:59 pm
Hello, thanks. I tried this but its saying "can't open file to write'. What should I do?
Thanks, Tekk3y
Douglas6
Fri Jun 20, 2014 4:09 pm
sudo nano /etc/rc.local
Tekk3y
Fri Jun 20, 2014 4:45 pm
Hello. I tried what you showed above but it doesn't seem to of done anything. I'm fairly new to the Raspberry Pi so i'v attached an image of what i'v written and if you can spot what i'v done wrong then that would be great.
Thanks again, Tekk3y
ilguargua
Fri Jun 20, 2014 5:21 pm
Is yor program file beginning with a properly hashbang (eg. #!/usr/bin/python)?
Did make it executable (chmod +x youfilename)?
Cheers,
Ale.
Gert van Loo
Fri Jun 20, 2014 5:39 pm
You do not have a shell which starts python for you.
So you have to specify the executable and the full paths to everything.
Try this:
/usr/bin/python /home/pi/Desktop/program.py &
Tekk3y
Fri Jun 20, 2014 7:23 pm
Gert van Loo wrote:You do not have a shell which starts python for you.
Try this:
Hi, I tried this but it still doesn't do anything on boot. :/
Tekk3y
Stephanie
Sat Jun 21, 2014 12:51 am
What are you expecting it to do? You probably won't see any output on your screen; when the script is run during startup it is not 'attached' to your console.
In other words, depending on what the script does, it might be running, you just can't see it.
Since you've mentioned it was in ~/Desktop I am wondering if you are having your Pi boot directly to the GUI desktop? If so, there's a way to have it run automatically (inside a terminal shell window if necessary) when the desktop boots up.
Using the program path in your earlier post, you would create the following file:
[Desktop Entry]
Name=My Program
Comment=My Program Auto Start
Exec=/home/pi/Desktop/program.py
Icon=
StartupNotify=true
Terminal=true
X-MultipleArgs=false
Type=Application
Categories=Utility;TerminalEmulator;
From your home directory that would go into .config/autostart/myprogram.desktop
You could open a terminal window and type:
nano ~/.config/autostart/myprogram.desktop
Then just paste the contents of the above code.
That will make the GUI automatically launch program.py in a text window whenever you start up the Pi.
Hope that is helpful.
Cheers!
Tekk3y
Sat Jun 21, 2014 10:59 am
Hi, when I do this it says "Error Writing /home/pi/.config/autostart/myprogram.desktop: No such file or". Should I have created the autostart file first?
rgrbic
Sat Jun 21, 2014 11:40 am
You have to put path to your python script in rc.local file. Open the file with the following command:
and before exit 0 write:
Make sure that your python script starts with the following line:
#!/usr/bin/env python
At 127.0.0.1
Twitter: @rgrbic
IoT-projects.com
Tekk3y
Sat Jun 21, 2014 12:02 pm
Stephanie wrote:What are you expecting it to do? You probably won't see any output on your screen; when the script is run during startup it is not 'attached' to your console.
[Desktop Entry]
Name=My Program
Icon=
StartupNotify=true
Terminal=true
Type=Application
Cheers!
So I tried this and you can see from my previous response what happened the first time but secondly I created the auto start folder as there wasn't one there and added the file but I still don't get the terminal to run the python script once its reached the desktop.
Stephanie
Sat Jun 21, 2014 1:20 pm
Hi Tekk3y,
.config and autostart are directories that should already be there. If you open a new terminal window and type:
cd .config (return)
then type:
cd autostart (return)
there should not be any errors, and you should see a prompt that looks like this:
~/.config/autostart $
From there you can try entering:
nano myprogram.desktop (return)
And then enter the code in my previous post.
If you get any errors along the way, please share exactly what error you get.
I've done this myself to get a python script to launch upon booting to the desktop, it should work but we might just need to tweak it a bit to be sure.
Oh one other thing you need to verify that your python script has a proper hashbang first line, and that it is executable, as ilguargua said.
I use a slightly different hashbang, but either should work. The first line of my .py file is:
#!/usr/bin/env python2.7
Cancelor
Sat Jun 21, 2014 2:05 pm
I'm trying to follow along on rasbian and I get this....
