I have a video with three audio tracks. English is track #2 and I would like to listen to that. I have a vanilla flavoured raspbmc build and initiate videos from file manager. I tried the icons at the bottom of the screen once the video was running but I couldn't see anyway to change the language (currently Italian I think). Any suggestions on changing the audio track? mediainfo dump posted below.
Cheers
Format : AVI
Format/Info : Audio Video Interleave
File size : 806 MiB
Duration : 1h 16mn
Overall bit rate : 1 464 Kbps
Writing application : VirtualDubMod 1.5.10.2 (build 2542/release)
Writing library : VirtualDubMod build 2542/release
Video
Format : MPEG-4 Visual
Format profile : Advanced Simple@L5
Format settings, BVOP : 2
Format settings, QPel : No
Format settings, GMC : No warppoints
Format settings, Matrix : Default (H.263)
Codec ID : XVID
Codec ID/Hint : XviD
Duration : 1h 16mn
Bit rate : 997 Kbps
Width : 640 pixels
Height : 352 pixels
Display aspect ratio : 16:9
Frame rate : 25.000 fps
Color space : YUV
Chroma subsampling : 4:2:0
Bit depth : 8 bits
Scan type : Progressive
Compression mode : Lossy
Bits/(Pixel*Frame) : 0.177
Stream size : 549 MiB (68%)
Writing library : XviD 1.2.0SMP (UTC 2006-01-08)
Audio #1
Format : MPEG Audio
Format version : Version 1
Format profile : Layer 3
Mode : Joint stereo
Mode extension : MS Stereo
Codec ID : 55
Codec ID/Hint : MP3
Duration : 1h 16mn
Bit rate mode : Constant
Bit rate : 128 Kbps
Channel(s) : 2 channels
Sampling rate : 44.1 KHz
Delay relative to video : 12ms
Stream size : 70.4 MiB (9%)
Alignment : Split accross interleaves
Interleave, duration : 40 ms (1.00 video frame)
Interleave, preload duration : 500 ms
Audio #2
Format : MPEG Audio
Mode : Joint stereo
Codec ID : 55
Codec ID/Hint : MP3
Duration : 1h 16mn
Bit rate : 128 Kbps
Audio #3
Format : MPEG Audio
Mode : Joint stereo
Codec ID : 55
Codec ID/Hint : MP3
Duration : 1h 16mn
Bit rate : 192 Kbps
Stream size : 106 MiB (13%)
Writing library : LAME3.90.3
