I would like to hear your feedback and suggestions for the project.Projects such as the following diagram.
1.Raspberry Pi Camera Alternative
The camera will be exposed to water and its cable should not be affected from movement of servo motor and water. So I will not use Raspberry Pi's camera because its CSI cable is too fragle and also I cannot merge its cables into one cable.How can I merge the CSI cable in one water-proof cable? Or can you suggest me any camera? I was planning to make a water-proof box for Raspberry Pi's camera, but its suspended for now.
2.In project, camera display will be viewed on a LCD screen. Servo motor will be controlled with the X-axis of a Joystick. Also there will be a LED circuit placed near to the camera and it will be controlled by the Y-axis of Joystick. There will be sensors on back of the servo motor. When a fire broke out, a warning will be displayed on LCD screen with the help of these sensors. Is Raspberry Pi a good choice for this project?
3.Is Raspberry Pi qualified enough?
I heard that Raspberry Pi is slow. Is it qualified enough for this project or should I use another SBC?
