rpiswag
raspberry pi satellite
Tue Jun 10, 2014 3:21 pm
if put in a pressure vesicle could the raspberry pi be put in low Earth orbit to collect data.
A computer's power can't be just measured Gigahertz. It is the same thing with us humans.
RaTTuS
Contact: Twitter YouTube
Re: raspberry pi satellite
Tue Jun 10, 2014 3:49 pm
yes if you have enough cash -
Covfefe
Ravenous
Tue Jun 10, 2014 4:22 pm
rpiswag wrote:if put in a pressure vesicle could the raspberry pi be put in low Earth orbit to collect data.
How much electronics and programming experience do you have?
riklaunim
Tue Jun 10, 2014 4:26 pm
The key element is protection from radiation, protection from very low temperatures, then communication with ground based stations, permissions etc. Students often get access to CubeSat program - http://en.wikipedia.org/wiki/CubeSat - and if Raspberry Pi based satellite would be approved then it could fly.
Cancelor
Tue Jun 10, 2014 4:34 pm
Would it even need a pressure vessel? Would it work okay in a vacuum?
Can't find the thread you want? Try googling : YourSearchHere site:raspberrypi.org
rpiswag
Tue Jun 10, 2014 5:01 pm
Because there are capacitors on the board and most capacitors will not function properly without a pressure vesicle. I know how to deal with maintaining pressure but what about electromagnetic interference from the sun and other sources ect.... It a vaccume heat would stay trapped on the raspberry pi board. In a vaccum could this cause the raspberry pi board to overheat?
riklaunim
Tue Jun 10, 2014 5:19 pm
Electronics that is space-compatible costs a lot, while it may be a Core 2 Duo board ;) And in general electronics in space is heated to some temperature at which they work and don't fail. You may look at http://www.srl.utu.fi/AuxDOC/tke/radmon ... andard.pdf or http://www.intechopen.com/books/aerospa ... cecraft#F6 for a computer diagram.
2.1.4
No pressure vessels over 1.2 standard atmosphere shall be permitted.
2.1.4.1 Pressure vessels shall have a factor of safety no less than 4.
mahjongg
Tue Jun 10, 2014 5:25 pm
Ravenous
Wed Jun 11, 2014 7:43 am
Here's another thread - amateur electronics, just not raspi, but still relevant:
http://www.picaxeforum.co.uk/showthread ... ace/page29
(It's a long read but there's interesting stuff in there.)
