rakosi2
apt-get stuck
Fri May 09, 2014 2:38 am
Every time I try to install mysql with 'sudo apt-get install mysql-server', it freezes on the trigger. I have tried 5 or 6 times with new images. I have tried letting it run for a day. I am using the RASPBIAN january version. Is it safe to just ctrl-c or what should I do?
[email protected] ~ $ sudo apt-get install mysql-server
Reading package lists... Done
Building dependency tree
The following extra packages will be installed:
  heirloom-mailx libaio1 libdbd-mysql-perl libdbi-perl libhtml-template-perl
  libmysqlclient16 libnet-daemon-perl libplrpc-perl mysql-client-5.5
  mysql-common mysql-server-5.5 mysql-server-core-5.5
Suggested packages:
  exim4 mail-transport-agent libipc-sharedcache-perl libterm-readkey-perl
  tinyca
Recommended packages:
  mailx
The following NEW packages will be installed:
  mysql-common mysql-server mysql-server-5.5 mysql-server-core-5.5
0 upgraded, 13 newly installed, 0 to remove and 0 not upgraded.
Need to get 9,895 kB of archives.
After this operation, 91.2 MB of additional disk space will be used.
Do you want to continue [Y/n]? y
Get:1 http://mirrordirector.raspbian.org/raspbian/ wheezy/main libaio1 armhf 0.3.109-3 [8,944 B]
Get:2 http://mirrordirector.raspbian.org/raspbian/ wheezy/main mysql-common all 5.5.37-0+wheezy1 [83.1 kB]
Get:3 http://mirrordirector.raspbian.org/raspbian/ wheezy/main libnet-daemon-perl all 0.48-1 [46.2 kB]
Get:4 http://mirrordirector.raspbian.org/raspbian/ wheezy/main libplrpc-perl all 0.2020-2 [36.0 kB]
Get:5 http://mirrordirector.raspbian.org/raspbian/ wheezy/main libdbi-perl armhf 1.622-1 [895 kB]
Get:6 http://mirrordirector.raspbian.org/raspbian/ wheezy/main libmysqlclient16 armhf 5.1.62-1 [1,828 kB]
Get:7 http://mirrordirector.raspbian.org/raspbian/ wheezy/main libdbd-mysql-perl armhf 4.021-1 [123 kB]
Get:8 http://mirrordirector.raspbian.org/raspbian/ wheezy/main mysql-client-5.5 armhf 5.5.37-0+wheezy1 [1,471 kB]
Get:9 http://mirrordirector.raspbian.org/raspbian/ wheezy/main mysql-server-core-5.5 armhf 5.5.37-0+wheezy1 [3,078 kB]
Get:10 http://mirrordirector.raspbian.org/raspbian/ wheezy/main mysql-server-5.5 armhf 5.5.37-0+wheezy1 [1,921 kB]
Get:11 http://mirrordirector.raspbian.org/raspbian/ wheezy/main heirloom-mailx armhf 12.5-2 [253 kB]
Get:12 http://mirrordirector.raspbian.org/raspbian/ wheezy/main libhtml-template-perl all 2.91-1 [72.0 kB]
Get:13 http://mirrordirector.raspbian.org/raspbian/ wheezy/main mysql-server all 5.5.37-0+wheezy1 [81.4 kB]
Fetched 9,895 kB in 17s (562 kB/s)
Preconfiguring packages ...
Selecting previously unselected package libaio1:armhf.
(Reading database ... 48310 files and directories currently installed.)
Unpacking libaio1:armhf (from .../libaio1_0.3.109-3_armhf.deb) ...
Selecting previously unselected package mysql-common.
Unpacking mysql-common (from .../mysql-common_5.5.37-0+wheezy1_all.deb) ...
Selecting previously unselected package libnet-daemon-perl.
Unpacking libnet-daemon-perl (from .../libnet-daemon-perl_0.48-1_all.deb) ...
Selecting previously unselected package libplrpc-perl.
Unpacking libplrpc-perl (from .../libplrpc-perl_0.2020-2_all.deb) ...
Selecting previously unselected package libdbi-perl.
Unpacking libdbi-perl (from .../libdbi-perl_1.622-1_armhf.deb) ...
