I was wondering if it would be possible to construct a multi channel ADC that would accept at least 5.1 analogue audio inputs and output a true 5.1 digital audio signal via an optical cable using a Raspberry Pi as a starting point? So far I have been unable to find a PC audio card that outputs true 5.1/7.1 audio via its optical output, all of them only output 2 channel audio and passes DTS and Doloby Digital from DVD's and Bluerays that must be processed by the DTS and Doloby converters in an AVR to produce the 5.1 or 7.1. audio that is then sent to the speakers. I simply do not understand why Sony is able to output 7.1 digital audio via HDMI or optical outputs from the 8 year old design of the PS3 and none of the audio card manufactures that design and build PC audio cards still only output true 5.1 and 7.1 audio via their analogue outputs. This 2 channel solution is ok if all you do is listen to music and watch commercial DVD's and Blueray movies but not for gaming. If you are a PC gamer the only way to get true 5.1 output from the games that support this is to use the analogue outputs from your sound card. After investing in a really good home theater sound system and wanting to utilize it for my PC audio as well I started wondering if constructing a relatively inexpensive ADC using the Raspberry Pi as a starting point were possible. Do any of you have any thoughts on this subject?
