I am trying to drive 9 bright LEDs from one GPIO port (as a light for a webcam) I appreciate that I can't drive them straight off the GPIO so have in driven them through a transistor. Please see the attached circuit.
The problem is that when I switch on GPIO 11 the LEDs come on but only at about half brightness.
The transistor is supposed to be able to carry 4A and has a current ratio of 750
I have measured the voltage out of the regulator and it is 2.9 to 3v.
If I use a 3v pin on the GPIO rather than Pin 11 they are dim
If I connect the 3v GPIO pin directly to the transistor base bypassing the resistor they are dim.
If I drive just one LED rather than 9 it is dim.
The only time I can get all LEDs brights is if If I bypass the transistor and connect the LED anodes directly to the +3v feed then all is as I would expect and they are bright.l
Any ideas would be gratefully received - been bashing my head against the wall all weekend over this.