Selecting previously unselected package libmysqlclient16.
Unpacking libmysqlclient16 (from .../libmysqlclient16_5.1.62-1_armhf.deb) ...
Selecting previously unselected package libdbd-mysql-perl.
Unpacking libdbd-mysql-perl (from .../libdbd-mysql-perl_4.021-1_armhf.deb) ...
Selecting previously unselected package mysql-client-5.5.
Unpacking mysql-client-5.5 (from .../mysql-client-5.5_5.5.37-0+wheezy1_armhf.deb) ...
Selecting previously unselected package mysql-server-core-5.5.
Unpacking mysql-server-core-5.5 (from .../mysql-server-core-5.5_5.5.37-0+wheezy1_armhf.deb) ...
Processing triggers for man-db ...
Setting up mysql-common (5.5.37-0+wheezy1) ...
Selecting previously unselected package mysql-server-5.5.
(Reading database ... 48694 files and directories currently installed.)
Unpacking mysql-server-5.5 (from .../mysql-server-5.5_5.5.37-0+wheezy1_armhf.deb) ...
Selecting previously unselected package heirloom-mailx.
Unpacking heirloom-mailx (from .../heirloom-mailx_12.5-2_armhf.deb) ...
Selecting previously unselected package libhtml-template-perl.
Unpacking libhtml-template-perl (from .../libhtml-template-perl_2.91-1_all.deb) ...
Selecting previously unselected package mysql-server.
Unpacking mysql-server (from .../mysql-server_5.5.37-0+wheezy1_all.deb) ...
Processing triggers for menu ...
Setting up libaio1:armhf (0.3.109-3) ...
Setting up libnet-daemon-perl (0.48-1) ...
Setting up libplrpc-perl (0.2020-2) ...
Setting up libdbi-perl (1.622-1) ...
Setting up libmysqlclient16 (5.1.62-1) ...
Setting up libdbd-mysql-perl (4.021-1) ...
Setting up mysql-client-5.5 (5.5.37-0+wheezy1) ...
Setting up mysql-server-core-5.5 (5.5.37-0+wheezy1) ...
Setting up mysql-server-5.5 (5.5.37-0+wheezy1) ...
[ ok ] Stopping MySQL database server: mysqld.
140508 16:51:03 [Warning] Using unique option prefix key_buffer instead of key_buffer_size is deprecated and will be removed in a future release. Please use the full name instead.
140508 16:51:03 [Warning] Using unique option prefix myisam-recover instead of myisam-recover-options is deprecated and will be removed in a future release. Please use the full name instead.
140508 16:51:03 [Note] Plugin 'FEDERATED' is disabled.
140508 16:51:03 InnoDB: The InnoDB memory heap is disabled
140508 16:51:03 InnoDB: Mutexes and rw_locks use GCC atomic builtins
140508 16:51:03 InnoDB: Compressed tables use zlib 1.2.7
140508 16:51:03 InnoDB: Using Linux native AIO
140508 16:51:04 InnoDB: Initializing buffer pool, size = 128.0M
140508 16:51:04 InnoDB: Completed initialization of buffer pool
140508 16:51:04 InnoDB: highest supported file format is Barracuda.
140508 16:51:05  InnoDB: Waiting for the background threads to start
140508 16:51:06 InnoDB: 5.5.37 started; log sequence number 1595675
140508 16:51:06  InnoDB: Starting shutdown...
140508 16:51:07  InnoDB: Shutdown completed; log sequence number 1595675
[ ok ] Starting MySQL database server: mysqld . . . . . ..
[info] Checking for tables which need an upgrade, are corrupt or were
not closed cleanly..
Setting up heirloom-mailx (12.5-2) ...
update-alternatives: using /usr/bin/heirloom-mailx to provide /usr/bin/mailx (mailx) in auto mode
Setting up libhtml-template-perl (2.91-1) ...
Setting up mysql-server (5.5.37-0+wheezy1) ...
Re: apt-get stuck
Fri May 09, 2014 6:22 am
Have you run the following to update Raspbian ?
sudo apt-get update
sudo apt-get dist-upgrade
Then in future always run the first command prior to apt-get install to ensure the repositories are up to date..
