ja.heller
using beeper via GPIO and python
Mon May 12, 2014 4:49 pm
Heyho guys;
I want to use my old beeper from my motherboard.
As I know it needs to get power via PWM.
I used this snippet of code:
import RPi.GPIO as GPIO
import time
GPIO.setmode(GPIO.BCM)
GPIO.setwarnings(False)
GPIO.setup(25, GPIO.OUT)
GPIO.output(25, True)
time.sleep(10)
GPIO.cleanup()
Result --> speaker "clicks" (very silent)
Now I tried this python code for using PWM:
p = GPIO.PWM(25, 50)
p.start(50)
GPIO.cleanup()
Result --> nothing happens, there isn't any sound.
Should I change the Hertz value or should I change the percent duty cycle?
If yes to which amount should I change?
Kind regards;
scotty101
Re: using beeper via GPIO and python
Mon May 12, 2014 7:43 pm
You should probably change the frequency.
50Hz isn't nearly high enough to produce an audible sound. Middle C is 261 Hz. Try a frequency in that range and report back.
jojopi
Mon May 12, 2014 8:12 pm
50Hz is a low but perfectly audible buzz.
The problem with the code is the lack of time.sleep() before GPIO.cleanup(), which means the note has zero length.
ja.heller
Tue May 13, 2014 11:11 am
I've tried:
p = GPIO.PWM(25, 261)
p.start(50)
GPIO.cleanup()
result --> no sound output ;(.
GPIO Pins are the right ones. As I told you the first code (see above) without using PWM triggers a very silent "click" sound.
All the best;
Kind regards;
kbfirebreather
Tue May 13, 2014 11:41 am
p.start(50)
time.sleep(10)
GPIO.cleanup()
GPIO.cleanup() resets all the GPIO pins. Without the time.sleep() in there, it starts the frequency, then immediately resets the gpio pin. The sleep should give you a sound for 10 seconds.
ja.heller
Tue May 13, 2014 11:48 am
Thanks a lot,
Now it works;
import time
p.start(50)
time.sleep(10)
GPIO.cleanup()
Any idea how to increase the volume? It's not as much loud as I expected it to be.
All the best;
GTR2Fan
Tue May 13, 2014 11:51 am
You might want to check that it's actually a high impedance piezo speaker. If it's a typical 'old school' PC beep loudspeaker then the impedance is way too low to drive directly from a GPIO pin without risking permanent damage to the Pi.
Pi2B Mini-PC/Media Centre: ARM=1GHz (+3), Core=500MHz, v3d=500MHz, h264=333MHz, RAM=DDR2-1200 (+6/+4/+4+schmoo). Sandisk Ultra HC-I 32GB microSD card on '50=100' OCed slot (42MB/s read) running Raspbian/KODI16, Seagate 3.5" 1.5TB HDD mass storage.
Return to “Python”
Who is online
Users browsing this forum: No registered users and 20 guests
