ric96
kano os integration
Mon May 26, 2014 2:14 am
Is there a way to integrate kano os with raspbian?
My apologies for shameless YouTube Plugs...
youtube.com/sahajsarup
twitter @sahajsarup
skype srics1996
e-mail: sahajsarup@gmail.com
Blog: http://www.geektillithertz.com/wordpress
Web: http://www.geektillithertz.com
riklaunim
Re: kano os integration
Mon May 26, 2014 6:17 am
Change wallpaper, install the same apps and you have it.
ShiftPlusOne
Mon May 26, 2014 6:31 am
what do you mean by 'integrate'?
ric96
Mon May 26, 2014 4:05 pm
ShiftPlusOne wrote:what do you mean by 'integrate'?
kano is build upon raspbian
what i mean is make an raspbian installation look and behave like kano without the need of reflashing my sdcard
twitter @sahajsarup
skype srics1996
ShiftPlusOne
Mon May 26, 2014 6:54 pm
I would start by looking at /etc/apt/sources.list and /etc/apt/sources.list.d/* and seeing if they added an additional repo to house their own stuff. Then you can fire up synaptic or use the command line tools to see what's actually installed from there. Then investigate what's autostarted and how.
ric96
Tue May 27, 2014 5:56 am
Foumd the repo
dev.kano.me release/main
Cannot get the public key
Help
twitter @sahajsarup
skype srics1996
ShiftPlusOne
Tue May 27, 2014 6:05 am
wget -q -O - http://dev.kano.me/archive/repo.gpg.key | sudo /usr/bin/apt-key add -
ric96
Tue May 27, 2014 1:40 pm
created a script to install kano on raspbian
pl. check
https://github.com/ric96/kano-raspbian
twitter @sahajsarup
skype srics1996
ShiftPlusOne
Tue May 27, 2014 7:22 pm
won't work
sudo echo "deb http://dev.kano.me/archive/ release main" > /etc/apt/sources.list.d/kano.list
This runs the 'echo' command as root. However, the redirection '>' is done as the current user.
Why do you have 'sudo' in every other line?
You also download files and don't clean up after yourself.
sudo apt-get upgrade -y
sudo apt-get dist-upgrade -y
Why? They do almost the same thing.
#!/bin/bash -e
if [ $EUID -ne 0 ]; then
	echo "This script must be run as root!"
	exit 1
fi
Since almost everything the script does is done as root, cut out all of the 'sudo' and add the above check to the script.
ric96
Tue May 27, 2014 9:58 pm
ShiftPlusOne wrote:won't work
#!/bin/bash -e
	exit 1
fi
Point 1. And 3. Noted changes will be made
Point 2 ) there are some files from the kano repo that are not upgraded by using just "upgrade"
twitter @sahajsarup
skype srics1996
ShiftPlusOne
Tue May 27, 2014 10:07 pm
2) Dist-upgrade implies upgrade.
ric96
Tue May 27, 2014 10:09 pm
ShiftPlusOne wrote:2) Dist-upgrade implies upgrade.
oh yeah !! almost forgot!
twitter @sahajsarup
skype srics1996
ric96
Tue May 27, 2014 10:12 pm
changes done!
twitter @sahajsarup
skype srics1996
