Hi everybody. I have bought a raspberry with lcd display 320x240 from adafruit. The display works well.
Now can I add a rtc module and then have I got others io available?
Does the display require all io available on raspberry pi?
If this is the display you have, the description says.mrdebug wrote:Can you exmplain better wich are the availabel pins? I'm a developer and not an elettronic man.
.Uses the hardware SPI pins (SCK, MOSI, MISO, CE0, CE1) as well as GPIO #25 and #24