Retired disgracefully.....
......to a more gentile life !
foobar1234
Re: apt-get stuck
Fri May 09, 2014 10:46 am
Seems to be some problem of the mysql-server package. I have exactly the same problem with it. Stays forever on "Processing triggers for menu ...", not only on installing, also on removing the package. All other packages work fine.
I just CTRL-C'ed out, everything worked (also mysql-server).
I switched to sqlite after that, since I wanted a more lightweight database. If you are not forced to mysql this could also be an alternative for you.
rakosi2
Re: apt-get stuck
Fri May 09, 2014 1:10 pm
Mysql first got stuck on Sunday May 4th on an update for mysql. After that it would always get stuck on the one location.
Re: apt-get stuck
Fri May 09, 2014 1:23 pm
Try
sudo apt-get update && sudo apt-get -f install # with no other operands
This is a doctor free zone.
rakosi2
Re: apt-get stuck
Fri May 09, 2014 9:23 pm
I just want a LAMP or similar to host a website with phpmyadmin. I would try to post a bug for mysql then if someone else has the same issue.
rakosi2
Re: apt-get stuck
Tue May 13, 2014 4:27 am
I am still stuck here at the 'Processing triggers for menu ...'
I have a already built website on MySQL and I have phpmyadmin on a LAMP.
I left my Pi working for a day and it would not go past the point.
I don't know what to do.
Re: apt-get stuck
Tue May 13, 2014 5:47 am
rakosi2 wrote:I am still stuck here at the 'Processing triggers for menu ...'
Have you tried pressing Ctrl-C yet?
rakosi2
Re: apt-get stuck
Tue May 13, 2014 1:10 pm
I don't know if Ctrl-C is safe?
It would crash on install, update, and uninstall.
FlexMcMurphy
Re: apt-get stuck
Tue May 20, 2014 10:42 pm
I had the same problem as the original poster.
I am dual booting Raspbian and OpenELEC using NOOBS. I am running Raspbian and ran the command:
sudo apt-get install mysql-server mysql-client php5-mysql
... but it hangs at 'Processing triggers for menu ...' I hit CTRL + C and now want to undo the half baked install with the command:
sudo apt-get purge mysql-server
... but it is now hanging on: "Reading Package lists... 0%"
I read that the problem may be because the file system ran out of space but I did a df - h and there is still lots of space on my 32 GB SD card and NOOBS automatically expands the filesystem to fill up the card anyway.
I also tried the command suggested above:
... but once again it is hanging on: "Reading Package lists... 0%"
Any advice on what I should do now? Start all over with a fresh NOOBs installation? I guess I should have made a backup of the Raspbian/OpenELEC dual boot setup before trying to install anything.
Anyone managed to install MySQL on Raspbian?
Flex
rakosi2
Re: apt-get stuck
Tue May 27, 2014 2:31 am
I gave up and just ctrl-c out. Ran:
sudo apt-get -y install heirloom-mailx libaio1 libdbd-mysql-perl libdbi-perl libhtml-template-perl mysql-client-5.5 mysql-server-core-5.5
sudo apt-get install mysql-server-5.5
sudo shutdown -r now
It will crash on mysql-server-5.5. My raspberry pi was extremely laggy after crash so I just restarted and everything was fine. I have not noticed anything not working. I am running a LAMP with PHPmyadmin and everything seems ok.
Got a reply at MySQL and they said its a Raspberry Pi issue because no one outside Raspberry Pi (Me) has reported this issue.
FlexMcMurphy
Re: apt-get stuck
Tue May 27, 2014 2:49 am
Hi rakosi2,
I started another thread over here: http://www.raspberrypi.org/forums/viewt ... 76#p556176 and a few other people have had the same experience as us. I also notice that even though the install hangs at the end, if you wait a while (I waited about an hour) you can then Ctrl+C out and it looks like the install works anyway... tho surely something won't be quite right?!
Thanks for taking the time to report this bug to MySql. It looks like an issue with the Pi (not enough memory?) or with the Raspbian OS (a file permission problem?). I might try and install MySql on Pidora and see if it works or not.
If you find a solution, please report it back to this thread?
