Thu May 29, 2014 7:52 pm
BSD does everything weird - in terms of the disk partitioning, right?
IIRC, it uses slices and stuff like that instead of the regular stuff that Linux uses. So, no, it probably wouldn't port, nor would the advice to do it manually - the way we used to do it before there was a raspi-config - be likely to work either.
You'll probably have to re-invent it all. But it shouldn't be *that* hard, I guess.
