Neerav
Booting Problem
Thu May 15, 2014 10:25 am
Hello!
I got a problem. When i start my raspberry pi with a new flashed Sdcard with either noobs, rasbmc etc it boots fine.
But to the problem when i turn it off with either shutdown in terminal or just pull the plug (know this isnt good) it wont boot again.
Its just the power led thats light up. I can reboot it works fine. But if i turn it off and dont use it for a while and gonna use it again. No hdmi picture no ssh access nothing.
Ive tried to sudo update upgrade then leave it on for 8 hours. For everything to be written to sd card and stuff. But the same thing happends.
Anyone got any solution?
BMS Doug
Re: Booting Problem
Thu May 15, 2014 11:30 am
when you do a shutdown command do you immediately remove power or do you wait (about 20 seconds after all the lights go off) to let it sort itself out?
Doug.
Neerav
Re: Booting Problem
Thu May 15, 2014 11:45 am
hmm a good question. dont really know how long i waited. i will try that thanks!
Neerav
Re: Booting Problem
Sat May 17, 2014 9:38 am
BMS Doug wrote:when you do a shutdown command do you immediately remove power or do you wait (about 20 seconds after all the lights go off) to let it sort itself out?
Ok i tried this. Waited 2 minuted. It was off for 3 hours tried again didnt boot.
Should be the SD card then right?
GTR2Fan
Re: Booting Problem
Sat May 17, 2014 9:42 am
...or marginal power supply voltage due to using a poor power supply, or marginal instability if RaspBMC has applied an overclock that your Pi doesn't like. The former can often exacerbate the latter.
Pi2B Mini-PC/Media Centre: ARM=1GHz (+3), Core=500MHz, v3d=500MHz, h264=333MHz, RAM=DDR2-1200 (+6/+4/+4+schmoo). Sandisk Ultra HC-I 32GB microSD card on '50=100' OCed slot (42MB/s read) running Raspbian/KODI16, Seagate 3.5" 1.5TB HDD mass storage.
Neerav
Re: Booting Problem
Sat May 17, 2014 11:14 am
Ok cool gonna get a new sd card and a powered usb hub today that should fix everything i hope :)
