themarkmcintosh
RPI I/O control software
Thu Jun 07, 2012 5:31 pm
Hi All,
I'm new to Linux and have recently received my RPI. I have got Debian up and running but am wondering if there is any software that can be used to easily control the I/O ports. Is there anything like this out there? I would like to be able to use the GPIO to switch relays etc as part of a bigger control system.
Many thanks,
Mark
ghans
Re: RPI I/O control software
Fri Jun 08, 2012 8:04 am
I would recommend python (the programming language).
http://pypi.python.org/pypi/RPi.GPIO
You can install above package by executing setup.py with sudo.
Then GPIO functionality should only be a import away.
PS: You can also use GPIO pins from the command-line or bash scripts , you just need to write to some device files (linux filesystem)
ghans
themarkmcintosh
Fri Jun 08, 2012 1:01 pm
Thanks for your reply!
I will look into using Python. I'm not much of a programmer and though there might be some kind of GUI that was already available but I am more than happy to have a play with Python!
dannyboy
Fri Jun 08, 2012 10:51 pm
I've got some LEDs flashing by using the tutorial in issue 2 of www.themagpi.com I found that pretty useful
@dannyboy6661984 on Twitter
themarkmcintosh
Sat Jun 09, 2012 2:05 am
That will be my next port of call then! Thanks dannyboy
Russell Jones
Sat Aug 04, 2012 8:48 pm
A good place to start with python (based on working through their JavaScript tutorials) is Code Academy. They provide online interactive programming tutorials
xinyun
Fri Feb 22, 2013 9:24 am
ghans wrote:I would recommend python (the programming language).
ghans
i can not do "You can install above package by executing setup.py with sudo." as you say.command not found!
croston
Fri Feb 22, 2013 9:41 am
RPi.GPIO is installed by default in recent versions of Raspbian so you don't need to install it manually.
Mobius
Sun Feb 24, 2013 12:40 am
This is the GPIO control SW I'm going to try as soon as my set of jumper cables shows up:
https://projects.drogon.net/raspberry-p ... d-install/