Flex
rakosi2
Re: apt-get stuck
Sun Jun 08, 2014 12:30 am
Confirmed. I have tryed to install MySQL onto RASPBIAN (2013-09-25-wheezy-raspbian) and worked without crashing. It has to be 2014-01-07-wheezy-raspbian that is causing the crashes.
I used the 2013-09-25 version because I had it downloaded already. I have no clue if the other versions work. You can get the archive here,
http://downloads.raspberrypi.org/raspbian/images/
dev64
Re: apt-get stuck
Fri Jun 13, 2014 4:19 am
this happened to me last night. is there a fix available yet?
rakosi2
Re: apt-get stuck
Fri Jun 13, 2014 3:57 pm
dev64 wrote:this happened to me last night. is there a fix available yet?
Yes the fix is to use an older distro if you want it to complete or you could Ctrl-C at the crash.
FlexMcMurphy
Re: apt-get stuck
Fri Jun 13, 2014 7:50 pm
rakosi2...
Thanks for the link to the archive of past Raspbian Images!
I was trying to get an older-than-Jan-2014 Raspbian installed so I could get a clean start-to-finish-install of MySql... I was working from a NOOBS SD card that had an Oct 2013 Raspbian on it but when you install that you still have all the NOOBS stuff on the SD Card taking up space. I was trying to move and copy and delete partitions but it just wasn't happening for me. Now at least I can just start with a blank slate and finally get my LAMP server up and running!
Flex
Re: apt-get stuck
Fri Jun 13, 2014 7:59 pm
FlexMcMurphy
Re: apt-get stuck
Sun Jun 15, 2014 4:22 pm
I was having trouble with the command:
When using the January version of Raspbian the MySql install was freezing almost at the end on the line: 'Processing Triggers for Menu' I can confirm the fix in that thread link worked for me and thanks for the heads-up!
Flex
rakosi2
Re: apt-get stuck
Fri Jun 20, 2014 4:55 am
So the issue is reported here:
https://github.com/raspberrypi/linux/issues/617
The raspberry pi is trying to process 4096 GB of data making it:
  • Writes to the filesystem slow to a crawl
  • The ACT LED is almost permanently illuminated during IO
  • All processes waiting on IO spend a lot of the time sleeping, waiting for IO to complete.
No wonder it didn't finish in a week, It's trying to process 4 terabytes of dirty pages.
AndrewS
Re: apt-get stuck
Mon Jun 23, 2014 8:01 pm
The problem's been fixed! https://github.com/raspberrypi/linux/co ... 1a479d65a8
(well, technically it's been worked around)
You can either rpi-update to get the latest firmware (which includes the fix) https://github.com/Hexxeh/rpi-firmware/ ... 4ccf48091a
or you can simply use the latest 2014-06-20 version of Raspbian from http://www.raspberrypi.org/downloads which includes the fix too. The 2014-06-20 version of Raspbian is also included in the new NOOBS v1.3.8 8-)
FlexMcMurphy
Re: apt-get stuck
Mon Jun 23, 2014 10:38 pm
It's a real shame this forum doesn't offer a "Thumbs Up" feature... Cheers AndrewS (and everyone who contributed to the fix!)
AndrewS
Re: apt-get stuck
Mon Jun 23, 2014 10:56 pm
I guess the OP can close https://bugs.launchpad.net/raspbian/+bug/1319216 and http://bugs.mysql.com/bug.php?id=72603 now ;)
I helped track down the problem, and @jdb, @gsh and @popcornmix fixed it.
Ludo444
Re: apt-get stuck
Mon Jul 21, 2014 5:56 pm
I've got similiar issue, but installing MySQL is stuck on "Setting up mysql-server (5.5.37-0+wheezy1) ..." line. Everything goes smoothly until that. Any tips?
I've got newest up to date Raspbian with firmware from April.
  heirloom-mailx libaio1 libdbd-mysql-perl libdbi-perl libhtml-template-perl libmysqlclient16 mysql-client-5.5 mysql-common mysql-server-5.5 mysql-server-core-5.5
Suggested packages:
  exim4 mail-transport-agent libipc-sharedcache-perl libterm-readkey-perl tinyca
  mailx
  heirloom-mailx libaio1 libdbd-mysql-perl libdbi-perl libhtml-template-perl libmysqlclient16 mysql-client-5.5 mysql-common mysql-server mysql-server-5.5 mysql-server-core-5.5
0 upgraded, 11 newly installed, 0 to remove and 0 not upgraded.
