rams4pi
Serial Communication Pyserial
Mon Jun 02, 2014 4:47 am
hi friends,
i am facing some problems with serial communcation, my requirement is i need to write i value, Instead of Giving string in ser.write ()
import serial
i = 10
ser = serial.Serial(port, 9600, timeout=1)
ser.open() # i am opening a serial port .
i need to write i value. can any one tell me the syntax .
ser.write(i) # is this correct ... can i write i value using i ...
Please Reply me ASAP
Thanks,
Rams4pi.
riklaunim
Re: Serial Communication Pyserial
Mon Jun 02, 2014 6:10 am
Maybe chr(i) would work for you? Serial communication may depend a lot on the target device and its API. If that doesn't help post some info about your device connected via serial.
rams4pi
Mon Jun 02, 2014 7:00 am
i am coonecting Xbee to Piusing usb and using Pyserial to communicate Serially ..
atomic3
Mon Jun 02, 2014 5:17 pm
On the receiving end just convert to int?
rams4pi
Wed Jun 04, 2014 5:39 am
Thanks i got the Output ...