[email protected] ~ $
[email protected] ~ $ cd .config
[email protected] ~/.config $ ls
enchant  libfm  lxpanel  midori  openbox  pcmanfm  Trolltech.conf
[email protected] ~/.config $ cd autostart
-bash: cd: autostart: No such file or directory
[email protected] ~/.config $ ^C
Can't find the thread you want? Try googling : YourSearchHere site:raspberrypi.org
Tekk3y
Sat Jun 21, 2014 2:23 pm
Stephanie wrote:Hi Tekk3y,
cd .config (return)
then type:
I tried this again (and I even tried re-installing the OS) but the autostart directory is still not there. When I type cd autostart (return) I get a message saying 'bash: cd: autostart: No such file or directory'.
simplesi
Sat Jun 21, 2014 2:27 pm
The autostart is not there with a fresh image
type
mkdir /home/pi/.config
ignore any error
then type
mkdir /home/pi/.config/autostart
you should not get any error
Simon
Seeking help with Scratch and I/O stuff for Primary age children
http://cymplecy.wordpress.com/ @cymplecy on twitter
Stephanie
Sat Jun 21, 2014 2:39 pm
My apologies, I thought autostart was already there. I don't remember having to add it myself.
Tekk3y
Sat Jun 21, 2014 2:41 pm
simplesi wrote:The autostart is not there with a fresh image
type
ignore any error
then type
Simon
I still dont get a terminal with my program running after boot after doing this... Although its removing the contents of my .py file on every start up. :/
Tekk3y
Sat Jun 21, 2014 4:17 pm
...Why is it so complicated to make a python script launch in terminal on boot. I still haven't accomplished this. :(
simplesi
Sat Jun 21, 2014 5:13 pm
Its not that complicated but one spilling mistook or one error and it won't work
And there are LOTS of ways to accomplish the same goal.
Linux isn't like Windows - there is no Startup group :(
Simon
Tekk3y
Sat Jun 21, 2014 5:36 pm
So at the moment I have found another way in which to do this. This is by using
nano ~/.bashrc
and then adding my command to run the script at the end of it. This works although only runs the script once I'v clicked to open terminal. Does anyone know of any ways to automatically open terminal on boot?
Thanks, Tekk3y
Cancelor
Sat Jun 21, 2014 7:50 pm
I tried the above and although I wasn't loosing the contents of my files I didn't get anything on screen.
I noticed that when I run my Python file:-
#!/usr/bin/env python3
import time
print ("hello world")
time.sleep(3)
while(True):
    print("Press Cntrl+c to EXIT")
    time.sleep(3)
by double clicking on it's desktop icon, it asks if I want to run in the terminal but nothing happens :(
simplesi
Sat Jun 21, 2014 11:00 pm
Im starting to get that you don''t just want to run a script on boot - you want to see it display in a terminal window as well - yes?
Simon
Tekk3y
Tue Jun 24, 2014 11:33 am
simplesi wrote:Im starting to get that you don''t just want to run a script on boot - you want to see it display in a terminal window as well - yes?
Simon
Yes that is what I wanted it to do. :)
Tekk3y
Tue Jun 24, 2014 4:05 pm
...So i'v now solved the problem. If anyone else is wanting to do this instead of finding bits and pieces over my two questions im list what i'v done below.
First of all you want your pi to launch straight to the desktop. I did this using Noobs of which you can set this when installing the OS in the options.
Secondly type:
mkdir ~/.config/autostart
to create the autostart directory.
after that you need to edit a .desktop file in the directory by using the following command.
Once there you need to place the following text into the .desktop file:
[Desktop Entry]
Exec= sudo python  /home/pi/Desktop/program.py
Type=Application
note to only use sudo if you need root access and the '/home/pi/Desktop/program.py' section should be the route to your python script.
After this you need to make your python script execuitable and add the orrect hash to the front of the code. For this open your python file in a text editor and add the following to the top of the file.
#!/usr/bin/python
after this you need to make your script executable, to do this move to the directory your script is in and type teh following into the terminal.
chmod +x myscript.py
this will be the same except change myscript.py for your script name and extension. After this you should be able to restart your pi and the terminal should launch on boot with your script running.
