Kewngen
Rpi + MCP3008 + Arduino sensor?
Thu May 08, 2014 8:43 am
A lot of the cheaper sensors around the internet are for Arduino, for example: http://www.aliexpress.com/store/product ... 12904.html
Is it possible with use MCP3008 and a RPi to read a sensor made for the Arduino (like the one in the link)?
BMS Doug
Re: Rpi + MCP3008 + Arduino sensor?
Thu May 08, 2014 10:16 am
Kewngen wrote:A lot of the cheaper sensors around the internet are for Arduino, for example: http://www.aliexpress.com/store/product ... 12904.html
yes, the board you linked outputs a 0-5v dc signal to indicate rainfall, a MCP3008 will be able to convert that to a SPI communication to your Pi.
Doug.
Building Management Systems Engineer.
Kewngen
Thu May 08, 2014 10:24 am
Thank you for quick reply!
I assume it would work with all these sensors then? http://www.dx.com/p/arduno-37-in-1-sens ... ack-142834
BMS Doug
Thu May 08, 2014 1:16 pm
Looking at the 37 sensors shown, I would imagine that for the most part they will either work with the MCP3008 or work directly with the Pi.
Doug.
