gagle
Error with the recent changes to the driver
Wed May 14, 2014 10:15 am
Have you made any important change in the driver internals? The last firmware update has broken the OpenMAX transition from unloaded to idle. After 5 seconds of inactivity with the led turned on, I get an error: OMX_ErrorInsufficientResources.
Using the raspistill I also get an error:
mmal: mmal_vc_component_enable: failed to enable component: ENOSPC
mmal: camera component couldn't be enabled
mmal: main: Failed to create camera component
mmal: Failed to run camera app. Please check for firmware updates
OS: Arch linux
Re: Error with the recent changes to the driver
Wed May 14, 2014 11:15 am
We don't test on Arch, so perhaps the problem is there. Does it go wrong on Raspbian? What GPU split do you have?
Although if it does go wrong on Raspian I would have expected many problems to have been flagged up by others.
gagle
Wed May 14, 2014 11:54 am
/boot/config.txt:
gpu_mem_512=316
gpu_mem_256=128
(I don't have any "gpu_mem" line)
free -h:
total mem: 462MB.
I've not made any change to the rpi (or I think so)
Edit: I've set these values to the /boot/config.txt file as stated here: https://wiki.archlinux.org/index.php/Raspberry_Pi
cma_lwm=
cma_hwm=
cma_offline_start=
Now it works again...
Return to “Camera board”
