the code as it stands is:
import RPi.GPIO as GPIO # import RPi.GPIO module
from time import sleep # lets us have a delay
import datetime
import time
import os
import time, datetime
Brightness = 17
LED_1 = 22
LCD_RS = 7
LCD_E = 8
LCD_D4 = 25
LCD_D5 = 24
LCD_D6 = 23
LCD_D7 = 18
LCD_WIDTH = 16 # Maximum characters per line
LCD_CHR = True
LCD_CMD = False
LCD_LINE_1 = 0x80 # LCD RAM address for the 1st line
LCD_LINE_2 = 0xC0 # LCD RAM address for the 2nd line
E_PULSE = 0.00005
E_DELAY = 0.00005
try:
while True:
def main():
# Main program block
GPIO.setmode(GPIO.BCM) # Use BCM GPIO numbers
GPIO.setup(LCD_E, GPIO.OUT) # E
GPIO.setup(LCD_RS, GPIO.OUT) # RS
GPIO.setup(LCD_D4, GPIO.OUT) # DB4
GPIO.setup(LCD_D5, GPIO.OUT) # DB5
GPIO.setup(LCD_D6, GPIO.OUT) # DB6
GPIO.setup(LCD_D7, GPIO.OUT) # DB7
sleep(10)
# Initialise display
lcd_init()
mystring = ""
mystring2 = ""
mytime = ""
mytemp = ""
pretemp = "["
posttemp = "c] "
f=os.popen("date")
for i in f.readlines():
mytime += i
mytime = mytime[11:-13]
f=os.popen("/opt/vc/bin/vcgencmd measure_temp")
mytemp += i
mytemp = mytemp[5:-3]
mystring = pretemp + mytemp + posttemp + mytime
lcd_byte(LCD_LINE_1, LCD_CMD)
lcd_string(mystring)
lcd_byte(LCD_LINE_2, LCD_CMD)
lcd_string(" test")
def lcd_init():
lcd_byte(0x33,LCD_CMD)
lcd_byte(0x32,LCD_CMD)
lcd_byte(0x28,LCD_CMD)
lcd_byte(0x0C,LCD_CMD)
lcd_byte(0x06,LCD_CMD)
lcd_byte(0x01,LCD_CMD)
def lcd_string(message):
# Send string to display
message = message.ljust(LCD_WIDTH," ")
for i in range(LCD_WIDTH):
lcd_byte(ord(message[i]),LCD_CHR)
def lcd_byte(bits, mode):
# Send byte to data pins
# bits = data
# mode = True for character
# False for command
GPIO.output(LCD_RS, mode) # RS
# High bits
GPIO.output(LCD_D4, False)
GPIO.output(LCD_D5, False)
GPIO.output(LCD_D6, False)
GPIO.output(LCD_D7, False)
if bits&0x10==0x10:
GPIO.output(LCD_D4, True)
if bits&0x20==0x20:
GPIO.output(LCD_D5, True)
if bits&0x40==0x40:
GPIO.output(LCD_D6, True)
if bits&0x80==0x80:
GPIO.output(LCD_D7, True)
# Toggle 'Enable' pin
time.sleep(E_DELAY)
GPIO.output(LCD_E, True)
time.sleep(E_PULSE)
GPIO.output(LCD_E, False)
time.sleep(E_DELAY)
# Low bits
if bits&0x01==0x01:
if bits&0x02==0x02:
if bits&0x04==0x04:
if bits&0x08==0x08:
time.sleep(E_DELAY)
time.sleep(E_PULSE)
time.sleep(E_DELAY)
if __name__ == '__main__':
main()
except KeyboardInterrupt: # trap a CTRL+C keyboard interrupt
GPIO.cleanup() # resets all GPIO ports used by this program
