YDYD
sudo apt-get update PROBLEM~PLSS HELP
Fri Jun 13, 2014 6:36 am
Hi All,
I am really new to Linus Raspbian,
I would really appreciate if anyone could help.
I could not update, the error msg as shown below:
pi@raspberrypi ~ $ sudo apt-get update
Get:1 http://raspberrypi.collabora.com wheezy Release.gpg [836 B]
Hit http://mirrordirector.raspbian.org wheezy Release.gpg
Hit http://raspberrypi.collabora.com wheezy Release
Err http://raspberrypi.collabora.com wheezy Release
Hit http://mirrordirector.raspbian.org wheezy/main armhf Packages
Hit http://archive.raspberrypi.org wheezy Release.gpg
Hit http://mirrordirector.raspbian.org wheezy/contrib armhf Packages
Hit http://mirrordirector.raspbian.org wheezy/non-free armhf Packages
Hit http://archive.raspberrypi.org wheezy/main armhf Packages
Hit http://mirrordirector.raspbian.org wheezy/rpi armhf Packages
Ign http://archive.raspberrypi.org wheezy/main Translation-en_GB
Ign http://mirrordirector.raspbian.org wheezy/contrib Translation-en_GB
Ign http://mirrordirector.raspbian.org wheezy/main Translation-en_GB
Ign http://mirrordirector.raspbian.org wheezy/non-free Translation-en_GB
Ign http://mirrordirector.raspbian.org wheezy/rpi Translation-en_GB
Fetched 836 B in 21s (39 B/s)
Reading package lists... Done
W: A error occurred during the signature verification. The repository is not updated and the previous index files will be used. GPG error: http://raspberrypi.collabora.com wheezy Release: The following signatures were invalid: BADSIG ED4BF9140C50B1C5 Collabora Raspbian Archive Signing Key <daniels@collabora.com>
W: Failed to fetch http://raspberrypi.collabora.com/dists/wheezy/Release
W: Some index files failed to download. They have been ignored, or old ones used instead.
W: Duplicate sources.list entry http://raspberrypi.collabora.com/ wheezy/rpi armhf Packages (/var/lib/apt/lists/raspberrypi.collabora.com_dists_wheezy_rpi_binary-armhf_Packages)
Re: sudo apt-get update PROBLEM~PLSS HELP
Fri Jun 13, 2014 7:16 am
In Raspbian Wheezy your sources list " /etc/apt/sources.list " should show:
deb http://mirrordirector.raspbian.org/raspbian/ wheezy main contrib non-free rpi
Have you installed any software which is not via apt-get ?
