@rpdom: You could also use the 5V pins on the gpio as a test point, rather than soldering wires to the board.
Is the 5V on the gpio the same as the 5V on the TP? I mean what was the reason of the Foundation to include a TP when that 5V could be measured on the gpio? There should be something behind this.
You will need an ADC of some sort
OK, what sort? I'm completly new to this, all i did so far was to solder a few wires my cat chewed on, solder back a displaced speaker to the pcb in my dect, solder off the beeper from my microwave (hated that), etc.
Please give me a shopping list with the item list i could google for and learn more about.
@joan:
I think you need a reference voltage.
ok, but what if that "3V3" is varied by the 5V input? Is it?
Could i calibrate the ADC by using a multimeter once? Or will the calibration drift away in time, or change with the temperature?
