comptech2545
Okular 0.16.2 and KDE 4.10.2 upgrade for Raspbian
Wed Jun 04, 2014 5:57 pm
I'm a newbe here so please bear with me.
I have Okluar 0.14.3 with KDE 4.8.4 installed. Everything is working great. We use the Raspberry PI on the production floor to read PDF drawings. I have read that Okular 0.16.2 has a feature to save the file with the notes. The current version does not do that.
The question I have is the Raspbian repository only has version 0.14.3 of Okular and 4.8.4 of KDE. How and where do I go to get the update?
Thanks!!
Re: Okular 0.16.2 and KDE 4.10.2 upgrade for Raspbian
Wed Jun 04, 2014 6:17 pm
Raspbian Jessie Testing has newer packages
https://packages.debian.org/jessie/okular
RPi 4B 4GB (SSD Boot)..
comptech2545
Wed Jun 04, 2014 6:55 pm
Thanks for the quick response!
Being a newbe.... I'm not sure where to get the code. Any apps I have added I did a: $apt-get install okular . I'm not sure where the Raspberry is getting the app. I'm guessing it is looking at the SOURCE.LIST. Mine has: "deb http://archive.raspbian.org/raspbian wheezy main contrib non-free deb-src http://archive.raspbian.org/raspbian wheezy main contrib non-free"
How do I get the newer Okular app?
mimi123
Wed Jun 04, 2014 6:57 pm
you remplace whezzy with jessie in sources.list.
comptech2545
Wed Jun 04, 2014 7:16 pm
Ahhhh...... Told you I was a newbe. Lol. I'll give that a try and let you know.
Wed Jun 04, 2014 7:17 pm
mimi123 wrote:you remplace whezzy with jessie in sources.list.
get Jessie you update /etc/apt/sources.list replacing wheezy with jessie ie
deb http://mirrordirector.raspbian.org/raspbian/ jessie main contrib non-free rpi
You then need to do sudo apt-get update && sudo apt-get dist-upgrade to move to Jessie
Maybe best to undertake this on another SDCard from a fresh install of Raspbian Wheezy
comptech2545
Thu Jun 05, 2014 3:08 pm
That worked!!!! Thanks sooooo much!!!
Return to “Raspberry Pi OS”