Need to get 9,809 kB of archives.
After this operation, 91.0 MB of additional disk space will be used.
Get:3 http://mirrordirector.raspbian.org/raspbian/ wheezy/main libdbi-perl armhf 1.622-1+deb7u1 [890 kB]
Get:4 http://mirrordirector.raspbian.org/raspbian/ wheezy/main libmysqlclient16 armhf 5.1.62-1 [1,828 kB]
Get:5 http://mirrordirector.raspbian.org/raspbian/ wheezy/main libdbd-mysql-perl armhf 4.021-1 [123 kB]
Get:6 http://mirrordirector.raspbian.org/raspbian/ wheezy/main mysql-client-5.5 armhf 5.5.37-0+wheezy1 [1,471 kB]
Get:7 http://mirrordirector.raspbian.org/raspbian/ wheezy/main mysql-server-core-5.5 armhf 5.5.37-0+wheezy1 [3,078 kB]
Get:8 http://mirrordirector.raspbian.org/raspbian/ wheezy/main mysql-server-5.5 armhf 5.5.37-0+wheezy1 [1,921 kB]
Get:9 http://mirrordirector.raspbian.org/raspbian/ wheezy/main heirloom-mailx armhf 12.5-2 [253 kB]
Get:10 http://mirrordirector.raspbian.org/raspbian/ wheezy/main libhtml-template-perl all 2.91-1 [72.0 kB]
Get:11 http://mirrordirector.raspbian.org/raspbian/ wheezy/main mysql-server all 5.5.37-0+wheezy1 [81.4 kB]
Fetched 9,809 kB in 6s (1,555 kB/s)
(Reading database ... 31296 files and directories currently installed.)
Unpacking libdbi-perl (from .../libdbi-perl_1.622-1+deb7u1_armhf.deb) ...
(Reading database ... 31645 files and directories currently installed.)
Setting up libdbi-perl (1.622-1+deb7u1) ...
140721 19:20:57 [Warning] Using unique option prefix key_buffer instead of key_buffer_size is deprecated and will be removed in a future release. Please use the full name instead.
140721 19:20:57 [Warning] Using unique option prefix myisam-recover instead of myisam-recover-options is deprecated and will be removed in a future release. Please use the full name instead.
140721 19:20:57 [Note] Plugin 'FEDERATED' is disabled.
140721 19:20:57 InnoDB: The InnoDB memory heap is disabled
140721 19:20:57 InnoDB: Mutexes and rw_locks use GCC atomic builtins
140721 19:20:57 InnoDB: Compressed tables use zlib 1.2.7
140721 19:20:57 InnoDB: Using Linux native AIO
140721 19:20:57 InnoDB: Initializing buffer pool, size = 128.0M
140721 19:20:58 InnoDB: Completed initialization of buffer pool
140721 19:20:58 InnoDB: highest supported file format is Barracuda.
140721 19:20:58  InnoDB: Waiting for the background threads to start
140721 19:20:59 InnoDB: 5.5.37 started; log sequence number 1595675
140721 19:21:00  InnoDB: Starting shutdown...
140721 19:21:01  InnoDB: Shutdown completed; log sequence number 1595675
FlexMcMurphy
Re: apt-get stuck
Mon Jul 21, 2014 8:29 pm
I think your problem might be that you have the firmware from April. Try installing more up to date firmware and see if the MySQL installs this time... I ran this command to update my firmware:
rpi-update f6eef32dd6388c3b04dbf462bd324d93281bf397
Flex
Ludo444
Re: apt-get stuck
Tue Jul 22, 2014 4:49 pm
I forgot to mention that I'm using firmware from NEXT branch. Anyway, I solved it by manually compiling and installing MariaDB instead.
Strange thing is, that when I added mysql/mariadb to run after boot with
sudo update-rc.d mysqld defaults
and then installing other packages, aptitude get stuck at
[100%] Writing extended state information
Turn off mysqld service didn't help. Only removing from rc.d.
