Hi, there is probably a simple wiring solution to this but I just can't see it.
I'm using an RPi version 2 and have been following the instructions for the beetbox from here: http://www.imthi.com/blog/electronics/c ... mrp121.php
Everything seems to be working in that I can touch the pin holes on the mrp121 board and get a drum sound but how do I get it to release?
Right now if I insert a wire into the hole it registers. Leaving go of the wire does nothing so I'm at a loss as to how I need to connect the wire so that me touching it registers a touch and leaving go registers a release. My assumption was that the wire into the mpr board needed to be touching the surrounding ring to make the connection but if I wasn't holding it then it wouldn't register.
If it makes any difference, I'm using a jumpered wire from the rpi to a bare wire into the mrp board, then another bare wire into the 0 hole on the other side of the mpr board.
(This probably isn't clear enough as it's late so if someone needs me to re-word this with a picture or two just let me know)
What am I missing?
SyntaxError
